Topic: List only *.csv files (Read 5497 times) previous topic - next topic
Onenate
hey guys are am trying to write some code that will only list the *.CSV files in the root directory
I have found this but have no idea how to use it
uint8_t SdBaseFile::type  (  ) const
http://mosquino.googlecode.com/hg/libraries/sdfatlib-mosquino/html/class_sd_base_file.html#a1555e6866abc9c867c5fff189a3a4317
any help would be great
PaulS
That function determine whether the instance is a directory or a file, not what the extension of a file is.
Seeing your code would be useful.
marco_c
Code from a program that build up a list of file name ending with MIDI_EXT (.MID). You should be able to adapt it for your use somehow, or just find out how you do what you need. I used the sdFat library, so the function calls may be different, and it created a file on the SD card with all the file names that I could then use to display in a menu.
Code: [Select]
uint16_t createPlaylistFile(void)
// create a playlist file on the SD card with the names of the files.
// This will then be used in the menu.
SdFile plFile; // Playlist file
SdFile mFile; // MIDI file
uint16_t count; // count of files
char fname[FNAME_SIZE];
// open/create the playlist file
if (!plFile.open(PLAYLIST_FILE, O_CREAT|O_WRITE))
LCDErrMessage("PL create fail", true);
count = 0;
while (mFile.openNext(SD.vwd(), O_READ))
if (mFile.isFile())
mFile.getFilename(fname);
if (strcmp(MIDI_EXT, &fname[strlen(fname)-strlen(MIDI_EXT)]) == 0)
// only include files with MIDI extenstion
plFile.write(fname, FNAME_SIZE);
count++;
mFile.close();
// close the playlist file
plFile.close();
return(count);
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
Onenate
thanks Marco_c  that has give me something to start with i have added it to the basic sdfatls code I have tried to fixup some of the references you had in their just checking how did you declare the midi_ext I thought it maybe like
char           CSV_EXT[] =  ".csv";
but I think I may be wrong some help to clean up the mess I created would be much appreciated :)
Code: [Select]
* This sketch will list all files in the root directory and
* then do a recursive list of all directories on the SD card.
#include <SdFat.h>
#include <SdFatUtil.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFat sd;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  PgmPrintln("Type any character to start");
// Serial.print("SS_PIN "); Serial.println(SS_PIN, DEC);
  while (!Serial.available());
  PgmPrint("Free RAM: ");
  Serial.println(FreeRam());
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  // if (!card.init(SPI_HALF_SPEED))
  pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
  digitalWrite(10, HIGH); // but turn off the W5100 chip!
  if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
  // initialize a FAT volume
  if (!volume.init(&card)) error("vol.init failed!");
  PgmPrint("Volume is FAT");
  Serial.println(volume.fatType(),DEC);
  if (!root.openRoot(&volume)) error("openRoot failed");
  // list file in root with date and size
  PgmPrintln("Files found in root:");
  root.ls(LS_DATE | LS_SIZE);
  // Recursive list of all directories
  PgmPrintln("Files found in all dirs:");
  root.ls(LS_R);
  PgmPrintln("Done");
SdFile lFile; //list files
       int          FNAME_SIZE;
        char fname[128];
        char            file_list[100];
if (!plFile.open(file_list, O_CREAT|O_WRITE))
//LCDErrMessage("PL create fail", true);
count = 0;
while (lFile.openNext(sd.vwd(), O_READ))
if (lFile.isFile())
lFile.getFilename(fname);
if (strcmp(CSV_EXT, &fname[strlen(fname)-strlen(CSV_EXT)]) == 0)
plFile.write(fname, 100  );
count++;
lFile.close();
plFile.close();
return(count);
createPlaylistFile(); }
marco_c
Code: [Select]
#define MIDI_EXT ".MID"
What you have is more efficient if the compiler can't recognise multiple uses as the same thing.
Alternatively this should also work
Code: [Select]
char *csv_ext = ".csv";
You do understand that my code creates a file on the SD card with the list of names in it? This is probably not what you want, exactly.
You also should call the function once from setup() and not every time through the loop. The list of files will not change every a few milliseconds :)
Think about what you have done with this one - what is executed if the 'if' is true? if you are not handling an error then get rid of the if statement or call your error function instead.
Code: [Select]
Onenate
thanks for you that but what your code is doing is exactly what I need it to do is create a list of files and then upload those files that end with .csv to a server
I have made the changes that you recommended but still get nothing it does not create the file.
Code: [Select]
#include <SdFat.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFat sd;
    Serial.print(',');
  while(1);
  root.ls(LS_R);
  PgmPrintln("Done");
PgmPrintln("start of CSV List __________________>");
       int          FNAME_SIZE;
          char fname[128];
        char   file_list[200] = "FILELIST.TXT" ;
        char *CSV_EXT = ".csv";
!plFile.open(file_list, O_CREAT|O_WRITE);
count = 0;
if (lFile.isFile())
count++;
lFile.close();
plFile.close();
return(count);
PaulS
Quote
There is no real reason why the variable name needs to bear any relationship to the value.
Code: [Select]
char *ext = "mid";
could have become
Code: [Select]
char *ext = "csv"';
with no need to change the rest of the code, to list files with different extensions.
Onenate
for some strange reason it is still not creating the file so of course it will not log to it?
Code: [Select]
#include <SdFat.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFat sd;
    Serial.print(',');
  while(1);
  root.ls(LS_R);
  PgmPrintln("Done");
        int  FNAME_SIZE;
        char  fname[200];
        char  file_list[] = "FILELIST.TXT";
       // #define *CSV_EXT "csv";
        char *CSV_EXT = ".CSV";
   !plFile.open("FILELIST.TXT", O_CREAT|O_WRITE);
//  {    sd.errorHalt("opening FILELIST.TXT for write failed");
      Serial.println(file_list);
count = 0;
{ if (lFile.isFile())
{ lFile.getFilename(fname);
if (strcmp(CSV_EXT, &fname[strlen(fname)-strlen(CSV_EXT)]) == 0){
plFile.write(fname, 100);
count++;
lFile.close();
plFile.close();
Serial.print(fname);
Serial.println("finished");
return(count);
Onenate
and if I change the char to  define CSV I get the following error
SdFatLs___list_csv.ino: In function 'uint16_t createPlaylistFile()':
SdFatLs___list_csv:101: error: expected `)' before ';' token
SdFatLs___list_csv:101: error: expected primary-expression before ',' token
SdFatLs___list_csv:101: error: expected `]' before ';' token
SdFatLs___list_csv:101: error: expected primary-expression before ')' token
SdFatLs___list_csv:101: error: expected `;' before ')' token
Onenate
the strange thing is if I change the code from
Code: [Select]
and  add a ! it seems to go in to an infinite loop
Code: [Select]
while (!lFile.openNext(sd.vwd(), O_READ))
but with out it, it does not seem to run the command at all.
Onenate
Done
FILELIST.TXT
count 0
finished
Code: [Select]
count = 0;
Serial.println("opened file");
  if (lFile.isFile())
count++;
lFile.close();
plFile.close();
Serial.printlb(count);
return(count);
marco_c
Code: [Select]
Not sure what the ! is doing there. I would also recommend that you do some error checking to see if the file is opened.
Quote
which indicates that the call is failing.
The sdFat library uses openNext() exclusively. Many other libraries use a combination of openFirst() and then openNext(). You may need to check if that applies to the library you are using. If that is the case, then you need to change the file checking logic to be initialised outside the loop, something like:
file = OpenFirst()
while (file is open)
  do stuff
  file = openNext()
end while
PeterH
If you think about what the code is doing, it's not strange at all. The only strange thing is why you think the command "isn't being run at all". In both cases, the command will always be run at least once if execution reaches that piece of code.
I only provide help via the forum - please do not contact me for private consultancy.
PaulS
Code: [Select]
        int  FNAME_SIZE;
        char  fname[200];
Since the SDFat and SD libraries only support fat16 format, which means 8.3 names, pissing away 200 bytes to hold a 12 character (including the trailing NULL) file names seems wasteful.
Code: [Select]
You know (or should) how long the name is. Why are you stuffing 100 bytes of mostly garbage in the file?
Onenate
okay I have tired to simplify the code if I comment out the  //if (plFile.open(file_list, O_CREAT|O_WRITE)); the code works :)
but when I add it back in with the  if (plFile.open(file_list, O_CREAT|O_WRITE)); or even with out  plFile.open(file_list, O_CREAT|O_WRITE);
it completes but skips the openNext command, I am using IDE 1.0.3 and the lastest SDFAT library
Code: [Select]
#include <SdFat.h>
#include <SdFile.h>
// SD chip select pin
const uint8_t chipSelect = SS;
// file system object
SdFat sd;
SdFile file;
       int  FNAME_SIZE;
       char  fname[200];
       char *CSV_EXT = "CSV";
// define a serial output stream
ArduinoOutStream cout(Serial);
if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
count = 0;
while (file.openNext(sd.vwd(), O_READ))
 Serial.println("Started");
    if (file.isFile())
{ file.getFilename(fname);
count++;
file.close();
plFile.close();
Serial.println("count");
Serial.print(count);
void loop() {}
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
