Topic: List only *.csv files (Read 6608 times) previous topic - next topic
UKHeliBob
What are the symptoms of the failure to load the sketch ?
Error messages ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Onenate
I have worked out the upload issues it was me bricking the Mega as it does not like uploading a sketch with the timeout library in it, lesson learned.
What I have got the sketch doing is checking for a network connection every time it sends a packet and if it fails it call the following command
Code: [Select]
byte FTPDroped()
 byte thisByte = 0;
 Serial.println("-----------------FTP Dropped !!!!!!!!!!!!!!!!!!!!!!!!!!!!");
 dclient.stop();
 Serial.println("Data disconnected");
 client.write("QUIT\r\n");
 client.stop();
 Serial.println("Command disconnected");
 ufile.close();
 Serial.println("SD closed");
 return 0;
 void loop ();
The only issue is that keeps on cycling through ever packet and I need it stop and go back to the normal loop
pingfail
----------------- FTP Dropped !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Data disconnected
SD closed
Packet
Onenate
here is the full code
Code: [Select]
#include <SdFat.h>
#include <SdFatUtil.h>
#include <SdFile.h>
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
// comment out next line to write to SD from FTP server
#define FTPWRITE
#define error(s) error_P(PSTR(s))
SOCKET pingSocket = 0;
// this must be unique
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 };
// change to your network settings
IPAddress ip( 192, 168, 3, 177 );
IPAddress gateway( 192, 168, 3, 254 );
IPAddress subnet( 255, 255, 255, 0 );
byte pingAddr[] = {
  192,168,3,254}; // ip address to ping
// SD chip select pin
const uint8_t chipSelect = SS;
// file system object
SdFat sd;
SdFile uploadfile;
uint16_t count; // count of files
int const file_size =13;
char fname[file_size];
char dname[file_size];
//char file_list[13] = "10000219.CSV";
char fileName[13] = "10000221.CSV";
char *CSV_EXT = "CSV";
char pingbuffer [256];
#define SD_SELECT 4
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile dfile;
SdBaseFile ufile;
// change to your server
//IPAddress server(serverName);
char serverName[] = "update.FTP.com";
EthernetClient client;
EthernetClient dclient;
char outBuf[128];
char outCount;
int CYCCount = 0;
byte pingcount=0;
byte pingfail=0;
// change fileName to your file (8.3 format!)
//char fileName[13] = "10000219.CSV";
ArduinoOutStream cout(Serial);
//...............errors..................
void error_P(const char* str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  if(sd.begin(4) == 0)
    Serial.println("SD init fail");
  PgmPrint("Free RAM: ");
  Serial.println(FreeRam());
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  // if (!card.init(SPI_HALF_SPEED))
  pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
  digitalWrite(10, HIGH); // but turn off the W5100 chip!
  if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
  // initialize a FAT volume
  if (!volume.init(&card)) error("vol.init failed!");
  PgmPrint("Volume is FAT");
  Serial.println(volume.fatType(),DEC);
  if (!root.openRoot(&volume)) error("openRoot failed");
  // list file in root with date and size
  PgmPrintln("Files found in root:");
  root.ls(LS_DATE | LS_SIZE);
  // Recursive list of all directories
  PgmPrintln("Files found in all dirs:");
  root.ls(LS_R);
  PgmPrintln("Done");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  if ( CYCCount >= 1000)
    bool pingRet;
    ICMPPing ping(pingSocket);
    pingRet = ping(3, pingAddr, pingbuffer);
    Serial.println(pingbuffer);
    if(pingRet) // Failure
      Serial.println("pingSuccess");
      pingcount = pingcount +1;
      Serial.println("pingfail");
      pingfail = pingfail +1;
    if (pingcount >=10)
      Serial.println("FTP upload Started ");
      sd.vwd()->rewind();
      callfile();
      CYCCount = CYCCount =0;
      pingcount =pingcount =0;
    if (pingfail >=1)
      pingfail = pingfail =0;
  Serial.println(CYCCount);
  CYCCount =CYCCount +1 ;
//***************************************** voids******************************************//
void callfile()
  Serial.println("Call File");
  count = 0;
  while (uploadfile.openNext(sd.vwd(), O_READ))
    if (uploadfile.isFile())
      uploadfile.getFilename(fname);
      if (strcmp(CSV_EXT, &fname[strlen(fname)-strlen(CSV_EXT)]) == 0){
        Serial.print("Call File -----------------");
        Serial.println(fname);
        doFTP();
        count++;
    delay (1000);
    uploadfile.close();
void todelete()
  if (strcmp(fname,fileName) == 0){
    Serial.println("Working File");
    uploadfile.close();
    uploadfile.close();
    if (dfile.open(&root, fname, O_RDWR))
      dfile.remove() ;
    Serial.println("----------------------------------------------------------->File To Be Deleted");
byte doFTP()
  Serial.println("SD opened");
  if (client.connect(serverName,21)) {
    Serial.println("Command connected");
  else {
    ufile.close();
    Serial.println("Command connection failed");
    return 0;
  if(!eRcv()) return 0;
  client.write("USER username\r\n");  // change your username here
  client.write("PASS password\r\n"); // change your password here
  client.write("SYST\r\n");
  client.write("PASV\r\n");
  char *tStr = strtok(outBuf,"(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL,"(,");
    array_pasv[i] = atoi(tStr);
    if(tStr == NULL)
      Serial.println("Bad PASV Answer");
  unsigned int hiPort,loPort;
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  Serial.print("Data port: ");
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(serverName,hiPort)) {
    Serial.println("Data connected");
  else {
    Serial.println("Data connection failed");
    client.stop();
    ufile.close();
    return 0;
  Serial.println("open file");
  ufile.open(fname,O_READ);
  client.write("STOR ");
  client.println(fname);
  if(!eRcv())
    dclient.stop();
    return 0;
  Serial.println("Writing");
  byte clientBuf[64];
  int clientCount = 0;
  while(ufile.available())
    clientBuf[clientCount] = ufile.read();
    clientCount++;
    if(clientCount > 63)
      connectionConnect();
      Serial.println("Packet");
      dclient.write(clientBuf,64);
      clientCount = 0;
  if(clientCount > 0) dclient.write(clientBuf,clientCount);
  dclient.stop();
  //  if(!eRcv()) return 0;
  //if(!eRcv()) return 0;
  client.stop();
  ufile.close();
  return 1;
  // todelete();
byte eRcv()
  Serial.println("Running Err Check");
  byte respCode;
  byte thisByte;
  Serial.print ("Response Code1 -");
  Serial.println (respCode);
  Serial.print ("byte Code1 - ");
  Serial.println (thisByte);
  while(!client.available()) delay(1);
  Serial.println("Past Delay");
  respCode = client.peek();
  Serial.println(respCode );
  outCount = 0;
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if(outCount < 127)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  Serial.print ("Response Code");
  if(respCode >= '4')
    efail();
    return 0;
  Serial.println("-----------------buffe ");
  return 1;
//*********************************** Standard Fail*************************************//
void efail()
  byte thisByte = 0;
  client.stop();
  ufile.close();
//*********************************** Ping Network*************************************//
void connectionConnect()
  bool pingRet = ping(1, pingAddr, pingbuffer);
  //Serial.println(pingbuffer);
  if(pingRet) // Check if ping is alive
    FTPDroped();
//*********************************** Interrupt Fail*************************************//
byte FTPDroped()
  byte thisByte = 0;
  Serial.println("----------------- FTP Dropped !!!!!!!!!!!!!!!!!!!!!!!!!!!!");
  dclient.stop();
  client.stop();
  ufile.close();
  return 0;
  void loop ();
any ideas
Onenate
if I add a ICMP ping server command in the byte eRcv() part it just hangs it never continue the loop. any ideas why?
Code: [Select]
byte eRcv()
  { Serial.println("pingSuccess"); }
    ftpfail= ftpfail=1;
    FTPDroped();
  byte respCode;
  byte thisByte;
  outCount = 0;
    if(outCount < 127)
      outCount++;
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
Onenate
okay I worked it out it was the erfail() hanging so I changed it to just bailout and it works a treat  :)
PaulS
Quote
That's not it. It doesn't like you (trying to) upload(ing) a sketch with this in it:
Code: [Select]
Three exclamation marks in a row trigger debug mode. The rest of the sketch is not then debug instructions.
Is that really necessary? Do all those dashes and exclamation marks add any value? The text "FTP Dropped" tells you all that you need to know. Hyperventilating over the dropped connection isn't going to help.
Onenate
Quote
I was trying to use the following watch dog timer.
http://www.nongnu.org/avr-libc/user-manual/group__avr__watchdog.html
Quote
This was really only  for debugging so I could see the FTP drop.
now I have it all working I just need to bring all the modules together.
Paul, thankyou for all your assistance.
Onenate
If any one wants the full working code ( based on the original code from surfertim, only works in passive mode).
That does the follow
1. Work with sdfat library
2. Work with w5100
3. Check sd card for *.csv files but can be changed easily to .txt or what ever you want
4. Pings the FTP server and starts to upload the file and if connection drops it bailsout and restarts the cycle.
5. Pings the server with every packet it send then send the packet.
6. If completed successfully it will delete the file from the SD card unless it is the current working file.
7. Goes in to a loop currently counting to 1000 then check for the network connection.
Well it all seems to work a treat for me.. Thanks to everyone assistance. :)
Onenate
Code: [Select]
#include <SdFat.h>
#include <SdFile.h>
#include <SPI.h>
#define FTPWRITE
byte mac[] = {
byte pingAddr[] = {192,168,3,254}; // ip address to ping
// SD chip select pinM
SdFat sd;
SdFile uploadfile;
#define SD_SELECT 4
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile dfile;
SdBaseFile ufile;
char serverName[] = "update.ftpserver.com"; // Change Server name
char outBuf[128];
char outCount;
int CYCCount = 0;
byte pingcount=0;
byte pingfail=0;
byte ftpfail=0;
    Serial.print(',');
  while(1);
  pinMode(10,OUTPUT);
  root.ls(LS_R);
  PgmPrintln("Done");
  delay(2000);
    bool pingRet;
    if (pingcount >=10)
      sd.vwd()->rewind();
      callfile();
    if (pingfail >=1)
//********************************************* Voids*****************************************************//
void callfile()
  count = 0;
        doFTP();
        count++;
    delay (1000);
    uploadfile.close();
  ftpfail = 0;
//----------------------------------------------------- Delete Not Current File---------------------------------------//
void todelete()
    uploadfile.close();
    uploadfile.close();
      dfile.remove() ;
    Serial.println("----------------->File To Be Deleted");
//----------------------------------------------------- FTP Server Connection---------------------------------------//
byte doFTP()
    ftpfail= ftpfail=1;
  if (ftpfail==0){
  else {
    ufile.close();
    return 0;
  int array_pasv[6];
    if(tStr == NULL)
  else {
    client.stop();
    ufile.close();
    return 0;
  if(!eRcv())
    dclient.stop();
    return 0;
  byte clientBuf[64];
    clientCount++;
        ftpfail= ftpfail=1;
        goto bailout;
        //FTPDroped();
      clientCount = 0;
bailout:
  dclient.stop();
  client.stop();
  ufile.close();
  Serial.print("Ftp Status - ");
  Serial.println(ftpfail);
  if (ftpfail==0)
    todelete();
  return 1;
//----------------------------------------------------- FTP Errors---------------------------------------//
byte eRcv()
  Serial.println("Running Error Check");
  byte respCode;
  byte thisByte;
// Serial.println (respCode);
// Serial.println (thisByte);
  while(client.connected() && !client.available()) delay(1);
    Serial.print ("Response Return -");
  outCount = 0;
    if(outCount < 127)
      outCount++;
  if(respCode >= '4')
    Serial.println("-----------------Fail Response");
    FTPDroped();
    return 0;
  return 1;
//----------------------------------------------------- Ping Server---------------------------------------//
byte pingserver()
    ftpfail= ftpfail=1;
//----------------------------------------------------- FTP Fail & Quit---------------------------------------//
byte FTPDroped()
  Serial.println("-----------------FTP Dropped");
  dclient.stop();
  client.stop();
  ufile.close();
  return 0;
