Topic: eye blinking in Neurosky with Arduino (Read 19430 times) previous topic - next topic
Nathan-NIS
Hi
I am a french student and I have a project for the Science of the Engineer section.
In this project we use Arduino for receiving data from the headset Mindwave.
Here is my problem:
I'd use the eye blinking to control a servo motor but I can not get this data, I did search but nothing concrete. Apparently I should initialize arduino to handle that type of data.
I already have a working program, but uses the attention ...
Thank you for your help and sorry for my English.
Erdin
Mindwave Neurosky, http://store.neurosky.com/products/mindwave-1
lomanas123
What extacly you want to read from?
analog or digital?
Ryan_MX
I'm also encounterin' this problem and I've noticed in the Mindset communication protocole documentation that the eyes blinkin' datas are only availbale with the TGCD and TGC APIs.
I keep searching but and don't have any hopes at all  =(
Please share with us your findings, I will do same.
Cheers
Ryan_MX
Hi all!
Nathan-NIS I've finally resolved the problem.
If you want to detect the eye blink with your headset Mindwave you should do an unexpected manipulation of your headset  ]:D
I'm joking! the tip is to detect when the EEG datas theta or the raw datas values reach a threshold because eye blinks are artifacts i.e some noise for these values.
When you blink your eyes, you should detect a peack between two raw datas  8)
enriqueortiz
Can you detect the blinking with the MindWave and Arduino?
joberol917
Hi Ryan,can you give tutorial for us?
how to get blinkStrength value from the headset..
voltron
Hello guys,
I have the same question. How can I get the blink strength value from Mindwave Mobile's EEG signal in Arduino?
I have found the following link on linkedin where you can find useful information on how to enable blink detection in TG_EnableBlinkDetection( int connectionId, int value) function in thinkgear.h file.
http://www.linkedin.com/groupAnswers?trk=NUS_DISC_Q-subject&gid=3572341&commentID=86548885&goback=.gmp_3572341.amf_3572341_13650068&viewQuestionAndAnswers=&discussionID=127150629
But my question still is even if I do that, how can I get the blink strength value in Arduino?
Thank you all.
Voltron
zixzixzix
Hi all!
could you please tell me how to detect?
i got rawValue but it looks random
Houseman74
Hi all!
Ryan_MX Hi, never mind but telling us these things it helps Us no way.
Everyone on the internet can grab these description, but we need at least the code that extracts the raw data in Arduino.. Any other speech is like fried air…
Regards
siva2013154046
   I got the Eye Blink output in arduino by using Raw EEG data,
  https://www.pantechsolutions.net/eye-blink-control-led-using-arduino
siva2013154046
For More Projects Mindwave using Arduino,
      https://www.pantechsolutions.net/mind-meditation-control-led-using-arduino
      https://www.pantechsolutions.net/mind-attention-control-led-using-arduino
      https://www.pantechsolutions.net/interfacing-mindwave-mobile-with-arduino
Noaman
hi i hope you will be fine, i wanted to get neurosky eeg headset band values like alpha,beta,gamma,delta and theta. i need help how to get those on arduino via bluetooth
