Topic: Help with LED Lamp concept. (Read 22853 times) previous topic - next topic
kculm
On the at85 I use 3,Red 0,Green 1,Blue.
Shuffle that red over to D4 and I think you'll have a better result.  The tiny core doesn't give you hardware PWM control on D3 so the effect of analogWrite() will be a harsh cut-over from OFF to ON.
Cheers ! Geoff
Thanks Geoff,  But I have a question. The diagram http://www.akafugu.jp/images/microcontroller-reference-sheet.png it show PIN 3 as PWM.  am I missing something as usual
thanks
kculm
all most there.
I have one last issue,  When I run it with out transistors on the Arduino it works smooth. But when I use 3, PNP transistors it works fine up until the Green to Blue transition. It almost dims out completely then flicker to blue.
You can see what I am talking about here.http://www.youtube.com/watch?v=on6Qf8OeYgg&feature=youtu.be  The first 45 sec our so is with out Transistors.  After a few sec of blackness it with transistors.
Sorry for the poor video
strykeroz
Cheers ! Geoff
thanks
it is. It's just not usable as one in the Arduino IDE.  use 4 and you'll be fine.
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
fungus
#18
Feb 20, 2013, 02:32 pm Last Edit: Feb 20, 2013, 02:35 pm by fungus Reason: 1
There's a hardware limitation: Pin 3 can only output the inverse of pin 4, pin 4 is the 'true' signal.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
strykeroz
While that's strictly true for the datasheet, in reply #38 of this thread on ATTiny85 and PWM Coding Badly explained that the inverted PWM output can't be used by the Arduino cores for ATTiny.  My own testing confirms this gotcha - that D3 is not able to use hardware PWM with the arduino-tiny core.  Software PWM like the tone() function works fine on all 5 of the standard ATTiny85 IO pins though, so there's an easy way around this limitation if you must use that leg.
Cheers ! Geoff
fungus
You know the PWM is working so it has to be a power supply problem. You probably need some decoupling. Add ceramic capacitors between ground and 5V next to the transistors (as close as you can), see if that helps.
fungus
I don't know how the cores use the timers. I know that using hardware PWM on D3 and D4 at the same time wouldn't work for analogueWrite() functions.
kculm
#22
Feb 20, 2013, 05:53 pm Last Edit: Feb 20, 2013, 07:21 pm by kculm Reason: 1
Thanks I will give that a try when I get home tonight.  But so I am clear. I need to put a Cap  from a Ground pin on the Arduino to the emitter on the PNP // Or is it from the Ground real to the 5v real.
And what size Cap..    ( Way to much to learn, I am glad it is fun).
Thanks
fungus
Between ground (any ground) and the 5V power line as close to the PNP as possible (touching it is good).
0.1 ... 0.22 uF, that sort of size, but only ceramic type.
kculm
I am using 3 transistors, so I am thinking one for each?
Also I cant thank you guys enough, I am learning so much.
fungus
At least! :)
kculm
At least! :)
Did not help,
it works fine with out transistors. not as bright. and it only jacks up on the full blue to full green and full green to full blue.
fungus
Has to be a power problem...how many mA are you using, how many are available.
ie. At maximum current.
kculm
Right now I am testing it on an Arduino uno.
This is what I get.  With out transistors it works fine. With Transistors is when I get the bule to green, green to blue issues.
If I use an at85 with out Transistors Is all jacked up, but with transistors I have the same issue as with Using the Arduino.
I have found another sketch but its not as nice, and I hate to just give up.
kculm
The green fades almost to nothing and the blue jumps on,  if that helps any
