Topic: Help with LED Lamp concept. (Read 24215 times) previous topic - next topic
fungus
I have found another sketch but its not as nice, and I hate to just give up.
I can't see your circuit from here, unfortunately. Can you draw it?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
kculm
strykeroz
If you back this down to just one RGB LED for simplicity, does it work smoothly on the ATTiny setup?
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
kculm
Same Effect .
strykeroz
Excellent. Then can you post the current version of the code here? We have to be close to sorting this now...
kculm
This is what I am using. Pretty Much the same. I just changed the Following.
#define  MAX_RGB_VALUE  245  // no bigger than 255.  (it was 255)
Works OK. just not a Rich
Code: [Select]
RGB LED - Automatic Smooth Color Cycling
Marco Colli
April 2012
Uses the properties of the RGB Colour Cube
The RGB colour space can be viewed as a cube of colour. If we assume a cube of dimension 1, then the
coordinates of the vertices for the cubve will range from (0,0,0) to (1,1,1) (all black to all white).
The transitions between each vertex will be a smooth colour flow and we can exploit this by using the
path coordinates as the LED transition effect.
// Output pins for PWM
#define  R_PIN  4  // Red LED
#define  G_PIN  0  // Green LED
#define  B_PIN  1  // Blue LED
// Constants for readability are better than magic numbers
// Used to adjust the limits for the LED, especially if it has a lower ON threshold
#define  MIN_RGB_VALUE  10   // no smaller than 0.
// Slowing things down we need ...
#define  TRANSITION_DELAY  70   // in milliseconds, between individual light changes
#define  WAIT_DELAY        500 // in milliseconds, at the end of each traverse
// Total traversal time is ((MAX_RGB_VALUE - MIN_RGB_VALUE) * TRANSITION_DELAY) + WAIT_DELAY
// eg, ((255-0)*70)+500 = 18350ms = 18.35s
// Structure to contain a 3D coordinate
typedef struct
  byte  x, y, z;
} coord;
static coord  v; // the current rgb coordinates (colour) being displayed
Vertices of a cube
    C+----------+G
  B+---------+F |
   | |       |  |    y
   |D+-------|--+H   ^  7 z
  A+---------+E      +--->x
const coord vertex[] =
//x  y  z      name
  {0, 0, 0}, // A or 0
  {0, 1, 0}, // B or 1
  {0, 1, 1}, // C or 2
  {0, 0, 1}, // D or 3
  {1, 0, 0}, // E or 4
  {1, 1, 0}, // F or 5
  {1, 1, 1}, // G or 6
  {1, 0, 1}  // H or 7
A list of vertex numbers encoded 2 per byte.
Hex digits are used as vertices 0-7 fit nicely (3 bits 000-111) and have the same visual
representation as decimal, so bytes 0x12, 0x34 ... should be interpreted as vertex 1 to
v2 to v3 to v4 (ie, one continuous path B to C to D to E).
const byte path[] =
  0x01, 0x23, 0x76, 0x54, 0x03, 0x21, 0x56, 0x74,  // trace the edges
  0x13, 0x64, 0x16, 0x02, 0x75, 0x24, 0x35, 0x17, 0x25, 0x70,  // do the diagonals
#define  MAX_PATH_SIZE  (sizeof(path)/sizeof(path[0]))  // size of the array
  pinMode(R_PIN, OUTPUT);   // sets the pins as output
  pinMode(G_PIN, OUTPUT);
  pinMode(B_PIN, OUTPUT);
void traverse(int dx, int dy, int dz)
// Move along the colour line from where we are to the next vertex of the cube.
// The transition is achieved by applying the 'delta' value to the coordinate.
// By definition all the coordinates will complete the transition at the same
// time as we only have one loop index.
  if ((dx == 0) && (dy == 0) && (dz == 0))   // no point looping if we are staying in the same spot!
    return;
  for (int i = 0; i < MAX_RGB_VALUE-MIN_RGB_VALUE; i++, v.x += dx, v.y += dy, v.z += dz)
    // set the colour in the LED
    analogWrite(R_PIN, v.x);
    analogWrite(G_PIN, v.y);
    analogWrite(B_PIN, v.z);
    delay(TRANSITION_DELAY);  // wait fot the transition delay
  delay(WAIT_DELAY);          // give it an extra rest at the end of the traverse
  int    v1, v2=0;    // the new vertex and the previous one
  // initialise the place we start from as the first vertex in the array
  v.x = (vertex[v2].x ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  v.y = (vertex[v2].y ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  v.z = (vertex[v2].z ? MAX_RGB_VALUE : MIN_RGB_VALUE);
  // Now just loop through the path, traversing from one point to the next
  for (int i = 0; i < 2*MAX_PATH_SIZE; i++)
    // !! loop index is double what the path index is as it is a nybble index !!
    v1 = v2;
    if (i&1)  // odd number is the second element and ...
      v2 = path[i>>1] & 0xf;  // ... the bottom nybble (index /2) or ...
    else      // ... even number is the first element and ...
      v2 = path[i>>1] >> 4;  // ... the top nybble
    traverse(vertex[v2].x-vertex[v1].x,
             vertex[v2].y-vertex[v1].y,
             vertex[v2].z-vertex[v1].z);
fungus
Ok, I think I see the problem.
With PNP transistors the output will be inverted, ie. The LEDs switch on when the Arduino pin is LOW. This is the opposite of when you connect it directly.
Try changing all your analogWrite(X,Y) to analogWrite(X,255-Y).
kculm
I get a bunch of Code errors .
strykeroz
That shouldn't create any errors. What are you seeing?
kculm
Are  these the three analogWrite I should change
Code: [Select]
strykeroz
kculm
But the Code is v.x ,so I am not sure what to do.
strykeroz
There's a few easy ways to do it.  You can do it in the calculations that construct the values you're outputting, you can change the values you define for the maximum and minimum (and change the direction of your traverse) or you can do it in the analogWrite() like was outlined above:
Code: [Select]
    analogWrite(R_PIN, 255-v.x);
    analogWrite(G_PIN, 255-v.y);
    analogWrite(B_PIN, 255-v.z);
All compiles.  Should work.
Geoff
kculm
And we have a winner.  Works Great.  I have to try to get it to do one more thing.
I am going to try to do it on my own. But will most likely need some help.
Will fill you in soon.
Thanks once more guys
kculm
#44
Mar 03, 2013, 08:22 pm Last Edit: Mar 03, 2013, 08:30 pm by kculm Reason: 1
Ok, I am down to the last piece of the puzzle.
I have now added a switch and  5 more functions.
What I am looking to make it do is ...
At power up all ls off.
Press Button : All RGB on to make white.
Press Button : only RED
Press Button : only Green
Press Button : only Blue
Press Button : Transition.
Press Button : All off.
I got it to work up until the transition.
Once it is in transition mode I cant turn it off.  It also does not Loop once it is in Transition Mode
Now I know it has to do with the Delays in the code, And I looked at the blink with out Delay example to see if I could figure it out, but had no luck.
Code: [Select]
//RGB w/Tarnistion
#define RED 4
#define GREEN 0
#define BLUE 1
#define delayTime 70
int switchPin = 3;
long previousMillis = 0;
long interval = 0;
int val;
int val2;
int buttonState;
int mode = 0;
Marco Colli
April 2012
// Tranistion Setup
#define  MAX_RGB_VALUE  255  // no bigger than 255.
typedef struct
 byte  x, y, z;
coord;
 //x  y  z      name
   0, 0, 0    }
 , // A or 0
   0, 1, 0    }
 , // B or 1
   0, 1, 1    }
 , // C or 2
   0, 0, 1    }
 , // D or 3
   1, 0, 0    }
 , // E or 4
   1, 1, 0    }
 , // F or 5
   1, 1, 1    }
 , // G or 6
   1, 0, 1    }  // H or 7
const byte path[] =
 pinMode(switchPin, INPUT);
 digitalWrite(switchPin, HIGH);
 pinMode(GREEN, OUTPUT);
 pinMode(BLUE, OUTPUT);
 pinMode(RED, OUTPUT);
 digitalWrite(GREEN, HIGH);
 digitalWrite(BLUE, HIGH);
 digitalWrite(RED, HIGH);
 buttonState = digitalRead(switchPin);
void Red(){
 digitalWrite(RED, LOW);
void Green(){
 digitalWrite(GREEN, LOW);
void Blue(){
 digitalWrite(BLUE, LOW);
void White(){
void off(){
   return;
   analogWrite(RED, 255-v.x);
   analogWrite(GREEN, 255-v.y);
   analogWrite(BLUE, 255-v.z);
void RGB()
   v1 = v2;
void loop(){
 val = digitalRead(switchPin);      // read input value and store it in val
 delay(10);                         // 10 milliseconds
 val2 = digitalRead(switchPin);
 if (val == val2){
   if (val != buttonState){
     if (val == LOW){
       if (mode == 0){
         White ();
         mode = 1;
       else if (mode == 1){
         Red();
         mode = 2;
       else if (mode == 2){
         Green();
         mode = 3;
       else if (mode == 3){
         Blue();
         mode = 4;
       else if (mode == 4){
         RGB ();
         mode = 5;
       else if (mode == 5){
         off();
         mode = 0;
     buttonState = val;
