Loading...
Pages: [1]   Go Down
Author Topic: Measuring current from solar panel  (Read 506 times)
Offline Offline
Newbie
View Profile
Hello frnds,
I am using arduino uno and i want to measure the current from the solar panel for my project , i don know what to interface to read the current, and i am newbie to arduino.
Please suggest some ideas ,
The current rating is from 0-5 A DC
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
Put a small value, precision shunt resistor in series with the cell and measure the voltage drop across it.
Logged
Experience, it's what you get when you were expecting something else.
Brisbane, Australia
Offline Offline
God Member
View Profile
I've used a few of the hall effect current sensors from Pololu for this type of thing also.  In a project on a boat I measured solar and generator input as well as total battery discharge using 3 of these modules.  I also use them in my benchtop power supply.  This +/- 5A one based on Allegro ACS714 will give you the best resolution for the range you're measuring.
Cheers ! Geoff
Logged
Offline Offline
Newbie
View Profile
Thank you Afremont and Strykeroz,
To strykeroz : can u also tel me how to design a dc-dc converter , and tell about your solar project , i have to design a solar charge controller,, it will be very useful for me ,
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
Hi
Unfortunately neither of those projects will be too useful to you I think. The bench supply uses an ATX PSU with power broken out to 3v3, 5, 12 and variable posts on the enclosure.  A 20x4 character display outputs the current drawn from each... Plus temperature and a clock since it was already over the top.
The power hub on the boat is really a fuse box and power distribution board with a screen. The solar and outboard power are routed through it before the battery and all battery output goes through it also. This gives a simple indication of total charge or discharge of the battery since reset, instantaneous and cumulative moving average for those statistics... And cabin temperature, because I had extra pins smiley-wink
Geoff
« Last Edit: February 25, 2013, 01:13:54 am by strykeroz » Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Atmel has an application note on battery charging. Starting in section 3.3 they start explaining the voltage and current measuring.
With respect to solar panels Tim Nolan's MPPT design is a must read.
Logged
Offline Offline
Newbie
View Profile
Thanks Chagrin
Those links were so useful smiley
Logged
Offline Offline
Newbie
View Profile
In solar battery charging systems every bit of energy is precious. A current shunt is just throwing away energy. Granted that it is a small amount but, if it can be avoided it should be. The use of a Hall sensor would be my first choice. Search ebay and you will find Hall sensors ranging from 5A to 30A .
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
True, but the first couple of Hall sensors that I checked out used 50mW while operating so you'd have to be careful.
Logged
Pages: [1]   Go Up
Print
Jump to:
