Topic: Fixing USBasp based on ATmega8 (Read 93791 times) previous topic - next topic
pito
naut
http://www.fischl.de/usbasp/
Yep, I've read the readme.txt but it's a bit complicated for me. I've downloaded the usbasp.2011-05-28.tar.gz archive, there is a main.c file, is that the one that I need to load into Arduino IDE?
If I try to use the USBasp as programmer, i.e. in Arduino IDE upload using programmer then I get "avrdude: warning: cannot set sck period. please check for usbasp firmware update.", twice. The readme.txt file states
"- SCK option to support targets with low clock speed (< 1,5MHz)."
So maybe it's not a firmware issue?
Maybe someone here could explain how to do this using avrdude GUI?
http://sourceforge.net/projects/avrdudegui/?source=dlp
hiduino
The "avrdude: warning" can be ignored.  It's just a warning that the programming clock speed is not manually adjustable.  You should be able to program most devices with your current firmware in the USBasp programmer.  The only time you may need to update the firmware is if you want to program AVR devices running below 1 MHz clocking.  Like some ATtiny's running at 128KHz or even down at 16KHz.
Note: the fischl.de firmware is not made for the Arduino IDE.  There is already pre-compiled hex files in the archive file, see \usbasp.2011-05-28\bin\firmware\usbasp.atmega8.2011-05-28.hex.  You will need to use avrdude from commandline to upload.
You need to give the full path for avrdude and it's config file.  Or you can run it from Arduino IDE install path.  I find it easier to run from (If from Windows commandline):
Code: [Select]
C:\> cd C:\Documents and Settings\User\My Documents\arduino-1.0.5\hardware\tools\avr\etc
C:\Documents and Settings\User\My Documents\arduino-1.0.5\hardware\tools\avr\etc>..\bin\avrdude -c arduino -PCOM6 -b19200 -p m8 -v -U flash:w:usbasp.atmega8.2011-05-28.hex
Note: you need to copy the hex file to \arduino-1.0.5\hardware\tools\avr\etc dir.
bperrybap
I get "avrdude" not found when trying to run this. Have I forgotten something?
The directory where avrdude is probably is not on your path.
It is in {installdir}\hardware\tools\avr\bin
--- bill
bperrybap
Actually it means that the programming clock speed is not settable over the USB by avrdude.
USBASP firmware (unless modified) always allows a manual clock speed setting to a slow
clock with a jumper. The newer versions of the firmware also allow setting the clock
speed via USB through a new USBASP command.
(There is discussion about this earlier in this thread)
I have no idea what this comment means:
Quote
I can update sketches or bootloaders using the avrdude commandline or the Arduino GUI
with the latest usbasp f/w.
I use the latest fischel image to allow clock setting from avrdude and I also use a later version of
avrdude than what is supplied by the Arduino team.
(I built the later avrdude myself from the avrdude repository)
The one supplied by the Arduino teams works, but later versions of avrdude have support
to skip over flash areas that don't need to be programmed. When burning a bootloader it
reduces the burn/verify time from a few minutes to 2-3 seconds. It is very noticeable.
I also modified my the fischel f/w so that the leds work slightly differently.
One lights when writing to the AVR and one lights when reading the AVR.
It is kind of neat to see the operation progress but when using the newer avrdude
to burn a bootloader, it is so fast that you don't really see much.
For sketches you have more time to see the operation in progress.
--- bill
hiduino
#50
Jun 11, 2013, 01:55 am Last Edit: Jun 11, 2013, 01:57 am by hiduino Reason: 1
We are talking about the same thing.  When I say "manual", I was referring to the command line option -B.  You can manually specify it (the sck clock speed) in the command line.
Quote
I was responding to @naut, was asking how to build the fischl firmware, main.c in the IDE.
naut
Quote
yep, I've read in other topics that the "avrdude: warning: cannot set sck period. please check for usbasp firmware update" can be ignored, but I've tried to upload the blink sketch to a Atmega48-20pu chip (same pinout as the 328p) and the led doesn't blink.
Quote
I tried it and got this:
naut
Quote
So I could add all the needed header and ccp files to the arduino library, open the main.c file in the IDE, use a 2009 as ISP programmer, hit upload and the firmware would be uploaded to the USBasp?
bperrybap
ah, ok.
The bummer is that the new avrdude attempts to set the clock rate over USB via the new USBASP command
even if the user does not ask for it to be done via -B.
(By default avrdude sends the command just to tell the USBASP device to use its default clock)
That is why the warning shows up.
I consider that misbehavior.
I think that if the user didn't ask for it, avrdude should not attempt to set it and let
the device run with the built in default clock rate inside the f/w.
This would end up using the same clock rate it is using now since by
default, avrdude sends the USBASP command to set the clock rate
just to tell the f/w to use the default rate inside inside it's f/w.
bperrybap
Quote
No.
You need to use the makefile to build the usbasp firmware.
--- bill
hiduino
That is a different problem not caused by the USBasp firmware version.  There could be many other causes for blink sketch not to work.  Especially if you are using a non standard ATmega48.  You need open a new post for this.
As for updating the USBasp firmware, you are in the wrong directory for the instructions.  You should be in the \etc dir and use the relative path for the ..\bin\avrdude.  Look more closely at the details of the instructions.
spam12345
I have purchased several of these Chinese USBasp programmers with the metal case covers.  These are very nicely built.
http://www.ebay.com/itm/New-USB-ISP-USBISP-USBasp-ASP-Programmer-For-51-ATMEL-AVR-WIN7-64-/180937536014?pt=LH_DefaultDomain_0&hash=item2a20b7b20e
You can also get them cheaper in bulk for about $4.00 ea.
http://www.ebay.com/itm/8pcs-lot-Colors-USB-ISP-USBISP-USBasp-ASP-Programmer-for-51-ATMEL-AVR-Download-/160828867138?pt=LH_DefaultDomain_0&hash=item257225c242
They are based on the USBasp circuit design with an Atmega8L.  The problem with these are they do not actually use the USBasp firmware.  They do not work direclty with avrdude.  They emulate an USB HID device so they can install without any Windows drivers.  The catch is they need to use a special Windows GUI (progisp.exe) program to burn AVRs.  They are based on the MX-USBISP-V3.00 2012-05-20 pcb.  See image.
I found that you can reprogram these with the fischl.de usbasp.atmega8.2009-02-28.hex or usbasp.atmega8.2011-05-28.hex firmware and they seem to work great.
1)  They usually have the lock bits set so you will have to erase it first.
2)  Also the back of the pcb have three solder bridges that need to be removed.  See image.
3)  Short the two holes the arrows are pointing from to the UP label.  This is the RESET line for self-programming.
Just a heads up. If anyone get the error like below when using the programmer (after reflashed), it is because the programmer tries to send data too fast.
Code: [Select]
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
This programmer doesn't have the jumper to set the speed. Fortunately, the firmware supports the -B bitclock option which can be used to change the ISP speed. If you use avrdude, just pass the -B parameter like below (the the higher the bitclock, the slower the ISP speed):
Code: [Select]
avrdude -c usbasp -P usb -p m328p -v -B 10
With Arduino IDE, as hiduino have shown me (note there is a semicolon after the bitclock):
There is no direct way to control the programming speed from the IDE.  However, you can configure the defaults in avrdude.conf to slow down the programming.  Just keep in mind this will affect all programming from avrdude.
Look for this line in avrdude.conf (around line 320):
Code: [Select]
# default_bitclock = 2.5;
Remove the comment tag and change it to somewhere around 10 to 20:
Code: [Select]
default_bitclock = 15;
That should slow the programming down enough.
Actually, if you want to be more specific.
For target AVRs down to running at 1MHz you can use:
Code: [Select]
default_bitclock = 3;
For target AVRs down to running at 128KHz you can use:
Code: [Select]
default_bitclock = 32;
Then if you dare go down to 16KHz:
Code: [Select]
default_bitclock = 128;
flurin
#57
Jul 27, 2013, 09:47 am Last Edit: Jul 27, 2013, 10:11 am by flurin Reason: 1
I've recently purchased one of this USBasp, MX-USBISP-V3.00, 2013-03-15.
I also tried setting -B 10 up to 256 but I still got the warning:
Code: [Select]
bperrybap
Code: [Select]
Not surprising. Your device has old firmware.
flurin
Okay. Is there an new version of MX-USBISP or have I to use usbasp.atmega8.2011-05-28.hex?
