Dallas, TX
Offline
Newbie
« on: February 18, 2013, 03:32:00 pm » |
SOLVED video here: https://www.youtube.com/watch?v=GvzXAXBHHrEgoing to integrate it into this computer case: http://www.instructables.com/id/Laser-Cut-Mini-ITX-Case-From-Scratch/Back in the day Be, Inc made a Be Box with two rows of leds that would give a CPU utilization level. I've been playing with my arduino and have duplicated the functionality, except now I can control four banks of LEDs using Dual shift registers (595s), 40 LEDs, and Transistors. I've got the circuit working, and arduino running any light I want (or all for that matter). Can I make the arduino take an input from the main computer and output it onto the LEDs? How would I accomplish this? I have a function that controls the bank, and number of LEDs to be lit, then it shifts in the next bank of data to show the next CPU utilization. Technically I can still have 2 more banks, but I don't have a 6 CPU system... My original guess is it should listen on some serial line, for a set of numbers (bank, number of LEDs to be lit) and then output this... I'm just not sure how this is accomplished using arduino. I got it working by taking in a character on the serial port, then switching it out to the proper configuration of LEDs, I'm sure there's enough keys on the keyboard to make this work. I used the shift PWM RGB example to propel this to glory much faster than I would have been able to on my own (about 30-60 minutes of futzing, no swearing at all) now that I got this working on my mac (haven't gotten everything working yet), I'm going to make it work with haiku (heck, BeOS might also work)...
« Last Edit: February 27, 2013, 04:24:53 pm by alphaseinor »
Logged
Milton Keynes UK
Offline
Tesla Member
« Reply #2 on: February 18, 2013, 10:19:10 pm » |
You would need an application on the PC which calculated the values for the Arduino to display and then sent them to the Arduino in a format the Arduino could understand. Since your total data set is too big to fit in a single byte you need to design a communication protocol that lets you transfer messages. By far the simplest and most robust scheme is to print out ascii text messages delimited by a newline, and parse those in the Arduino to extract the values for display. For example if you only need to transfer a fixed set of numbers, you could encode them as a sequence of comma separated values terminated by a newline.
Logged
Dallas, TX
Offline
Newbie
« Reply #3 on: February 18, 2013, 10:55:21 pm » |
Thanks for the quick replies. Since I'm dealing with 42 bits, I can chop it down to 20 bits, and use a bit for even and odd and that leaves me with 21 bits... the rest is just shifting it out. Depends on the size of the byte? if it's a 32 bit byte, then yes  , 16 bit, then no
Logged
Dallas, TX
Offline
Newbie
« Reply #4 on: February 18, 2013, 11:13:54 pm » |
actually, I would need 2 bits for assigning the led array (4 cpus, 0,1,2,3), and 4 bits for the 10 LEDs to light (0,1,2,3,4,5,6,7,8,9,10)
0000 CPU 1 0001 CPU 2 0010 CPU 3 0011 CPU 4
0000 No Lights 0001 1 LED 0010 2 LED 0011 3 LED 0100 4 LED 0101 5 LED 0110 6 LED 0111 7 LED 1000 8 LED 1001 9 LED 1010 10 LED
CPU 2, 8 LEDs would look something like this 00010010
so that's two octets... one 16 bit byte
Updated so they are not backwards to the uninitiated
« Last Edit: February 20, 2013, 01:06:44 am by alphaseinor »
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #5 on: February 19, 2013, 12:01:51 am » |
your bits are backwards. 00000001 is 1, 00000010 is 2.... If you're bad at bit math you might want to use the ShiftPWM library ( http://www.elcojacobs.com/shiftpwm/)
Logged
Dallas, TX
Offline
Newbie
« Reply #6 on: February 19, 2013, 12:21:43 am » |
Depends on endian... big or little... My MSB is your LSB
or tomato, tomato
Logged
Dallas, TX
Offline
Newbie
« Reply #7 on: February 20, 2013, 01:04:03 am » |
alright, so I've modified my code for the 1 byte "packet" as listed above.
The output on the shift register looks something like this: CPU 2, 8 LEDs (previous example, now with bits not backwards to non geeks) Input: 1000:0010 (08:02) Output to the data pin (clocked in after each data pin is set high for a 1, or low for a 0, then after the whole register is clocked in, it latches the data to the outputs, displaying the LEDs) LED 1 bit: 1 LED 2 bit: 1 LED 3 bit: 1 LED 4 bit: 1 LED 5 bit: 1 LED 6 bit: 1 LED 7 bit: 1 LED 8 bit: 1 LED 9 bit: 0 LED 10 bit: 0 LED (bus 1) 11 bit: 0 LED (bus 2) 12 bit: 1 LED (bus 3) 13 bit: 0 LED (bus 4) 14 bit: 0 Blank Pin 15 bit: 0 Blank Pin 16 bit: 0
I've also added a bucket so if the 4 bits for the LED is 4 or over it just doesn't do anything.
Logged
Dallas, TX
Offline
Newbie
« Reply #8 on: February 26, 2013, 08:28:43 pm » |
Here's what I came up with I used the ShiftPWM library (very nice) as it allows some better control over the light levels // Alphaseinor's Blink program // Uses Teensyduino on a Teensy 2.0++ in it's current form // Used to take a single character to control 40 LEDs // These 40 LEDs are split into 4 sets of 10 LEDs // They are controlled by 2 595 shift registers // 4 sets of LEDs are controlled cathode to ground by NPN Transistors
// The warning from the ShiftPWM library:vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv // Clock and data pins are pins from the hardware SPI, you cannot choose them yourself if you use the hardware SPI. // Data pin is MOSI (Uno and earlier: 11, Leonardo: ICSP 4, Mega: 51, Teensy 2.0: 2, Teensy 2.0++: 22) // Clock pin is SCK (Uno and earlier: 13, Leonardo: ICSP 3, Mega: 52, Teensy 2.0: 1, Teensy 2.0++: 21)
// You can choose the latch pin yourself. const int ShiftPWM_latchPin=8;
// If your LED's turn on if the pin is low, set this to true, otherwise set it to false. const bool ShiftPWM_invertOutputs = false;
// You can enable the option below to shift the PWM phase of each shift register by 8 compared to the previous. // This will slightly increase the interrupt load, but will prevent all PWM signals from becoming high at the same time. // This will be a bit easier on your power supply, because the current peaks are distributed. const bool ShiftPWM_balanceLoad = true;
#include <ShiftPWM.h> // include ShiftPWM.h after setting the pins!
// Here you set the number of brightness levels, the update frequency and the number of shift registers. // These values affect the load of ShiftPWM. // Choose them wisely and use the PrintInterruptLoad() function to verify your load. // There is a calculator on my website to estimate the load.
unsigned char maxBrightness = 50; unsigned char pwmFrequency = 75; int numRegisters = 2; int numRGBleds = numRegisters*8/3;
void setup(){ Serial.begin(9600);
// Sets the number of 8-bit registers that are used. ShiftPWM.SetAmountOfRegisters(numRegisters);
// SetPinGrouping allows flexibility in LED setup. // If your LED's are connected like this: RRRRGGGGBBBBRRRRGGGGBBBB, use SetPinGrouping(4). ShiftPWM.SetPinGrouping(4); //This is the default, but I added here to demonstrate how to use the funtion ShiftPWM.Start(pwmFrequency,maxBrightness); }
void blink(int numberOfLeds, int cpuNumber){ //this outputs to the 595 shift registers the appropriate amount of LEDs //first we set which bank of LEDs we want to use switch(cpuNumber){ //pins 10-13 on the registers use a NPN transistor to pull the LED bus low case 1: ShiftPWM.SetOne(10,maxBrightness); break; case 2: ShiftPWM.SetOne(11,maxBrightness); break; case 3: ShiftPWM.SetOne(12,maxBrightness); break; case 4: ShiftPWM.SetOne(13,maxBrightness); break; default: break; } //Then we light up the number of LEDs that need to be displayed in order to make a single line graph for(int i=0;i<numberOfLeds;i++){ //loops the number of LEDs starting at output 1 ShiftPWM.SetOne(i,maxBrightness); //sets 1 LED at a time in the loop } }
void loop() { if (Serial.available()) { // if serial data is present char c = (char)Serial.read(); //note loop does not end here because it needs to switch 'c' ShiftPWM.SetAll(0); //this changes all of the sates back to off on every loop so we don't get cross talk on the different LED Banks switch (c){ // This is the switch for us to use the blink function // A-K for CPU 1 // L-V for CPU 2 // a-k for CPU 3 // l-v for CPU 4 // 0 turns off LEDs // 1-9 Sets Brightness of LEDs case 'A': //LED Row 1, No LEDs Showing break; case 'B': //LED Row 1, 1 LEDs Showiing blink(1, 1); break; case 'C': //LED Row 1, 2 LEDs Showing blink(2, 1); break; case 'D': //LED Row 1, 3 LEDs Showing blink(3, 1); break; case 'E': //LED Row 1, 4 LEDs Showing blink(4, 1); break; case 'F': //LED Row 1, 5 LEDs Showing blink(5, 1); break; case 'G': //LED Row 1, 6 LEDs Showing blink(6, 1); break; case 'H': //LED Row 1, 7 LEDs Showing blink(7, 1); break; case 'I': //LED Row 1, 8 LEDs Showing blink(8, 1); break; case 'J': //LED Row 1, 9 LEDs Showing blink(9, 1); break; case 'K': //LED Row 1, 10 LEDs Showing blink(10, 1); break; case 'L': //LED Row 2, No LEDs Showing break; case 'M': //LED Row 2, 1 LEDs Showiing blink(1, 2); break; case 'N': //LED Row 2, 2 LEDs Showing blink(2, 2); break; case 'O': //LED Row 2, 3 LEDs Showing blink(3, 2); break; case 'P': //LED Row 2, 4 LEDs Showing blink(4, 2); break; case 'Q': //LED Row 2, 5 LEDs Showing blink(5, 2); break; case 'R': //LED Row 2, 6 LEDs Showing blink(6, 2); break; case 'S': //LED Row 2, 7 LEDs Showing blink(7, 2); break; case 'T': //LED Row 2, 8 LEDs Showing blink(8, 2); break; case 'U': //LED Row 2, 9 LEDs Showing blink(9, 2); break; case 'V': //LED Row 2, 10 LEDs Showing blink(10, 2); break; case 'a': //LED Row 3, No LEDs Showing break; case 'b': //LED Row 3, 1 LEDs Showiing blink(1, 3); break; case 'c': //LED Row 3, 2 LEDs Showing blink(2, 3); break; case 'd': //LED Row 3, 3 LEDs Showing blink(3, 3); break; case 'e': //LED Row 3, 4 LEDs Showing blink(4, 3); break; case 'f': //LED Row 3, 5 LEDs Showing blink(5, 3); break; case 'g': //LED Row 3, 6 LEDs Showing blink(6, 3); break; case 'h': //LED Row 3, 7 LEDs Showing blink(7, 3); break; case 'i': //LED Row 3, 8 LEDs Showing blink(8, 3); break; case 'j': //LED Row 3, 9 LEDs Showing blink(9, 3); break; case 'k': //LED Row 3, 10 LEDs Showing blink(10, 3); break; case 'l': //LED Row 4, No LEDs Showing break; case 'm': //LED Row 4, 1 LEDs Showiing blink(1, 4); break; case 'n': //LED Row 4, 2 LEDs Showing blink(2, 4); break; case 'o': //LED Row 4, 3 LEDs Showing blink(3, 4); break; case 'p': //LED Row 4, 4 LEDs Showing blink(4, 4); break; case 'q': //LED Row 4, 5 LEDs Showing blink(5, 4); break; case 'r': //LED Row 4, 6 LEDs Showing blink(6, 4); break; case 's': //LED Row 4, 7 LEDs Showing blink(7, 4); break; case 't': //LED Row 4, 8 LEDs Showing blink(8, 4); break; case 'u': //LED Row 4, 9 LEDs Showing blink(9, 4); break; case 'v': //LED Row 4, 10 LEDs Showing blink(10, 4); break; case '0': maxBrightness = 0; break; case '1': maxBrightness = 25; break; case '2': maxBrightness = 50; break; case '3': maxBrightness = 75; break; case '4': maxBrightness = 100; break; case '5': maxBrightness = 125; break; case '6': maxBrightness = 150; break; case '7': maxBrightness = 175; break; case '8': maxBrightness = 200; break; case '9': maxBrightness = 225; break; default: break; } } }
Now on to programming that arduino driver for www.Haiku-OS.org haven't even seen if someone else has done it for me.
Logged
Dallas, TX
Offline
Newbie
« Reply #9 on: February 27, 2013, 01:48:46 pm » |
Added a demo code to when the device starts up, just a random number generator... it's in the bottom else in main video here: https://www.youtube.com/watch?v=GvzXAXBHHrEgoing to integrate it into this computer case: http://www.instructables.com/id/Laser-Cut-Mini-ITX-Case-From-Scratch/// Alphaseinor's Blink program // Uses Teensyduino on a Teensy 2.0++ in it's current form // Used to take a single character to control 40 LEDs // These 40 LEDs are split into 4 sets of 10 LEDs // They are controlled by 2 595 shift registers // 4 sets of LEDs are controlled cathode to ground by NPN Transistors
unsigned char maxBrightness = 50; unsigned char pwmFrequency = 75; int numRegisters = 2; int numCPUs = 4; int numLeds = 10;
void loop() { if (Serial.available()) { // if serial data is present char c = (char)Serial.read(); //note loop does not end here because it needs to switch 'c' ShiftPWM.SetAll(0); //this changes all of the sates back to off on every loop so we don't get cross talk on the different LED Banks switch (c){ // This is the switch for us to use the blink function // A-K for CPU 1 // L-V for CPU 2 // a-k for CPU 3 // l-v for CPU 4 // 0 turns off LEDs // 1-9 Sets Brightness of LEDs case 'A': //LED Row 1, No LEDs Showing break; case 'B': //LED Row 1, 1 LEDs Showiing blink(1, 1); break; case 'C': //LED Row 1, 2 LEDs Showing blink(2, 1); break; case 'D': //LED Row 1, 3 LEDs Showing blink(3, 1); break; case 'E': //LED Row 1, 4 LEDs Showing blink(4, 1); break; case 'F': //LED Row 1, 5 LEDs Showing blink(5, 1); break; case 'G': //LED Row 1, 6 LEDs Showing blink(6, 1); break; case 'H': //LED Row 1, 7 LEDs Showing blink(7, 1); break; case 'I': //LED Row 1, 8 LEDs Showing blink(8, 1); break; case 'J': //LED Row 1, 9 LEDs Showing blink(9, 1); break; case 'K': //LED Row 1, 10 LEDs Showing blink(10, 1); break; case 'L': //LED Row 2, No LEDs Showing break; case 'M': //LED Row 2, 1 LEDs Showiing blink(1, 2); break; case 'N': //LED Row 2, 2 LEDs Showing blink(2, 2); break; case 'O': //LED Row 2, 3 LEDs Showing blink(3, 2); break; case 'P': //LED Row 2, 4 LEDs Showing blink(4, 2); break; case 'Q': //LED Row 2, 5 LEDs Showing blink(5, 2); break; case 'R': //LED Row 2, 6 LEDs Showing blink(6, 2); break; case 'S': //LED Row 2, 7 LEDs Showing blink(7, 2); break; case 'T': //LED Row 2, 8 LEDs Showing blink(8, 2); break; case 'U': //LED Row 2, 9 LEDs Showing blink(9, 2); break; case 'V': //LED Row 2, 10 LEDs Showing blink(10, 2); break; case 'a': //LED Row 3, No LEDs Showing break; case 'b': //LED Row 3, 1 LEDs Showiing blink(1, 3); break; case 'c': //LED Row 3, 2 LEDs Showing blink(2, 3); break; case 'd': //LED Row 3, 3 LEDs Showing blink(3, 3); break; case 'e': //LED Row 3, 4 LEDs Showing blink(4, 3); break; case 'f': //LED Row 3, 5 LEDs Showing blink(5, 3); break; case 'g': //LED Row 3, 6 LEDs Showing blink(6, 3); break; case 'h': //LED Row 3, 7 LEDs Showing blink(7, 3); break; case 'i': //LED Row 3, 8 LEDs Showing blink(8, 3); break; case 'j': //LED Row 3, 9 LEDs Showing blink(9, 3); break; case 'k': //LED Row 3, 10 LEDs Showing blink(10, 3); break; case 'l': //LED Row 4, No LEDs Showing break; case 'm': //LED Row 4, 1 LEDs Showiing blink(1, 4); break; case 'n': //LED Row 4, 2 LEDs Showing blink(2, 4); break; case 'o': //LED Row 4, 3 LEDs Showing blink(3, 4); break; case 'p': //LED Row 4, 4 LEDs Showing blink(4, 4); break; case 'q': //LED Row 4, 5 LEDs Showing blink(5, 4); break; case 'r': //LED Row 4, 6 LEDs Showing blink(6, 4); break; case 's': //LED Row 4, 7 LEDs Showing blink(7, 4); break; case 't': //LED Row 4, 8 LEDs Showing blink(8, 4); break; case 'u': //LED Row 4, 9 LEDs Showing blink(9, 4); break; case 'v': //LED Row 4, 10 LEDs Showing blink(10, 4); break; case '0': maxBrightness = 0; break; case '1': maxBrightness = 25; break; case '2': maxBrightness = 50; break; case '3': maxBrightness = 75; break; case '4': maxBrightness = 100; break; case '5': maxBrightness = 125; break; case '6': maxBrightness = 150; break; case '7': maxBrightness = 175; break; case '8': maxBrightness = 200; break; case '9': maxBrightness = 225; break; default: break; } } else { //startup routine for(int cpu=1;cpu<numCPUs+1;cpu++){ for(int led=0;led<numLeds+1;led++){ if (Serial.available()){break;} blink(random(led),cpu); delay(10); ShiftPWM.SetAll(0); } } } }
« Last Edit: February 27, 2013, 04:23:30 pm by alphaseinor »
Logged
Dallas, TX
Offline
Newbie
« Reply #10 on: February 27, 2013, 05:23:28 pm » |
changed the code to have the 10 anodes loop last, and the 4 cathodes loop first... this reduces the CPU flicker on the leds. drop the delay to 4 and the flicker goes away completely. still working on the haiku driver... i'll post it here when I'm done. // Alphaseinor's Blink program // Uses Teensyduino on a Teensy 2.0++ in it's current form // Used to take a single character to control 40 LEDs // These 40 LEDs are split into 4 sets of 10 LEDs // They are controlled by 2 595 shift registers // 4 sets of LEDs are controlled cathode to ground by NPN Transistors
unsigned char maxBrightness = 255; unsigned char pwmFrequency = 75; int numRegisters = 2; int numCPUs = 4; int numLeds = 10;
void loop() { if (Serial.available()) { // if serial data is present char c = (char)Serial.read(); //note loop does not end here because it needs to switch 'c' ShiftPWM.SetAll(0); //this changes all of the sates back to off on every loop so we don't get cross talk on the different LED Banks switch (c){ // This is the switch for us to use the blink function // A-K for CPU 1 // L-V for CPU 2 // a-k for CPU 3 // l-v for CPU 4 // 0 turns off LEDs // 1-9 Sets Brightness of LEDs case 'A': //LED Row 1, No LEDs Showing break; case 'B': //LED Row 1, 1 LEDs Showiing blink(1, 1); break; case 'C': //LED Row 1, 2 LEDs Showing blink(2, 1); break; case 'D': //LED Row 1, 3 LEDs Showing blink(3, 1); break; case 'E': //LED Row 1, 4 LEDs Showing blink(4, 1); break; case 'F': //LED Row 1, 5 LEDs Showing blink(5, 1); break; case 'G': //LED Row 1, 6 LEDs Showing blink(6, 1); break; case 'H': //LED Row 1, 7 LEDs Showing blink(7, 1); break; case 'I': //LED Row 1, 8 LEDs Showing blink(8, 1); break; case 'J': //LED Row 1, 9 LEDs Showing blink(9, 1); break; case 'K': //LED Row 1, 10 LEDs Showing blink(10, 1); break; case 'L': //LED Row 2, No LEDs Showing break; case 'M': //LED Row 2, 1 LEDs Showiing blink(1, 2); break; case 'N': //LED Row 2, 2 LEDs Showing blink(2, 2); break; case 'O': //LED Row 2, 3 LEDs Showing blink(3, 2); break; case 'P': //LED Row 2, 4 LEDs Showing blink(4, 2); break; case 'Q': //LED Row 2, 5 LEDs Showing blink(5, 2); break; case 'R': //LED Row 2, 6 LEDs Showing blink(6, 2); break; case 'S': //LED Row 2, 7 LEDs Showing blink(7, 2); break; case 'T': //LED Row 2, 8 LEDs Showing blink(8, 2); break; case 'U': //LED Row 2, 9 LEDs Showing blink(9, 2); break; case 'V': //LED Row 2, 10 LEDs Showing blink(10, 2); break; case 'a': //LED Row 3, No LEDs Showing break; case 'b': //LED Row 3, 1 LEDs Showiing blink(1, 3); break; case 'c': //LED Row 3, 2 LEDs Showing blink(2, 3); break; case 'd': //LED Row 3, 3 LEDs Showing blink(3, 3); break; case 'e': //LED Row 3, 4 LEDs Showing blink(4, 3); break; case 'f': //LED Row 3, 5 LEDs Showing blink(5, 3); break; case 'g': //LED Row 3, 6 LEDs Showing blink(6, 3); break; case 'h': //LED Row 3, 7 LEDs Showing blink(7, 3); break; case 'i': //LED Row 3, 8 LEDs Showing blink(8, 3); break; case 'j': //LED Row 3, 9 LEDs Showing blink(9, 3); break; case 'k': //LED Row 3, 10 LEDs Showing blink(10, 3); break; case 'l': //LED Row 4, No LEDs Showing break; case 'm': //LED Row 4, 1 LEDs Showiing blink(1, 4); break; case 'n': //LED Row 4, 2 LEDs Showing blink(2, 4); break; case 'o': //LED Row 4, 3 LEDs Showing blink(3, 4); break; case 'p': //LED Row 4, 4 LEDs Showing blink(4, 4); break; case 'q': //LED Row 4, 5 LEDs Showing blink(5, 4); break; case 'r': //LED Row 4, 6 LEDs Showing blink(6, 4); break; case 's': //LED Row 4, 7 LEDs Showing blink(7, 4); break; case 't': //LED Row 4, 8 LEDs Showing blink(8, 4); break; case 'u': //LED Row 4, 9 LEDs Showing blink(9, 4); break; case 'v': //LED Row 4, 10 LEDs Showing blink(10, 4); break; case '0': maxBrightness = 0; break; case '1': maxBrightness = 25; break; case '2': maxBrightness = 50; break; case '3': maxBrightness = 75; break; case '4': maxBrightness = 100; break; case '5': maxBrightness = 125; break; case '6': maxBrightness = 150; break; case '7': maxBrightness = 175; break; case '8': maxBrightness = 200; break; case '9': maxBrightness = 225; break; default: break; } } else { //startup routine for(int led=1;led<numLeds+1;led++){ for(int cpu=0;cpu<numCPUs+1;cpu++){ if (Serial.available()){break;} blink(random(led),cpu); delay(5); ShiftPWM.SetAll(0); } } } }
Logged
