Loading...
Pages: [1]   Go Down
Author Topic: Need some help with subroutine * RESOLVED*  (Read 155 times)
Offline Offline
Newbie
View Profile
Hello all,
I have some code that I need help with.  It seems that the subroutine that I created for updating my time and date bar is not functioning correctly.  When the subroutine is called from the Setup loop, it runs correctly and populates the data.  However when it is called from the main loop, it never executes.  I have added a bunch of Serial.prints to try and help troubleshoot it.  Here is the code.  Please let me know if you need more information or what a possible solution might be.  I cant include all the code as its over the maximum allow length for a single post.  So here are the subroutine I am calling, the setup loop, and the main loop.
Subroutine being called
Code:
//--------------------------------- Time and Date Bar ------------------------------------//
void TimeDateBar()  //This needs to be updated once RTC is connected
  String time, minute, hour,ampm;
  myGLCD.setColor (0,0,255);
  myGLCD.fillRect (0, 0, 319, 18);
  Serial.print ("t.hour entering Sub = ");
  Serial.println (t.hour,DEC);
    //Pad minute with 0 if necessary
if ((t.min >= 0) && (t.min <= 9))
      minute = "0" + String(t.min);
      minute = String(t.min);
Serial.print ("t.min = ");
Serial.println (t.min,DEC);
Serial.print ("minute = ");
Serial.println (minute);
//Figure out hour
if (t.hour == 0)
 hour = "12";
else if (t.hour > 12)
hour = String(t.hour - 12);
hour = String(t.hour);
Serial.print ("t.hour after adjustment = ");
Serial.print ("hour after adjustment = ");
Serial.println (hour);
//Determin AM or PM
if (t.hour < 12)
ampm = " AM";
ampm = " PM";
Serial.print ("ampm after adjustment = ");
Serial.println (ampm);
    time = hour + ":" + minute + ampm;
Serial.println ("Time is " + time);
    setFont(LARGE,255,255,255,0,0,255);
UpdateTandDBar = 0;
    myGLCD.print(time, RIGHT, 1);
    myGLCD.print(rtc.getDateStr(FORMAT_LONG,FORMAT_MIDDLEENDIAN,'/'),LEFT,1);
Serial.println ("-----------");
And the setup and main loop
Code:
//--------------------------------------- Setup ------------------------------------------//
  Serial.begin (9600);
  // Initial setup
  pinMode(RenaFiltPin, OUTPUT);
  pinMode(SunFiltPin, OUTPUT);
  pinMode(MainLtPin, OUTPUT);
  pinMode(MoonLtPin, OUTPUT);
  pinMode(HeaterPin, OUTPUT);
  pinMode(CO2Pin, OUTPUT);
  pinMode(DosePmp1Pin, OUTPUT);
  pinMode(DosePmp2Pin, OUTPUT);
  digitalWrite(RenaFiltPin, HIGH);
  digitalWrite(SunFiltPin, HIGH);
  digitalWrite(MainLtPin, HIGH);
  digitalWrite(MoonLtPin, HIGH);
  digitalWrite(HeaterPin, HIGH);
  digitalWrite(CO2Pin, HIGH);
  digitalWrite(DosePmp1Pin, HIGH);
  digitalWrite(DosePmp2Pin, HIGH);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  sensors.begin();     //start up temperature library
  // set the resolution to 9 bit
  sensors.setResolution(HoodTempSen, 9);
  sensors.setResolution(WaterTempSen, 9);
  t = rtc.getTime();
  checkTemp();
  TimeDateBar();
  mainScreen(true);
//------------------------------------- Main Loop ----------------------------------------//
  if (myTouch.dataAvailable())
    processMyTouch();
  if ((currentMillis - prevMillis30 >= 30000) || (UpdateTandDBar))    //Update Time every 30 Seconds
    prevMillis30 = currentMillis;
    //checkTemp();
    if (dispScreen == 0)
      mainScreen(false);
    // Get data from the DS1307
    t = rtc.getTime();
    //delay(50);
Serial.println ("Entering Sub");
TimeDateBar();
    //checkMainLt();
Thanks,
Grimm
« Last Edit: February 18, 2013, 10:11:38 pm by Grimnokk » Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
Where and how is 'prevMillis30' declared, UpdateTandDBar = 0 so the if is probably never entered.
Logged
Offline Offline
Newbie
View Profile
They are declared in the beginning.  As I said, all of my code can not be posted because it is above the maximum allowed characters for a post.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Please note that, at present, the String library has bugs as discussed here and here.
In particular, the dynamic memory allocation used by the String class may fail and cause random crashes.
I recommend reworking your code to manage without String. Use C-style strings instead (strcpy, strcat, strcmp, etc.).
Alternatively, install the fix described here:
  http://arduino.cc/forum/index.php/topic,145765
Quote
You can do attachments.
How to use this forum
Logged
Offline Offline
Newbie
View Profile
Quote
Thank you Nick for the reply.  I will look into redoing the code to make it work.
As a side note, I have paired down this code to isolate just where I am having a problem.
Here is the new code:
Code:
#include <UTFT.h>
#include <UTouch.h>
#include <EEPROM.h>
#include <writeAnything.h>
#include <DS1307.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//TOUCH PANEL and TFT MEGA SHIELD V2.0
//(Mega Shield utilizes pins 5V, 3V3, GND, 2-6 (Touch Control), 22-41 (LCD), & (50-53 for SD Card))
UTFT        myGLCD(TFT01_32, 38,39,40,41);
UTouch      myTouch(6,5,4,3,2);
// Init the DS1307
DS1307  rtc(8, 9);
//Declare which fonts to be utilized
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
#define LARGE true
#define SMALL false
// Init a Time-data structure
Time  t, tSet;
byte UpdateTandDBar;
unsigned long prevMillis30 = 0;
//------------------------------------- Set Font -----------------------------------------//
void setFont(boolean font, byte cr, byte cg, byte cb, byte br, byte bg, byte bb)
  myGLCD.setBackColor(br, bg, bb);               //font MenuBtnground black
  myGLCD.setColor(cr, cg, cb);                   //font color white
  if (font==LARGE)
    myGLCD.setFont(BigFont);                     //font size LARGE
  else if (font==SMALL)
    myGLCD.setFont(SmallFont);
  String time = "", minute = "", hour = "",ampm = "";
  //Figure out hour
  if (t.hour == 0)
    hour = "12";
  //Determin AM or PM
  if (t.hour < 12)
    ampm = " AM";
    ampm = " PM";
  UpdateTandDBar = 0;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  t = rtc.getTime();
  TimeDateBar();
    t = rtc.getTime();
    delay(10);
    TimeDateBar();
and the serial output:
Code:
t.hour entering Sub = 17
t.min = 54
minute = 54
t.hour after adjustment = 17
hour after adjustment = 5
ampm after adjustment =  PM
Time is 5:54 PM
Entering Sub
t.min = 54
minute = 54
so the upper part of the serial output would be the call from the setup loop.  The bottom part is the subroutine call.
Logged
Canada
Offline Offline
Newbie
View Profile
Not sure what your other codes are doing, but if you are using Timers or Interupts that would kill your ability to use millis()
Logged
Offline Offline
Newbie
View Profile
Thanks again Nick.  The string fix appears to have resolved the issue.
Logged
Pages: [1]   Go Up
Print
Jump to:
