Loading...
Pages: [1]   Go Down
Author Topic: Moving from the uno to programming AVRs. Please recommend  (Read 3078 times)
Offline Offline
Full Member
View Profile
I'm about to go from programming an UNO to programming ATmega chips (not sure which yet, but probably 4-8k variety up to 20MHz) to use in some prototypes.  I am not at all sure how to program chips outside of the one that is installed on the UNO.  Can someone make some recommendations?  Do I need to purchase something from ATMEL?  Can I use the UNO board itself?  If I need to purchase something, my budget is $50 USD.
Thanks,
memotick
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You will need a programmer like the AVRisp Mk2 (ATmega chips don't come with bootloaders) and you should download the free AVRstudio from Atmel.  For help you can go to the AVRfreaks forums.  The programming will be similar to Arduino programming without the Arduino core and libraries (no digitalWrite, analogRead, millis, etc).
Logged
Nova Scotia
Offline Offline
Full Member
View Profile
WWW
I'm did exactly that and made a little tutorial up along the way to help others. It was actually easier then what I was expecting. That never happens: https://sites.google.com/site/0miker0/Designing-your-custom-Arduino-Board
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
What are the "4-8K variety"?
I've used ATtiny85, ATTiny84, and ATMega328 and always with ArduinoISP. Never had any problems.
Logged
Belgium
Offline Offline
Edison Member
Arduino rocks; but with my plugin it can fly rocking the world ;-)
View Profile
WWW
As you have a Arduino you can also use arduinoisp.
Best regards
Jantje
Logged
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
 As others have said, you can certainly use your existing Uno board as a AVR programmer using the arduinoISP sketch. If you do want a standalone programmer here is one that works with AVRDUDE and also directly works with the arduino IDE and is quite affordable. Got one earlier in the week and it functions fine.
http://www.hobbyking.com/hobbyking/store/__21321__USBasp_AVR_Programming_Device_for_ATMEL_proccessors.html?strSearch=USBasp
Lefty
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
Lefty
Thanks for the link. I'm thinking about getting 1 (or more). To me (and you) they are quite affordable but it still is 10% of the budget of OP.  smiley-twist
Best regards
Jantje
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You can get them direct from Hong Kong for just under $4 (including free shipping).  Just search eBay for "USBasp".  Note that they usually come with only a 10-pin cable.  To use them with an Arduino you will need to adapt them to the 6-pin connector.  You can find 10-pin to 6-pin adapters on eBay but they will cost another $4 so someone on a tight budget might want to fabricate their own cable.
Logged
Offline Offline
Brattain Member
View Profile
Yes, that's why I bought the one I listed as it's cable has both 10 and 6 pin female connectors on it. Saved needing to buy the converter adapter.
Lefty
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
4$ is 8% of 50$
With a tight budget like this you need to use what you have in house. So I advice start with arduino isp and a good breadboard.
That said; 50$ is really tight (in the western world) to learn a new technology so it probably will not be sufficient if there are no free resources around (like a school lab).
I don't know much from the hardware side.
From the software side : If you like/know eclipse the paths Arduino IDE -> arduino eclipse plugin -> avr eclipse  could be a good path and it is 100% free.
If you're not into eclipse you're probably best looking into the free AVRstudio from Atmel.
Best regards
Jantje
Logged
Westbrook, CT
Offline Offline
Full Member
"Why should I bother with made-up games when there are so many real ones going on." (c) Kurt Vonnegut
View Profile
WWW
Here is an awesome guide on how to program little Atmel chips:
http://hlt.media.mit.edu/?p=1695
Another Tutorial:
http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
Logged
Arduino Uno R3
Mac OSX Lion
Pages: [1]   Go Up
Print
Jump to:
