Topic: RF transmitters/receivers to turn audio file on Wave Module V1.0 ON/OFF (Read 5023 times) previous topic - next topic
3LFM4N
Hi guys, I am a complete beginner to arduino..
I've bought two low cost RF transmitters and a receiver, and I was hoping to use a set up where one transmitter would turn on a looped voice message stored on a wave shield to play every 5 seconds..
and then the signal from the other transmitter would turn this off.
How would I go about doing this? :smiley-eek-blue:
Thank you
Erdin
How cheap ?
Did you buy those very cheap 433MHz ?
A library called "VirtualWire" is very good with those modules.
http://www.open.com.au/mikem/arduino/VirtualWire/
3LFM4N
Erdin
This movie is very useful, http://www.youtube.com/watch?v=e8RhXtst7ME
3LFM4N
guys I have bought a wave module V1.0 to play the sound:
http://www.ebay.com/itm/Wave-Sound-Shield-Module-V1-0-Arduino-Compatible-/270941553333?ssPageName=ADME:L:OC:GB:3160
But I can't get it to work, I have no idea how to code it.
What do I need to write if I only want it to play 1 file on a loop????
Erdin
You have version 1.
This is for version 2:
http://www.emartee.com/product/42147/Wave%20Shield%20V2.0
http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=168_170&products_id=2161
But I think the software for both is the same.
Someone else asked about the wave shield, http://arduino.cc/forum/index.php/topic,152453.0.html
Please don't cross-post.
http://arduino.cc/forum/index.php/topic,152958.msg1147431.html
Now I am reading you already have the code.
3LFM4N
Sorry about the cross-post.
As the file I want to loop is just a voice command, I decided to repeat it multiple times with the pauses in between for a surplus duration of what I require at this site:
http://www2.research.att.com/~ttsweb/tts/demo.php
This eradicates the need to programme it to loop and so now I simply need to turn the file ON or OFF via 2 RF transmitters and 1 receiver.
The video you posted was really helpful and I hope to adapt the receiver code. 1 transmitter will be dedicated to turning it ON, the other OFF, each transmitter will be coupled with an Encoder and a tilt switch.
Here is the code I'm using to play the Wave Module:
int RST = 3;
int CLK = A5;
int DAT = A4;
    pinMode(RST, OUTPUT);
    pinMode(CLK, OUTPUT);
    pinMode(DAT, OUTPUT);
    digitalWrite(RST, HIGH);
    digitalWrite(CLK, HIGH);
    digitalWrite(DAT, HIGH);
    digitalWrite(RST, LOW);
    delay(5);
    delay(300);
  send(0x0000);//play file 0000
  delay(10000);//delay 10 seconds
  send(0xfff0);//set voice volumn to 0 (turn off)
  delay(3000);
  send(0xfff4);//set voice volumn to 4
  delay(3000);
  send(0xfff7);//set voice volumn to 7
  delay(3000);
  send(0xfffe);// pause
  delay(5000);
  send(0xfffe);//play
  while(1);
void send(int data)
  digitalWrite(CLK, LOW);
  delay(2);
  for (int i=15; i>=0; i--)
    delayMicroseconds(50);
    if((data>>i)&0x0001 >0)
        //Serial.print(1);
         digitalWrite(DAT, LOW);
        // Serial.print(0);
    if(i>0)
    if(i>0)
  delay(20);
However I don't know how I would combine the two codes for what I require :S
