Loading...
Pages: [1]   Go Down
Author Topic: HTML Causing Arduino To Crash  (Read 261 times)
Offline Offline
Newbie
View Profile
Hi all,
I've been working on some basic HTML pin controls as a mini project to learn Ethernet side of Arduino but I keep getting stuck....
The following lines always crash the Arduino and make it restart.
Code:
//         client.print("<form method=get>");
//                                  client.print("<input type='radio' name=r2 value='1'");
//         if (digitalRead(2) == 1) client.print(" checked");
//                                  client.print("> Relay 2<br>");
//         client.print("<input type='radio' name=r value='2' checked> Two<br>");
//         client.print("<input type='radio' name=r value='3'> Three<br>");
//         client.print("</form>");
Even leaving out the 3 that make up the if statement and just using the following line does the same..
Code:
If I replace with...
Code:
         client.print("<br>");
         client.print("Test Text");
It works fine, just not with the form HTML.
Full code attached.
Any ideas?
Logged
UK
Offline Offline
Tesla Member
View Profile
Perhaps you're running out of RAM. All those strings will be occupying RAM, and there is only a tiny amount available. Without seeing the whole sketch (hint!) or knowing what hardware you're using (hint, hint!) it's impossible to do more than guess, but that would be my guess. You avoid those strings using RAM by defining them as PROGMEM values.
Logged
NE PA
Offline Offline
Full Member
View Profile
WWW
You probably need to escape the single quotes like this:
Code:
client.print("<input type=\'radio\' name=r value=\'3\'> Three<br>");
Logged
Offline Offline
Newbie
View Profile
Thanks both for the quick replies smiley
Quick5pnt0 - No such luck does the same  smiley-cry
PeterH - You might be right, 1 line of code seems to cause a restart when I try to access the device. Whereas multiple lines of code just cause it to reboot instantaneously. I'm pretty new to this so will look up what you mean by PROGMEM tomorrow after I've got some sleep and have more patience.
PS Its an UNO and the full code is attached to the original post.
Thanks again  smiley
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
Hint: it is a PITA to download code when it can be posted in a code box.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
Zoomkat - I tried but it was too long smiley-sad I could try stripping out what I few as the "unimportant" code when I get home from work.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Use the F() function to keep those static strings in program memory.
Code:
client.print(F("<form method=get>"));
Do the same to the rest of those strings, and that should save you a lot of SRAM.
Logged
Pages: [1]   Go Up
Print
Jump to:
