Topic: HTML Causing Arduino To Crash (Read 2003 times) previous topic - next topic
dan_miles86
Hi all,
I've been working on some basic HTML pin controls as a mini project to learn Ethernet side of Arduino but I keep getting stuck....
The following lines always crash the Arduino and make it restart.
//         client.print("<form method=get>");
//                                  client.print("<input type='radio' name=r2 value='1'");
//         if (digitalRead(2) == 1) client.print(" checked");
//                                  client.print("> Relay 2<br>");
//         client.print("<input type='radio' name=r value='2' checked> Two<br>");
//         client.print("<input type='radio' name=r value='3'> Three<br>");
//         client.print("</form>");
Even leaving out the 3 that make up the if statement and just using the following line does the same..
If I replace with...
         client.print("<br>");
         client.print("Test Text");
It works fine, just not with the form HTML.
Full code attached.
Any ideas?
PeterH
Perhaps you're running out of RAM. All those strings will be occupying RAM, and there is only a tiny amount available. Without seeing the whole sketch (hint!) or knowing what hardware you're using (hint, hint!) it's impossible to do more than guess, but that would be my guess. You avoid those strings using RAM by defining them as PROGMEM values.
Quick5pnt0
You probably need to escape the single quotes like this:
client.print("<input type=\'radio\' name=r value=\'3\'> Three<br>");
dan_miles86
Thanks both for the quick replies :)
Quick5pnt0 - No such luck does the same  =(
PeterH - You might be right, 1 line of code seems to cause a restart when I try to access the device. Whereas multiple lines of code just cause it to reboot instantaneously. I'm pretty new to this so will look up what you mean by PROGMEM tomorrow after I've got some sleep and have more patience.
PS Its an UNO and the full code is attached to the original post.
Thanks again  :)
zoomkat
Hint: it is a PITA to download code when it can be posted in a code box.
dan_miles86
Zoomkat - I tried but it was too long :( I could try stripping out what I few as the "unimportant" code when I get home from work.
SurferTim
Use the F() function to keep those static strings in program memory.
client.print(F("<form method=get>"));
Do the same to the rest of those strings, and that should save you a lot of SRAM.
