Topic: Talon Speed Controller (Read 4881 times) previous topic - next topic
Soapy29
Hello everyone. Me and a friend were thinking about building a robot, and I was just wondering if the Talon Speed Controller's would work good with Arduino. We were also wondering about the Victor 888, and the Jaguar controllers.
Link to:
Jaguar Motor Controller
Victor 888 Motor Controller
Soapy29
Or would there be any way of getting a Tetrix DC Motor Controller working with Arduino? I am pretty sure they work with I2C, and reading on the Playground a bit, the Uno R3 has I2C. We have a bunch of the Tetrix motor controllers, so if we could get those working, that would be awesome!
kIlla2
#2
Apr 14, 2013, 07:47 pm Last Edit: Apr 14, 2013, 08:07 pm by kIlla2 Reason: 1
I've got a Talon working with my Leonardo using the servo Sweep example. I also tried it with the Jaguar with much success! You may need to calibrate the speed controller but to do that you must write a code which sets the limits for a little over one second each. Here's the calibration loop I used:
Quote
 servo.write(180);
 delay(1500);
 servo.write(0);
 delay(1500);
This is assuming your servo object is named "servo," of course.
Let me know how this works out.
PS: also, does anyone know how to input something like a USB joystick and read an axis with the arduino?
Soapy29
Thanks for confirming that the Talon and the Jaguar controllers work with Arduino. I kind of figured they would, as well as Victors.
kIlla2
De nada! I haven't tried a victor yet but I figure with the right calibration, they'd work as well.
Soapy29
Arn't these controllers just PWM?
kIlla2
Yes, but they're all a special frequency of PWM. Using the default PWM for arduino, analogWrite, the arduino gives out a 50hz PWM signal but the controllers accept something around 150hz. The servos use the same frequency so the libraries work great with the controllers.
StevenBills
hey so you said you can just use the servo library. how would you control speeds of a motor using a servo library? how does that work?
