Loading...
Pages: [1]   Go Down
Author Topic: [SOLVED] Roomba From PRONTO CODE to IR Emitter (IR LED + RAWCODE + ARDUINO)  (Read 381 times)
italy
Offline Offline
Newbie
View Profile
Hi to all,
I'm trying to use arduino to control a roomba vaccum cleaning robot.
My project has a very simple IR Led and a 100 OHM resistor connected to the board.
I found this pronto code:
http://www.robotreviews.com/chat/viewtopic.php?t=8682#p64966
For clean:
0000 0069 0000 0008 0071 0027 0023 0071 0023 0071 0023 0071 0071 0027 0023 0071 0023 0071 0023 030B
I read all the documentation about Pronto code, and I was able to understand that
Frequency (hz) is: 39478
1 Cycle (ms) is: 0.025330563858351
First burst pair: 0
Second burst pairs: 8
0071 0027 means 0
0023 0071 means 1
So the string to send (3 times) is: 01110111
Well.....
The first thing I though is to use irlibrary... but how?  SendRaw(X,Y,Z) with X a vector of hex converter to decimal, Y ?? Z=8???
I made several trials but I could'nt figure it out..
I found a script at:
http://l8ter.com/arduino/index.php
That's generate this code
Code:
int pinIRLED = 13;                                      // assign the Infrared emitter/ diode to pin 13
  pinMode(pinIRLED, OUTPUT);                            // set the pin as an output
// sets the pulse of the IR signal.
void pulseON(int pulseTime) {
  unsigned long endPulse = micros() + pulseTime;        // create the microseconds to pulse for
  while( micros() < endPulse) {
    digitalWrite(pinIRLED, HIGH);                       // turn IR on
    delayMicroseconds(13);                              // half the clock cycle for 38Khz (26.32×10-6s) - e.g. the 'on' part of our wave
    digitalWrite(pinIRLED, LOW);                        // turn IR off
    delayMicroseconds(13);                              // delay for the other half of the cycle to generate wave/ oscillation
void pulseOFF(unsigned long startDelay) {
  unsigned long endDelay = micros() + startDelay;       // create the microseconds to delay for
  while(micros() < endDelay);
void takePicture() {
  for (int i=0; i < 2; i++) {
        pulseOFF(2862);
pulseON(988);
pulseOFF(887);
pulseON(2862);
pulseOFF(887);
pulseON(2862);
pulseOFF(887);
pulseON(2862);
pulseOFF(2862);
pulseON(988);
pulseOFF(887);
pulseON(2862);
pulseOFF(887);
pulseON(2862);
pulseOFF(887);
pulseON(19733);
  }                                                     // loop the signal twice.
  takePicture();                                        // take the picture
  delay(5000);                                          // delay in milliseconds which allows us to do timelapse photography - 1 second = 1000 milliseconds
It seems to be wrong (it start with pulse off..) and in fact it doesn't work.. I try to invert pulse on/off (the timing seems to be correct) but it still doesn't work also if I repeat it 3 times (not 2 as the script do )
I have no idea on how I can figure it out and make my project work.. Please help me.
NB I read all the documentation regarding pronto code from remote central and from other website, I manually decodify it, I try to be accurate in defining the right frequency and cycle...
NB2 I don't have the original remote, so I can't use irLibrary to decode the signals
« Last Edit: February 23, 2013, 06:07:42 am by maniiu » Logged
italy
Offline Offline
Newbie
View Profile
Please, somebody can help me?
Logged
italy
Offline Offline
Newbie
View Profile
Finally I was able to make it works:
Code:
#include <IRremote.h>
IRsend irsend;
//unsigned int clean[] = {2650,1100,750,2900,750,2950,700,2950,2700,1100,700,2950,750,2900,750};
unsigned int manu2[32]= {2872,999,897,2872,897,2872,897,2872,2872,999,897,2872,897,2872,897};
    for (int i = 0; i < 4; i++) {
      //irsend.sendRaw(clean, 15, 38);
      irsend.sendRaw(manu2, 15, 39);
      Serial.println("Roomba GO~~~~~~~~~~~~~~~~~");
      delay(40);
  delay(5000);
Manu2 is the best rawcode, derivated directly from Pronto Code (specs found on remote central site).
I hope this will help other people looking for similar solutions
Ciao
Logged
Offline Offline
Newbie
View Profile
Here is a sketch I wrote to send different commands to the Roomba.
For example, enter "136" in the serial monitor, press enter, and the Roomba performs "clean". A list of codes to be sent is also included with the sketch.
https://gist.github.com/probonopd/5181021
Logged
Pages: [1]   Go Up
Print
Jump to:
