Loading...
Pages: [1]   Go Down
Author Topic: Servo - convert writeMicroseconds to write angle  (Read 178 times)
Offline Offline
Newbie
I'm glad I bought an Arduino Leonardo
View Profile
Does anyone know the math  to figure out how to get the servo write() angle out of the writeMicroseconds number?
Thank you in advance! ^^
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Why do you need to? The process is exactly the same as mapping from angle to microseconds, except that the ranges are swapped.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
If in doubt, look at the source.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
And in reality the servo library mapping is a crude assumption on the part of the servo library because it assumes all servos have the same physical positioning range using the same minimum and maximum pulse width values, which is simply not the case.
 If one wants servo.write(degrees) to accurately move the servo in real degree steps then they must carefully test their specific servo(s) and supply the servo library with the correct minimum and maximum pulse widths and build their own mapping to the physical travel limits for the servos being used. servo.writeMicroseconds() is your friend to gain the information needed to have well characterized servo movements possible in your projects.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
