Topic: Problema con funzione ltoa (Read 767 times) previous topic - next topic
nemen
Salve come da titolo ho un piccolo problema, mi spiego meglio quando vado a compilare mi da questo errore :
xxxxxxx.ino: In function 'void readConfig()':
xxxxxxx:xx: error: 'ltoa' was not declared in this scope
Code: [Select]
#include <EEPROM.h>
#include "EEPROMAnything.h"
char ArmCode[];
char disarmCode[];
char adminCode[] ;
struct config_t
    long arm;
    long disarm;
    long admin;
    int c_hour;
    int c_minute;
    int c_second;
} configuration;
void saveConfig() {
  configuration.arm = atol(ArmCode);
  configuration.disarm = atol(disarmCode);
  configuration.admin = atol(adminCode);
  configuration.c_hour = hour;
  configuration.c_minute = minute;
  configuration.c_second = second;
  EEPROM_writeAnything(0, configuration);
void readConfig() {
  EEPROM_readAnything(0, configuration);
  ltoa(configuration.arm, ArmCode, 10);
  ltoa(configuration.disarm,disarmCode,10);
  ltoa(configuration.admin,adminCode,10);
  hour = configuration.c_hour;
  minute = configuration.c_minute;
  second = configuration.c_second;
come posso risolverlo?
grazie in anticipo
PaoloP
Devi includere il file dove dichiari la funzione LTOA.
Mi pare non esista nella libreria standard di Arduino.
cyberhs
#2
Aug 05, 2013, 06:27 pm Last Edit: Aug 05, 2013, 06:30 pm by cyberhs Reason: 1
Sì che esiste e fa parte della stdlib: long to array (ltoa)
Forse va dichiarata la libreria con un #include <stdlib.h>
Quote
char * ltoa (long int __val, char * __s, int __radix)
Convert a long integer to a string.
The function ltoa() converts the long integer value from val into an ASCII representation that will be stored under s. The caller is responsible for providing sufficient storage in s.
Note:
The minimal size of the buffer s depends on the choice of radix. For example, if the radix is 2 (binary), you need to supply a buffer with a minimal length of 8 * sizeof (long int) + 1 characters, i.e. one character for each bit plus one for the string terminator. Using a larger radix will require a smaller minimal buffer size.
Warning:
If the buffer is too small, you risk a buffer overflow.
Conversion is done using the radix as base, which may be a number between 2 (binary conversion) and up to 36. If radix is greater than 10, the next digit after '9' will be the letter 'a'.
If radix is 10 and val is negative, a minus sign will be prepended.
