Loading...
Pages: [1]   Go Down
Author Topic: Program execution resets with no serial connection  (Read 160 times)
Offline Offline
Newbie
View Profile
I have a project where the arduino will collect data while not connected to the PC.  Once connected to the PC it sends info out the serial port.  It seems that if I don't have the usb connected to the PC that the program will not run.  If I leave the pc connected then all functions fine.  What am I missing?
« Last Edit: February 20, 2013, 09:02:13 am by asinc » Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Presumably you have the Arduino connected to another power source?
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Queens, New York
Online Online
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
Some code would be nice.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
Yes an external supply is connected.
Logged
Offline Offline
Newbie
View Profile
Actually I just confirmed that the program does continue to run.  The problem appears to be that once the USB is plugged into the PC, that the arduino reboots and starts execution again.
Logged
Queens, New York
Online Online
Edison Member
View Profile
Yes, that is what it supposed to do, unless you disable the reset feature.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Two things,
1. when you open the serial monitor it will reset the Arduino.
2. As I understand it serial will hang when its buffer is full.
Mark
Written as you where posting
Logged
Offline Offline
Newbie
View Profile
and how do I do that?
So many quick responses!  Thanks
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Two things,
Yes, Irregardless if your using serial statements in your sketch or not.
No, the serial buffers, if overfilled, will just wrap around thus loosing characters but it will still continue to receive and send characters.
Lefty
Mark
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Quote
Lefty
Not according to the hardwareSerial code
Code:
size_t HardwareSerial::write(uint8_t c)
  int i = (_tx_buffer->head + 1) % SERIAL_BUFFER_SIZE;
  // If the output buffer is full, there's nothing for it other than to
  // wait for the interrupt handler to empty it a bit
  // ???: return 0 here instead?
  while (i == _tx_buffer->tail)
  _tx_buffer->buffer[_tx_buffer->head] = c;
  _tx_buffer->head = i;
  sbi(*_ucsrb, _udrie);
  // clear the TXC bit -- "can be cleared by writing a one to its bit location"
  transmitting = true;
  sbi(*_ucsra, TXC0);
  return 1;
Mark
Logged
Offline Offline
Brattain Member
View Profile
Quote
Lefty
Code:
  sbi(*_ucsra, TXC0);
  return 1;
Mark
I was speaking in reference to the receive buffers which the user has no control over if they continue to receive characters from an external source but are not read out of the 'growing' buffer by the sketch in due time.
 The transmit buffer, if filled, just becomes a 'blocking' command and will empty the buffer in due time based on the baud rate being used, so nothing is lost on the transmit side, it just 'stalls' your sketch until it's not full.
Lefty
Logged
Queens, New York
Online Online
Edison Member
View Profile
I believe its a 10k resistor from reset to ground
Reset => 10K => GND
I think, but maybe Lefty knows for sure.
Logged
Pages: [1]   Go Up
Print
Jump to:
