Topic: Sending voltages to PWM pins through the Serial Monitor (Read 2223 times) previous topic - next topic
TwoChain
Hello,
I am new to Arduino and have been following along through Simon Monk's book "Programming Arduino Getting Started with Sketches". The book is excellent, and up until now I have had no problems. However, I am now trying to get sketch 6-08 to work with my Uno. The goal of this sketch is to use PWM pins to generate a voltage between 0 and 5 V. The sketch is shown below:
Code: [Select]
//sketch 06-08
int outputPin = 3;
  pinMode(outputPin, OUTPUT);
  Serial.println("Enter Volts 0 to 5");
  if (Serial.available() > 0)
    char ch = Serial.read();
    int volts = (ch - '0') * 51;
    analogWrite(outputPin, volts);
When I run the sketch, my Arduino Uno does not generate the voltage it should at the specified pin (in this case, pin 3). Regardless of the voltage I enter into the Serial Monitor, I only measure a voltage of ~ 0.13 V at pin 3 (vs. ground). The same is true for all of the PWM pins (after changing the code to correspond to the new pin, of course).
To determine if this was problem with the code, or a problem with my board, I tried editing the code to look as follows:
Code: [Select]
//sketch 06-08
int outputPin = 3;
  analogWrite(outputPin, 150);
By doing this, and by directly varying the voltage of pin 3 in the void setup(), I have verified that my Arduino Uno is working properly (a value in the analogWrite function of 150 results in a voltage of ~ 2.94 V, as expected).
One final clue to this problem comes by adding the lines Serial.println(ch) and Serial.println(volts) into the void loop() of the original code. When I do this, I can see that when I enter a voltage into the Serial Monitor, the variable "volts" initially takes the correct value, but immediately after this it reverts to a value of -1785 regardless of the voltage that I enter into the Serial Monitor. In fact, even if I enter nothing into the Serial Monitor, and simply press "send" the variable "volts" again takes a value of -1785. Based on this I can clearly see that there must be something wrong with the code, but as I am new to this area, I cannot identify the problem.
Specifically, I would like to know:
1) Why does the variable "volts" immediately revert to -1785 regardless of the voltage I enter?
2) How can I modify the code to avoid this problem?
Thanks!
Dustin
Nick Gammon
What voltage do you enter? Give an example.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
CrossRoads
The values you receive over serial can be seen here
http://www.asciitable.com/
'0' = 48 decimal,
'1' = 49 decimal,
etc.
So you could change this from
to
byte volts = (ch - 48) * 51;  // results in 0, 51,102, 153, 204, 255
which is what analogWrite is expecting, an 8-bit number.
Nick Gammon
More info:
TwoChain
Hello Nick,
Thank you for your fast reply.
I am entering voltages between 0 and 5. I can see how the code is supposed to convert these user defined voltages to values between 0 and 255 to be fed into the analogWrite command. However, it does not seem to be working.
Dustin
Nick Gammon
Say you entered: 5 <carriage-return>
The 5 is processed OK, but carriage-return has the value 13, see my arithmetic above.
More info:
Nick Gammon
More info:
Nick Gammon
-1785 is F907 in hex. Take the low-order byte (07) and do this math:
Code: [Select]
07 / 255 * 5 = 0.13725490196078
That's why you got a voltage of 0.13 volts!
So, everything is working. ;)
More info:
TwoChain
Hello Nick and CrossRoads,
Thank you both for your amazingly fast replies. I really appreciate the help and the explanation. I will try editing my code with this in mind. I wonder why/how this code was able to work for Simon in his book. It specifically states that you should be able to simply enter in the numeric value you desire to achieve at the PWM pin, and it will be generated using this exact code. There is even a picture of a multimeter measuring a value of "3" after "3" is entered into the Serial Monitor...
Anyways, thanks both for your help.
Dustin
Nick Gammon
He may conceivably have his serial monitor configured to not send anything when you hit Send, rather than carriage-return.
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
