Topic: Arduino Micro, USB Keyboard not 100% like a real keyboard (Read 2420 times) previous topic - next topic
calli
Mar 06, 2013, 08:59 pm Last Edit: Mar 06, 2013, 09:01 pm by calli Reason: 1
after trying a bit with a normal Arduino and usbkeyboard.h I found it too wacky and bought a Arduino Micro. It was quite straight forward to make my application, a footswitch controller for a music game (Rocksmith).
The Keyboard from the Arduino micro works well in Windows and even the menu control in the game works with it. HOWEVER and thats my problem, as soon as the real game (outside menus, playing a "level") starts no keypresses are send (or received?). A second (real) USB Keyboard connected works as expected, so I think the Arduino Micro does not act *exact* like a USB Keyboard...
Any suggestions how to solve this? Who is the developer for this part of the Arduino project? BTW: where is the source for that functionality?
Any suggestions welcome to save my project from going to the "not working projects" box...
Cheers,
Carsten
EDIT: The sketch
Code: [Select]
// Keybox
#define SHIFTLED 10
#define POWERLED 11
#define DEBOUNCE 10  // button debouncer
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {
  2, 3, 4, 5,6,7}; // the analog 0-5 pins are also known as 14-19
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// Track Array
byte pressed[NUMBUTTONS];
  byte i;
  // set up serial port
  //  Serial.begin(9600);
  // pin13 LED
  pinMode(POWERLED,OUTPUT);
  pinMode(SHIFTLED,OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    //    digitalWrite(buttons[i], HIGH); // we use external Pulls
  Keyboard.begin();
void check_switches()
  byte index;
  for (index = 0; index < NUMBUTTONS; index++)
    if (digitalRead(buttons[index]) and (pressed[index]<DEBOUNCE))
      pressed[index]++;
    else if (!digitalRead(buttons[index]))
      pressed[index]=0;
void keySend(char key)
  digitalWrite(POWERLED, LOW);
  Keyboard.write(key);
  delay(100);
  digitalWrite(POWERLED, HIGH);
  delay(10);
  check_switches();
  if (pressed[0] >= DEBOUNCE)
    if (!digitalRead(SHIFTLED))
      keySend(KEY_F1); // F1
      keySend(KEY_LEFT_ARROW); // Links
  else if (pressed[1] >= DEBOUNCE)
      keySend(KEY_F2);
      keySend(' ');
  else if (pressed[2] >= DEBOUNCE)
      keySend(KEY_F3);
      keySend(KEY_RIGHT_ARROW);
  else if (pressed[3] >= DEBOUNCE)
    keySend(KEY_ESC); // ESC
  else if (pressed[4] >= DEBOUNCE)
    keySend(KEY_RETURN); // ENTER
  if (digitalRead(buttons[NUMBUTTONS-1]))
    digitalWrite(SHIFTLED, HIGH);
    digitalWrite(SHIFTLED, LOW);
Erdin
I think it should work. I'm looking at the sketch and see a few strange things.
You use Keyboard.write(). That 'sends' a character, as if someone is typing a key very quickly. After that, you wait 100ms, that is a long time.
Could you make small test sketch for one button.
Use the Keyboard.press() if the button is pressed, and Keyboard.release() if the button is released. Try if that is accepted by the game.
calli
I will try. Maybe the game itself uses a different keyboard polling because of the realtime needs of that specific game and so it misses that keypresses.
The delay(100) I use for the pause between keyboard key repeat.
will come back later with results.
Thanks,
Carsten
calli
@Erdin: You are my hero ;-)
Works now. I was unsure from beginning what function to use, and then decided that they are equal and that there must be some kind of buffer so that no keypress gets lost, but as it seems that function is much lower level, near hardware....
Thank you very much, you made my evening!
Carsten
James C4S
It's all included with the IDE and also can be found on the Arduino github.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
calli
Yea, sure, but I could not find it searching for "Leonardo", "Keyboard" or "USB". Was hoping for a lazyman pointer. Often the dvelopers comments are quite helpfull.
Carsten
Louis Davis
Carsten
Here is the lazyman pointer:
https://github.com/arduino/Arduino/blob/master/hardware/arduino/cores/arduino/HID.cpp
calli
Thanks, interesting even though the problem is solved.
Carsten
James C4S
Then get your local search fixed.
Code: [Select]
James-MBP2b:cores james$ cd /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino
James-MBP2b:arduino james$ grep Keyboard *
HID.cpp:Keyboard_ Keyboard;
HID.cpp: // Keyboard
HID.cpp:    0x09, 0x06,                    // USAGE (Keyboard)
HID.cpp:    0x05, 0x07,                    //   USAGE_PAGE (Keyboard)
HID.cpp: 0x19, 0xe0,                    //   USAGE_MINIMUM (Keyboard LeftControl)
HID.cpp:    0x29, 0xe7,                    //   USAGE_MAXIMUM (Keyboard Right GUI)
HID.cpp:    0x29, 0x65,                    //   USAGE_MAXIMUM (Keyboard Application)
HID.cpp:// Keyboard
HID.cpp:Keyboard_::Keyboard_(void)
HID.cpp:void Keyboard_::begin(void)
HID.cpp:void Keyboard_::end(void)
HID.cpp:void Keyboard_::sendReport(KeyReport* keys)
HID.cpp:size_t Keyboard_::press(uint8_t k)
HID.cpp:size_t Keyboard_::release(uint8_t k)
HID.cpp:void Keyboard_::releaseAll(void)
HID.cpp:size_t Keyboard_::write(uint8_t c)
USBAPI.h:// Keyboard
USBAPI.h:class Keyboard_ : public Print
USBAPI.h: Keyboard_(void);
USBAPI.h:extern Keyboard_ Keyboard;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
