Topic: Non blocking blink alternatives (Read 595 times) previous topic - next topic
malrose
I have a stepper motor I want to run with very quick blink pulses but I want a way to do it without blocking the code, I know about blink without delay but I'm unsure it can do what I want since I first want it to blink with a certain  delay, then blink with another delay in the code. example:
long interval = 1000;
at one point of the code and
long interval = 500;
at another.
I hope my question makes sense.
AWOL
You'll notice in the blink without delay example that the variable "interval" is fixed at 1000.
It is a variable so you can give it any value you like.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
malrose
To clarify it a bit more, I'd like it to run at the variable of 1000 for around 3 seconds then switch to 500. Or run at 1000 for 3 seconds then 500 for a set amount of time then 200 then go back to 1000.
AWOL
You'll have to define "around 3 seconds" a little better for the compiler, but there's nothing to stop you assigning any value you want to "interval" at any time.
malrose
So I can change the interval inside the loop? How do I do that?
AWOL
With a simple assignment - it's a variable
malrose
I think I get, I just call long interval = 700; inside the loop if I want to change it, but how do I time it? How do I get it to keep track of how long it has been blinking before changing.
AWOL
Quote
That looks to me like you're creating a new variable call "interval", which probably isn't what you want.
Quote
I have no idea - I can't see your code - but it probably involves some calls to "millis()"
PeterH
The blink without delay example demonstrates how to run code after an interval. That code can do whatever you want, including changing the variables that control the timing of that piece of code, or variables that affect timing of other pieces of code.
