Topic: Rewersing directionof stepper motor with limit switch (Read 6308 times) previous topic - next topic
websonic
Hi everybody,
I am very new in this field,
can somebody help me with a sample code how to reverse direction of a stepper motor  when 5v is applied through limit switch?
I have managed to switch of an on LED, with switch, but Stepper are out of my range.
Thanks In advance
wildbill
websonic
#2
Feb 20, 2013, 05:20 pm Last Edit: Feb 20, 2013, 05:43 pm by websonic Reason: 1
It is 6  wire unipolar motor,
Controlled over arduino uno,
And i am trying to use accel stepper library
MarkT
websonic
Hardly any,
I want to use random example from accelstepper
any ideas hot to incorporate two limit switches which would only reverse reverse direction if activated
Thanks in advance
// Random.pde
// -*- mode: C++ -*-
// Make a single stepper perform random changes in speed, position and acceleration
// Copyright (C) 2009 Mike McCauley
// $Id: Random.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
    if (stepper.distanceToGo() == 0)
   // Random change to speed, position and acceleration
   // Make sure we dont get 0 speed or accelerations
   stepper.moveTo(rand() % 200);
   stepper.setMaxSpeed((rand() % 200) + 1);
   stepper.setAcceleration((rand() % 200) + 1);
    stepper.run();
dewy721
#5
Feb 23, 2013, 05:22 am Last Edit: Feb 23, 2013, 05:28 am by dewy721 Reason: 1
top of file add: (replace A0 & A1 with your selection of pins.)
#define switchPinA A0
#define switchPinB A1
Add to void setup()
 pinMode(switchPinA,INPUT);
 pinMode(switchPinB,INPUT);
 digitalWrite(switchPinA,HIGH);
 digitalWrite(switchPinB,HIGH);
in void loop() replace:
//stepper.moveTo(rand() % 200);
*with*
long someRandomPosition=rand() % 200;
if(digitalRead(switchPinA)==HIGH || digitalRead(switchPinB)==HIGH)
  someRandomPosition=someRandomPosition * -1; // just invert data
stepper.moveTo(someRandomPosition);
PS: According to  if (stepper.distanceToGo() == 0)
it will change direction based on switches, ONLY after it completes the previous move.
If you wish to have it switch directions instantly, then you just need to put the blue code outside of the if (stepper.distanceToGo() == 0) statement.
websonic
Hi Dewy,
Thanks for advice and your time.
I am still having trouble
when I include long someRandomPosition=rand() % 200;
Stepper just gets blocked.
With out that change motor always runs in one direction.
Pls take >look at the code, What I have done wrong?
AccelStepper stepper(AccelStepper::FULL4WIRE, 8, 9, 10,11);
#define switchPinA 2
#define switchPinB 3
        //someRandomPosition=someRandomPosition * -1; // just invert data
        stepper.moveTo(-1);
    stepper.run();
dewy721
Try this instead:
#define lowestRandomNum -100
#define highestRandomNum 100
     long someRandomPosition=random(lowestRandomNum, highestRandomNum);
     stepper.setMaxSpeed(random(0, highestRandomNum) + 1);
     stepper.setAcceleration(random(1, highestRandomNum) + 1);
   stepper.run();
websonic
Hi Dewy,
This time it is working :) thanks, thanks ,thanks :)
If you do have more time for me,
1) I do not think that when limit switch is activated motor changes direction straight away.
2) and I would greatly appreciated if you can advise me how to set minimum speed in random behavior.
I have checked limit switches with simple sketch to activate 2 LEDs, and I am sure that part is ok.
Thanks in advance
dewy721
Ok for that, let's take a look at the AccelStepper command reference:
First, lets fix the brakes:
    Quickstop.pde.
We'll need to add the use of:
stop() "Sets a new target position that causes the stepper to stop as quickly as possible..."
runToPosition() "Moves the motor at the currently selected constant speed (forward or reverse) to the target position..."
Now lets rev up the minimum speed:
setMaxSpeed() "Sets the maximum permitted speed."
     stepper.setMaxSpeed(random(10, highestRandomNum) + 1);
       stepper.stop(); // Stop as fast as possible: sets new target
       stepper.runToPosition();
   stepper.run();
Ok, that's my limit of two freebies per customer. Its your turn to hack at it. :)
websonic
God Bless  my friend :)
I am greatfull and for this much
