Loading...
Pages: [1]   Go Down
Author Topic: OpAmp Freq and Slew rate?  (Read 155 times)
Offline Offline
Full Member
View Profile
It is correct that an opamp with lower bandwidth will reproduce a signal with a low peak input voltage - say 125mV. Where as if I have a 5V peak signal, i would need a much higher slew rate? Slew rate= (2*pi*F*Vpk/1e-6)[V/us]
I have an signal source that gives me  5V peak, 68Mhz square wave at a very low output impedance. I wanted a buffer op amp to help interface it to other things. If I use a fraction of the input voltage, that requires a lower slew rate and I can get away with a lower bandwidth op-amp. Is that correct?
Logged
Offline Offline
Sr. Member
View Profile
Here's the typical relationship between Vpeak and SR and frequency.
Area above diagonal line = good.
Why not just use a high-speed logic line driver (non-inverting)?  Example CD74HCT241
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Excellent sugestion... One more thing, Tie the unused inputs low (to ground) the unused buffers can oscillate and when that happens the gates involved draw a great deal of current from the 5V power supply and get quiite hot.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Pages: [1]   Go Up
Print
Jump to:
