Pittsburgh, PA, USA
I only know some basic electricity....
« Reply #45 on: February 24, 2013, 09:33:09 am » |
Dont jump on my case because you dont know US laws or how the country's laws work. Are you joking or just stupid? http://www.fcc.gov/search/results/jamming. When you can find laws prohibiting sales of such devices with body text that says Signal jamming devices pose significant risks to public safety and potentially compromise other radio communications services. Then you should be able to figure out that building your own is not an 'out'. Whether you buy or build you own gun, if you shoot someone it counts. Your examples/exceptions are a joke BTW. If I caused enough interference to be noticed, the FCC would let me know and fine me. That's not guesswork either. My circuits don't run enough power to compete with my open-box PC and it doesn't cause noticeable interference to my TV or radio. There is such a thing as _proportion_ and in the case of interference it has to reach far enough to be detected to matter. You don't seem to know the difference between what matters and what does not. Will your jammer be so short-ranged as a normal PC, or short in an appliance or some low power Arduino project I make? Or will it be powerful to jam FM radio signals at any useful distance? "Mommy I want a cookie." "Not until you eat your food." "But cookies ARE food!"
Examples can be found at Learning in the Main Site and at the Playground
Dallas, TX
« Reply #46 on: February 24, 2013, 10:22:36 am » |
This is the "Project Guidance" section, so if I picked the wrong band to mess with jamming to learn from then tell me. Okay, now you're talking. There is an unallocated band between 3kHz and 6kHz. Knock yourself out.
Yes they know I have a brass set and the one is bigger then [sic] the other two. And pay attention in grammar class this term.
Tucson, AZ
« Reply #47 on: February 24, 2013, 12:01:53 pm » |
This is the "Project Guidance" section, so if I picked the wrong band to mess with jamming to learn from then tell me. Dont jump on my case because you dont know US laws or how the country's laws work.
A lot of you are more bent out of shape on RF bands than realizing that some home made circuit's can also outputting interference. How many of you test every circuit you build? 5% of the people on this forum actually test for that, or less? If the FCC went around checking interference they would find appliances shorting out in homes producing interference. Your PC is one program away from being a jammer, yes its that easy!
Yes they know I have a brass set and the one is bigger then the other two.
I'll tell you what S_Flex, I DO work for the FCC as an engineer. You think I don't know the FCC regulations? Here's a list of our field offices. http://transition.fcc.gov/eb/rfo/FieldPhone.html I DARE you to call any one of them and tell them that your little jamming scheme is LEGAL, give them your address, and DEFY them to do something about it. Since I KNOW that you only "have a brass set" while you are hiding behind what you THINK is the anonymity of a forum posting and would never actually call us, for my part, I'll initiate the process to have our Special Counsel for the Spectrum Enforcement Division get your IP address from the forum moderators, use that to get your REAL name and address from your ISP, and start an investigation based upon your PUBLIC admission regarding carrying out a pre-meditated jamming operation with full knowledge that your actions are both harmful to radio communications and illegal. I am sick of you coming on this forum and telling the good people of this forum that DO KNOW the FCC regulations, that they are wrong and engaging in your pathetic little saber-rattling tirade of superiority.
South England
« Reply #48 on: February 24, 2013, 12:09:54 pm » |
 I think I can hear them starting to rattle and shrink already
Dallas, TX
« Reply #49 on: February 24, 2013, 01:20:46 pm » |
 I think I can hear them starting to rattle and shrink already  That's the best macro of a pair of BB's I've ever seen!
Boston, MA
Carpe Mirum
« Reply #50 on: February 24, 2013, 04:53:06 pm » |
From Code of Federal Regulations, title 47, part 15:
§ 15.239 Operation in the band 88-108 MHz.
(a) Emissions from the intentional radiator shall be confined within a band 200 kHz wide centered on the operating frequency. The 200 kHz band shall lie wholly within the frequency range of 88-108 MHz.
(b) The field strength of any emissions within the permitted 200 kHz band shall not exceed 250 microvolts/meter at 3 meters. The emission limit in this paragraph is based on measurement instrumentation employing an average detector.
Elsewhere in part 15 is a requirement that measurements confirming compliance be supplied to the nearest FCC office if the device is not a type-approved commercially produced unit.
If you are in compliance with those regulations, you are set until the first time there's an interference report from anybody. With the second report, it becomes intentional interference. The default fine is $4,000 per monitored transmission.
Is that sufficiently concise to end the shouting match?
Manchester (England England)
Solder is electric glue
« Reply #51 on: February 24, 2013, 05:14:05 pm » |
Is that sufficiently concise to end the shouting match? I doubt it because he does not believe that that particular law applies to him. He believes that something at state level trumps that law. He is taking freedom of believe to a level that is beyond belief.
Dallas, TX
« Reply #52 on: February 24, 2013, 05:49:22 pm » |
Is that sufficiently concise to end the shouting match? He is taking freedom of believe to a level that is beyond belief. The highest level of which is just plain ignorance.
Dee Why NSW
« Reply #53 on: February 24, 2013, 06:30:23 pm » |
Does anyone have some links or projects of jammers that are powered by an arduino?
NOTE: Before you come posting on this thread about it being illegal. I know the laws a
Four pages in less than four days..... I visit this thread only because of some fascination about the motivation, and mindset, that started it in the first place. My money is on Grumpy Mike, it is all about the evils of rock'n'roll.
Pittsburgh, PA, USA
« Reply #54 on: February 24, 2013, 06:30:23 pm » |
Is that sufficiently concise to end the shouting match? I doubt it because he does not believe that that particular law applies to him. He believes that something at state level trumps that law. He is taking freedom of believe to a level that is beyond belief. It's been the national hobby for years now. Science is a hoax and facts are optional.
Land of Oz
I dream in Assembler
« Reply #55 on: February 24, 2013, 06:41:24 pm » |
This is the "Project Guidance" section, so if I picked the wrong band to mess with jamming to learn from then tell me. Dont jump on my case because you dont know US laws or how the country's laws work. A lot of you are more bent out of shape on RF bands than realizing that some home made circuit's can also outputting interference. How many of you test every circuit you build? 5% of the people on this forum actually test for that, or less? If the FCC went around checking interference they would find appliances shorting out in homes producing interference. Your PC is one program away from being a jammer, yes its that easy! Yes they know I have a brass set and the one is bigger then the other two.
You, Sir, plain and simply, are an idiot. I worked in EMC compliancy and Tempest for a number of years so I do know what I am talking about. I am also an amateur radio op for many many years. Your statement on PCs and other appliances shows your lack of knowledge on degree of interference. Now...do I waste my time saying more ??? Maybe not, some people on this planet are confirmed basket cases and nothing would change that.
« Last Edit: February 24, 2013, 07:18:40 pm by greywolf271 »
Left Coast, CA (USA)
Measurement changes behavior
« Reply #56 on: February 24, 2013, 06:47:10 pm » |
Is that sufficiently concise to end the shouting match? I doubt it because he does not believe that that particular law applies to him. He believes that something at state level trumps that law. He is taking freedom of believe to a level that is beyond belief. Well in the USA there is and always will be a lot of issues and opinions around States and individual rights Vs Federal powers granted under out Constitution. It's kind of ingrained into our Constitution that the Founders wanted a rather limited and focused Federal government, given only specific enumerated powers, the rest (even if unstated) being reserved to the States and the People. There is no question that the US Federal government has grown to dwarf the powers of the State. But in the case of RF laws it would appear to clearly fall (IMO) under the common commerce clause of the Constitution and could not be managed by 50 individual states. Lefty
UK
« Reply #57 on: February 25, 2013, 02:40:57 am » |
I think it's all been said now. Thread locked.
