Topic: Arduino Due unable to connect to Bossa (Read 3809 times) previous topic - next topic
rtmetz92
It is the first time I work with an Arduino (I chose the Due) and I'm having a lot of trouble uploading the code to the board, using Bossa under Windows 8 (64 bits).
The steps I have taken to install the Arduino Due are the following:
Firstly, I installed Bossa with the drivers signature enforcemente disabled
After connecting the board to the Programming Port, I went to the Device Manager and selected the "Arduino Due Programming Port" which was a unrecognized device. Then, I have manually installed its drivers which are in the arduino 1.5.2 folder with success (the "?" does no longer appear in the icon next to the Arduino Device).
At this point, I can upload any code example with the Arduino IDE with any problems.
With Bossa, however, after following these steps https://sites.google.com/site/arduinodueatmelstudio/home/uploading-code-to-due I am unable to connect the program with the board. Also, with the Bossa GUI, when I select COM3, it says that the device was not found.
So, if the code upload works with the Arduino IDE, what am I steps am I missing, so that Bossa can't even establish a connection with the device? (please note that I have already tried to press the reset button, the erase button and both switches - erase button for 1 second and then press the reset button while pressing the previous one).
Any help is appreciated.
Thanks in advance
Louis Davis
The DUE uses a patched version of BOSSA, see here:
https://github.com/shumatech/BOSSA/tree/arduino
This may be why you are having problems, if you are using the standard version of BOSSA.
rtmetz92
#2
Feb 22, 2013, 06:45 pm Last Edit: Feb 22, 2013, 06:58 pm by rtmetz92 Reason: 1
Yes, I was using the version 1.2.1, which might be as you said the general version of bossa. I will try to install this version and then I will post some feedback. Thank you for the help.
EDIT: It seems to be working. Thank you so much for the precious help :)
bfall17
This is from a while ago, but did you have to compile the modified Bossa, or is there an executable for it somewhere?
