Topic: Video capture ! Possible? (Read 13627 times) previous topic - next topic
sja785
Hello, I read on other forums that video processing (color detection, object recognition, etc.) is impossible with arduino because of the amount of processing power required for this. However what about simple video capture?
I have Arduino Uno and Arduino WiFi shield and what I would like is to stream video captured through an Internet connection. Is this possible? If yes then what video camera can I buy?
robtillaart
Quote
Define simple?
I recall some 10 by 10 pixels (?) BW video demo. It was barely enough to recognize anything. Think youtube is your friend here
but in short, not possible.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Arrch
BulletMagnet83
Isn't it about time we had an "Arduino and Video - Crushing your expectations" sticky thread? ;)
be80be
When you have computers that cant stream video whats 8 mhz micro controller going to do?
PeterH
Buy an IP camera. You can use your Arduino and WiFi shield to prop it up, if you like.
sja785
I know that my project (a car that can be controlled over a WiFi connection) would work with an IP camera. However wouldn't that defy the whole point of using an arduino board for this type of project? Should I be looking at some other product for this type of project?
Would it change anything if rather then streaming video; snapshots are taken, saved on an SD card, and then stream the image files on the SD card?
AWOL
Quote
try sitting in the driver's seat.
Look around, then close your eyes, engage drive and steer based on what you just saw. Drive for about twenty seconds, then open your eyes. Repeat.
(20 seconds is being generous)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
sja785
Good point; was not thinking there would be such a long delay. Arduino has been a lot of fun; really helped me learn lots of new stuff, but I guess video capture/processing is too much and I might have to look at something else. Any leads ... ?
zoomkat
Some thoughts on a simple routerbot that could be expanded.
http://www.lynxmotion.net/viewtopic.php?f=20&t=6343
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
PeterH
That begs the question - what is the point of trying to use the Arduino for this type of project?
robtillaart
An arduino can perfectly support a video project with
- pan and tilt the camera
- determine light conditions
- switch on LEDs or even IR leds
- can shine a laser pointer
- can drive the camera to a new location
- can hold a magnifying glass for the webcam (to get different focus)
- can detect heat, moisture etc
- sound alarms
Rob Tillaart
sja785
#12
Feb 23, 2013, 02:20 pm Last Edit: Feb 23, 2013, 02:28 pm by sja785 Reason: 1
What would you suggest? I know that Arduino (+ WiFi Shield) and an IP camera would solve my problem however the hardware of the IP camera really and truly can already do what I am doing with the Arduino. For example I found an IP camera which I can tilt and rotate; if the hardware of this IP camera can already do this then it can also manage another motor to move a pair of wheels.
However I do not know what kind of boards these IP cameras have inside. I guess what I am looking for is something that fills the gap between Arduino and RaspberryPI (I think RaspberryPI is too much for this type of project).
PeterH
This is the first time you've mentioned wheels.
Perhaps you ought to step back and explain what you're trying to achieve. I don't think it is sensible to do any form of video capture/processing/transmission with an Arduino, but perhaps there are other parts of your problem which an Arduino might be useful for.
zoomkat
If you are want to experiment with video, you might look into how the old parallel port Connectix QuickCams operated. A microcontroller might be able to capture video in some form from the quickcam.
