Author Topic: while loop disrupting void loop?  (Read 212 times)
I really hesitate to post this because I just know that I'm doing something stupid, but I would appreciate any input. I am have an Arduino Mega 2560 with an LCD shield. I am trying to make a sort of pseudo-alarm system with it. Enter 4 digit sequence of buttons, alarm sets, enter it again to get a message. Anyway. Everything was going nicely, I got it to store the password. Then I tried to make it do something with those numbers. It seems that after it breaks out of the while loop it goes straight to the top of the program (ie. it runs the setup() again). I don't know if I am doing something wrong with my while loop or if I am just missing something.
Step by step:
I run the program.
It displays the initial "Begin Alarm." (on the lcd)
It then starts accepting values and outputting them to the serial so I can see them.
Gets the 4 button sequence as I expected. Displays it on serial.
When I press a button the 5th time, it displays "Begin Alarm" again (on the lcd) and the whole thing repeats.
"Password Set" is never displayed.
Its like the Arduino is getting reset. Again, I am probably just doing something wrong, but I would appreciate any insight anyone could give me.
Full code is below
#include <Wire.h>
#include <LiquidCrystal.h>   // include LCD library
  Defines
// Pins in use
#define BUTTON_ADC_PIN           A0  // A0 is the button ADC input
#define LCD_BACKLIGHT_PIN         10  // D10 controls LCD backlight
#define RIGHT_10BIT_ADC           0  // right
#define UP_10BIT_ADC            120  // up
#define DOWN_10BIT_ADC          280  // down
#define LEFT_10BIT_ADC          480  // left
#define SELECT_10BIT_ADC        720  // right
#define BUTTONHYSTERESIS         30  // hysteresis for valid button sensing window
//return values for ReadButtons()
#define BUTTON_NONE               0  //
#define BUTTON_RIGHT              1  //
#define BUTTON_UP                 2  //
#define BUTTON_DOWN               3  //
#define BUTTON_LEFT               4  //
#define BUTTON_SELECT             5  //
//some example macros with friendly labels for LCD backlight/pin control, tested and can be swapped into the example code as you like
#define LCD_BACKLIGHT_OFF()     digitalWrite( LCD_BACKLIGHT_PIN, LOW )
#define LCD_BACKLIGHT_ON()      digitalWrite( LCD_BACKLIGHT_PIN, HIGH )
#define LCD_BACKLIGHT(state)    { if( state ){digitalWrite( LCD_BACKLIGHT_PIN, HIGH );}else{digitalWrite( LCD_BACKLIGHT_PIN, LOW );} }
  Variables
byte buttonJustPressed  = false;         //this will be true after a ReadButtons() call if triggered
byte buttonJustReleased = false;         //this will be true after a ReadButtons() call if triggered
byte buttonWas          = BUTTON_NONE;   //used by ReadButtons() for detection of button events
int password[4];                         //Where we will store the passoword
  Init the LCD library with the LCD pins to be used
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );   //Pins for the freetronics 16x2 LCD shield. LCD: ( RS, E, LCD-D4, LCD-D5, LCD-D6, LCD-D7 )
   //button adc input
   pinMode( BUTTON_ADC_PIN, INPUT );         //ensure A0 is an input
   digitalWrite( BUTTON_ADC_PIN, LOW );      //ensure pullup is off on A0
   //lcd backlight control
   digitalWrite( LCD_BACKLIGHT_PIN, HIGH );  //backlight control pin D3 is high (on)
   pinMode( LCD_BACKLIGHT_PIN, OUTPUT );     //D3 is an output
   //set up the LCD number of columns and rows:
   lcd.begin( 16, 2 );
   //Print some initial text to the LCD.
   lcd.setCursor( 0, 0 );   //top left
   //          1234567890123456
   lcd.print( " Begin Alarm" );
   lcd.setCursor( 0, 1 );   //bottom left
   lcd.print( "Btn:" );
  byte button;
  byte lastbutton = 0;
  button = ReadButtons();
  lcd.setCursor (0,0);  //Top left
  lcd.print ("Enter 4 button  ");
    lcd.setCursor(0,1);
    lcd.print ("Password:");
   int t = 0;
   while (t <5)
     if (button != lastbutton)      //If the button has changed since last time
       switch( button )              //Go into the switch
        case BUTTON_NONE:
           lastbutton = button;
           break;
        case BUTTON_RIGHT:
           lcd.setCursor( 10, 1 );
           lcd.print( "RIGHT   " );
           password[t] = button;
           t = t+1;
           break;
        case BUTTON_UP:
           lcd.print( "UP   " );
           t = t+1;
           break;
        case BUTTON_DOWN:
           lcd.print( "DOWN  " );
           t = t+1;
           break;
        case BUTTON_LEFT:
          lcd.print( "LEFT  " );
          t = t+1;
          break;
       case BUTTON_SELECT:
          lcd.print( "SELECT-FLASH" );
          t = t+1;
          break;
        default:
          break;
Serial.print (password[0]);
Serial.print (F("     "));
Serial.print (password[1]);
Serial.print (password[2]);
Serial.print (password[3]);
Serial.println (t);
//  -------------------------     END GET PASSWORD    --------------------------------
lcd.setCursor(0,0);
lcd.print (F("Password Set    "));
lcd.setCursor(0,1);
lcd.print (F("                  "));
delay (5000);
  ReadButtons()
  Detect the button pressed and return the value
  Uses global values buttonWas, buttonJustPressed, buttonJustReleased.
byte ReadButtons()
   unsigned int buttonVoltage;
   byte button = BUTTON_NONE;   // return no button pressed if the below checks don't write to btn
   //read the button ADC pin voltage
   buttonVoltage = analogRead( BUTTON_ADC_PIN );
   //sense if the voltage falls within valid voltage windows
   if( buttonVoltage < ( RIGHT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_RIGHT;
   else if(   buttonVoltage >= ( UP_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( UP_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_UP;
   else if(   buttonVoltage >= ( DOWN_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( DOWN_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_DOWN;
   else if(   buttonVoltage >= ( LEFT_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( LEFT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_LEFT;
   else if(   buttonVoltage >= ( SELECT_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( SELECT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_SELECT;
   //handle button flags for just pressed and just released events
   if( ( buttonWas == BUTTON_NONE ) && ( button != BUTTON_NONE ) )
      //the button was just pressed, set buttonJustPressed, this can optionally be used to trigger a once-off action for a button press event
      //it's the duty of the receiver to clear these flags if it wants to detect a new button change event
      buttonJustPressed  = true;
   if( ( buttonWas != BUTTON_NONE ) && ( button == BUTTON_NONE ) )
      buttonJustReleased = true;
   //save the latest button value, for change event detection next time round
   buttonWas = button;
   return( button );
Thanks
Matt
Melbourne, Australia
Shannon Member
Lua rocks!
  while (t <5)
          t = t+1;
Looks to me like you are storing into password [4] which is not valid.
Sigh. That would be the problem. I'm glad there are people smarter than me out there.
int password[5];
Now it works fine.
Many thanks.
Pittsburgh, PA, USA
I only know some basic electricity....
I think you fixed the wrong thing. Or is the 5th an Enter key? In that case, you fixed the wrong thing too.
Examples can be found at Learning in the Main Site and at the Playground
The 5th key really didn't do anything. It was just enter 4 digits and press any key a 5th time to go on.
Regardless, that was an error and correcting it fixed the problem.
Pakistan
Before you were thinking nobody is smarter than you smiley-mr-green
