Topic: [Solved] Are pins forced to LOW after constructor calls? (Read 2192 times) previous topic - next topic
olikraus
Feb 22, 2013, 10:37 pm Last Edit: Feb 23, 2013, 12:16 am by olikraus Reason: 1
On my Due i have the following code (Arduino IDE 1.5.2). It should force pin 8 to HIGH, but pin 8 will be LOW instead.
Code: [Select]
// THIS DOES NOT WORK ON THE DUE, PIN 8 WILL BE LOW
class pin {
 public:
   pin() {
     pinMode(8, OUTPUT);
     digitalWrite(8, HIGH);
   int z;
class pin x;
 x.z++;
If I put the constructor call into the setup(), it will work. So this is fine and pin 8 will be HIGH:
Code: [Select]
class pin {
 public:
   pin() {
     pinMode(8, OUTPUT);
   int z;
 class pin x;
 x.z++;
On the Uno, both examples produce HIGH at pin 8.
Any ideas? Did I miss something? I had looked into this forum, but did not see any thead about this topic.
Unfortunately this currently breaks my library: During the constructor call a do a low active reset on an external device. Of course i expect, that the output pin stays HIGH within setup() and loop(). But this is not true and my external device will be put into reset again.
Oliver
AWOL
In your first example, your constructor runs before "init()".
Take a look at the source of "init()".
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
olikraus
hmmm good hint. So here is the main loop (objdump):
Code: [Select]
int main( void )
   802a4: b508      push {r3, lr}
init();
   802a6: f000 fc83 bl 80bb0 <init>
delay(1);
   802aa: 2001      movs r0, #1
   802ac: f000 fd76 bl 80d9c <delay>
#if defined(USBCON)
USBDevice.attach();
   802b0: 4806      ldr r0, [pc, #24] ; (802cc <main+0x28>)
   802b2: f000 f849 bl 80348 <_ZN10USBDevice_6attachEv>
#endif
setup();
   802b6: f7ff ff35 bl 80124 <setup>
for (;;)
loop();
   802ba: f7ff ff3b bl 80134 <loop>
if (serialEventRun) serialEventRun();
And, yes, fully correct, the "init()" code includes this:
Code: [Select]
// Disable pull-up on every pin
  for (int i = 0; i < PINS_COUNT; i++)
   80bea: e004      b.n 80bf6 <init+0x46>
  digitalWrite(i, LOW);
Thanks AWOL. Good point.
I expect that this will break many existing libs...
Oliver
AWOL
Quote
which is why many libraries have a "begin" method which must be explicitly called.
olikraus
hmmm... I never had seen this relationship. Thanks for clarification. Karma+
Oliver
