Author Topic: [Solved] Are pins forced to LOW after constructor calls?  (Read 361 times)
Germany
Online Online
If you believe something is right, you won't see what's wrong (David Straker).
On my Due i have the following code (Arduino IDE 1.5.2). It should force pin 8 to HIGH, but pin 8 will be LOW instead.
// THIS DOES NOT WORK ON THE DUE, PIN 8 WILL BE LOW
class pin {
  public:
    pin() {
      pinMode(8, OUTPUT);
      digitalWrite(8, HIGH);
    int z;
class pin x;
  x.z++;
If I put the constructor call into the setup(), it will work. So this is fine and pin 8 will be HIGH:
class pin {
  public:
    pin() {
      pinMode(8, OUTPUT);
    int z;
  class pin x;
  x.z++;
On the Uno, both examples produce HIGH at pin 8.
Any ideas? Did I miss something? I had looked into this forum, but did not see any thead about this topic.
Unfortunately this currently breaks my library: During the constructor call a do a low active reset on an external device. Of course i expect, that the output pin stays HIGH within setup() and loop(). But this is not true and my external device will be put into reset again.
Oliver
« Last Edit: February 22, 2013, 06:16:43 pm by olikraus » Logged
UK
Online Online
In your first example, your constructor runs before "init()".
Take a look at the source of "init()".
Germany
Online Online
hmmm good hint. So here is the main loop (objdump):
int main( void )
   802a4: b508      push {r3, lr}
init();
   802a6: f000 fc83 bl 80bb0 <init>
delay(1);
   802aa: 2001      movs r0, #1
   802ac: f000 fd76 bl 80d9c <delay>
#if defined(USBCON)
USBDevice.attach();
   802b0: 4806      ldr r0, [pc, #24] ; (802cc <main+0x28>)
   802b2: f000 f849 bl 80348 <_ZN10USBDevice_6attachEv>
#endif
setup();
   802b6: f7ff ff35 bl 80124 <setup>
for (;;)
loop();
   802ba: f7ff ff3b bl 80134 <loop>
if (serialEventRun) serialEventRun();
And, yes, fully correct, the "init()" code includes this:
// Disable pull-up on every pin
  for (int i = 0; i < PINS_COUNT; i++)
   80bea: e004      b.n 80bf6 <init+0x46>
  digitalWrite(i, LOW);
Thanks AWOL. Good point.
I expect that this will break many existing libs...
Oliver
UK
Online Online
which is why many libraries have a "begin" method which must be explicitly called.
Germany
Online Online
hmmm... I never had seen this relationship. Thanks for clarification. Karma+
Oliver
