Pages: [1] 2 3 ... 7   Go Down
Author Topic: Cosa: An Object-Oriented Platform for Arduino programming  (Read 11660 times)
Sweden
The Cosa project is slowly approaching beta test level. Time to let friends have a look.
https://github.com/mikaelpatel/Cosa
The beginning of a blog is available at http://cosa-arduino.blogspot.se/.
Hope to get time to write about the design principles and how it can be used. Or at least explain the examples and demo code in some more detail :-).
NB: Cosa is full-fledged C++ and not entry level programming. It is possible to mix Cosa and Arduino code.
Check the information on github and in the documentation (doc.zip) for more details.
Cheers!
Rapa Nui
Pukao hats cleaning services
Great! I've tried with my ST7735R and IDE 1.5.2. Works fine..  smiley
Changed /cs and a0 pins to 7 and 8 with:
ST7735R tft(Board::D7, Board::D8);
PS: I want to use it with 1284p - is the board.hh the only place to enhance?
« Last Edit: February 22, 2013, 08:42:53 pm by pito » Logged
Wow!  Costa is amazing, it beats other object-oriented event-driven systems for Arduino.
I hope people invest some time trying it.
If you are an experienced C++ programmer browse the code implementing Cosa, it has great style.
Sweden
There are some ifdef's in the different classes so Board.hh is only where you start and then you have to check adapt these classes. But if you wait a few hours or a day or so ;-) I will check more in detail whats special with the 1284p. If it is similar to 328P this is a piece of cake. Right now adding a new Board class is only part of the work.
Only boards based on ATmega328P, Atmega2560 and the ATtiny85 family are supported out of the box. Basically what I have to play with at home.
Thanks for your support with this project and taking the time to test Cosa.
Cheers
Sweden
BW: Did you test more of the ST7735 driver and the Canvas class? Would be nice to hear more about this and especially the graphics script engine I have put in there. There are some examples on this.
There is also a simple off-screen canvas to help drawing to LCD devices such as the very cheap PCD8544 (Nokia 84x48). The driver is actually defined as an IOStream to allow direct printing with all the IOStream functions and operators (<<).
I put a lot of work into making the Trace support really easy to use on different devices. You can for instance trace directly to the ST7735 by just changing the trace.begin() parameter. The support macros follow the Linux syslog format and will include the function and line in the output. This helps debugging without a debugger ;-)
Cheers.
Rapa Nui
Yes, I'll do smiley.
The 1284p uses a separate core folder - ie. I am using the "mighty" stuff ..\hardware\arduino\avr\cores\mighty1284p\..) and pin defs in \hardware\arduino\avr\variants\mighty1284p\pins_arduino.h
Sweden
I have pushed an update with support for the ATmega1284P.
https://github.com/mikaelpatel/Cosa/commit/568177b054478886f11a3bdcfed10f6b928a430d
Needed to add a new Board class but also update Interrupt and PWM pin handling. I don't have a board with this processor so the only test I have done is verifying build with the mighty1284p arduino core (as above). Actually I only used the boards.txt file. Please test.
I really liked the spec of the ATmega1284P!
Cheers.
« Last Edit: February 23, 2013, 08:50:13 am by kowalski » Logged
Rapa Nui
It seems the uart needs a fix. 1284p has got two uarts. When running ie CosaBenchmarkThread example I do not get serial output in terminal..
Sweden
Missed that. Will have a look. But it seemed to compile alright ;-) Do you have a link to the board schematics? Which of the two UARTs are used for the serial output. I assumed UART0.
https://github.com/mikaelpatel/Cosa/commit/97d796808389a58544815ebba441e28eafe4d2bd
I have updated so the two UARTs are supported but I think there is something else that is the problem. Baudrate?
Cheers.
« Last Edit: February 23, 2013, 10:31:10 am by kowalski » Logged
Rapa Nui
What is the board spec for the UART? Do you have a link to the board schematics?
« Last Edit: February 23, 2013, 10:10:34 am by pito » Logged
Rapa Nui
Fantastic! The fastest port ever (1284p mighty @16MHz/3V3)..
CosaBenchmarkThread: started
sizeof(Thread) = 9
sizeof(Counter) = 13
113:loop:info:31 us per dispatch (496 cycles)
CosaBenchmarkRTC: started
free_memory() = 15932
Watchdog::ms_per_tick() = 16
Watchdog::get_ticks() = 0
58:setup:info:RTC::micros(): 4
63:setup:info:RTC::millis(): 4
68:setup:info:DELAY(1): 4
CosaBenchmarkFSM: started
free_memory() = 15916
sizeof(Event::Handler) = 2
sizeof(Link) = 6
sizeof(FSM) = 12
sizeof(Echo) = 14
F_CPU = 16000000
I_CPU = 16
EVENTS_MAX = 100000
132:loop:info:27 us per event (432 cycles)
CosaBenchmarkPins: started
free_memory() = 15889
sizeof(InputPin) = 4
sizeof(OutputPin) = 4
sizeof(AnalogPin) = 9
74:setup:info:Loop: 504 us per 1,000 nop loops
85:setup:info:Arduino: 6478 us per 1000 digitalRead(7)
95:setup:info:Cosa(10X): 629 us per 1000 inPin.is_set()
106:setup:info:Cosa(10X): 629 us per 1000 inPin >> var
116:setup:info:Cosa(11X): 567 us per 1000 InputPin::read(7)
128:setup:info:Arduino: 9812 us per 1000 digitalWrite(8, 1); digitalWrite(8, 0)
139:setup:info:Cosa(1X): 5032 us per 1000 outPin.write(1); outPin.write(0)
150:setup:info:Cosa(4X): 2328 us per 1000 outPin.set; outPin.clear()
161:setup:info:Cosa(4X): 2328 us per 1000 outPin << 1; outPin << 0
172:setup:info:Cosa(1X): 5535 us per 1000 OutputPin::write(8, 1); OutputPin::write(8, 0)
183:setup:info:Arduino: 9623 us per 1000 digitalWrite(8, !digitalRead(8))
193:setup:info:Cosa(2X): 3711 us per 1000 outPin.write(!outPin.read())
203:setup:info:Cosa(4X): 2139 us per 1000 outPin.is_set/clear/set()
215:setup:info:Cosa(4X): 2076 us per 1000 outPin >> var; outPin << !var
225:setup:info:Cosa(4X): 2076 us per 1000 outPin.set/is_clear()
235:setup:info:Cosa(8X): 1196 us per 1000 outPin.toggle()
245:setup:info:Cosa(3X): 3145 us per 1000 OutputPin::write(8, !OutputPin::read(8))
258:setup:info:Cosa(2X): 3271 us per 1000 OutputPin::read/write(8,0/1)
268:setup:info:Cosa(12X): 755 us per 1000 OutputPin::toggle(8)
283:setup:info:Arduino: 14 us per bit data transfer() digitalWrite()
297:setup:info:Cosa(2X): 7 us per bit data transfer() pin.write()
311:setup:info:Cosa(3X): 4 us per bit data transfer() pin.write/toggle()
325:setup:info:Cosa(1X): 9 us per bit data transfer() OutputPin::write()
339:setup:info:Cosa(3X): 4 us per bit data transfer() OutputPin::write/toggle()
373:setup:info:Cosa(4X): 3 us per bit data transfer() pin.write/toggle() unrolled
383:setup:info:Arduino: 16 us per bit data transfer() shiftOut()
393:setup:info:Cosa(4X): 4 us per bit data transfer() dataPin.write()
401:setup:info:Arduino: 112 us per analogRead()
408:setup:info:Cosa(1X): 112 us per analogPin.sample()
417:setup:info:Cosa(1X): 112 us per analogPin >> var
424:setup:info:Cosa(1X): 112 us per AnalogPin::sample()
« Last Edit: February 23, 2013, 11:17:48 am by pito » Logged
Sweden
Fantastic!
sizeof(Thread) = 9
Looking good!
Wow! Thats something I only dream of ;-). There is a lot of design in Cosa to use PROGMEM when ever possible and cut down on SRAM usage. With 16K I could put in a real RTOS with processes ;-)
Do you have the number on CosaBenchmarkPins? This shows how much faster Cosa is compared to Arduino/Wiring with regard to pin functions.
Cheers - and thanks for your effort testing Cosa!
Rapa Nui
See above.
Left Coast, CA (USA)
Measurement changes behavior
A ATmega1284P has 16KB of SRAM and is pretty simple to get working in the arduino IDE.
Lefty
There should be no problem with that much memory.
ChibiOS/RT http://www.chibios.org/dokuwiki/doku.php is a nice little preemptive RTOS that easily runs on an Uno.  It does a semaphore take plus a context switch  in 12 usec.
Giovanni Di Sirio, the author of ChibiOS wrote an experimental preemptive kernel called Nil RTOS that is really small.
I have been playing with it on Uno and each thread takes only a few bytes plus stack space.  It does a context switch a little faster than ChibiOS.
The Arduino versions are here http://code.google.com/p/rtoslibs/downloads/list.
You can really speed up pin I/O using a template class.  I just posted a library that does writes in two cycles or 0.125 usec on an Uno. That library is at the above location.
« Last Edit: February 23, 2013, 12:06:19 pm by fat16lib » Logged
Pages: [1] 2 3 ... 7   Go Up
