Sweden
« on: February 22, 2013, 04:45:34 pm » |
The Cosa project is slowly approaching beta test level. Time to let friends have a look. https://github.com/mikaelpatel/CosaThe beginning of a blog is available at http://cosa-arduino.blogspot.se/. Hope to get time to write about the design principles and how it can be used. Or at least explain the examples and demo code in some more detail :-). NB: Cosa is full-fledged C++ and not entry level programming. It is possible to mix Cosa and Arduino code. Check the information on github and in the documentation (doc.zip) for more details. Cheers!
Rapa Nui
Pukao hats cleaning services
« Reply #1 on: February 22, 2013, 08:31:35 pm » |
Great! I've tried with my ST7735R and IDE 1.5.2. Works fine..  Changed /cs and a0 pins to 7 and 8 with: ST7735R tft(Board::D7, Board::D8); PS: I want to use it with 1284p - is the board.hh the only place to enhance?
« Last Edit: February 22, 2013, 08:42:53 pm by pito »
« Reply #2 on: February 22, 2013, 10:09:30 pm » |
Wow! Costa is amazing, it beats other object-oriented event-driven systems for Arduino.
I hope people invest some time trying it.
If you are an experienced C++ programmer browse the code implementing Cosa, it has great style.
Sweden
« Reply #3 on: February 23, 2013, 05:08:47 am » |
Great! I've tried with my ST7735R and IDE 1.5.2. Works fine..  Changed /cs and a0 pins to 7 and 8 with: ST7735R tft(Board::D7, Board::D8); PS: I want to use it with 1284p - is the board.hh the only place to enhance? There are some ifdef's in the different classes so Board.hh is only where you start and then you have to check adapt these classes. But if you wait a few hours or a day or so ;-) I will check more in detail whats special with the 1284p. If it is similar to 328P this is a piece of cake. Right now adding a new Board class is only part of the work. Only boards based on ATmega328P, Atmega2560 and the ATtiny85 family are supported out of the box. Basically what I have to play with at home. Thanks for your support with this project and taking the time to test Cosa. Cheers
Sweden
« Reply #4 on: February 23, 2013, 05:19:56 am » |
Great! I've tried with my ST7735R and IDE 1.5.2. Works fine..  Changed /cs and a0 pins to 7 and 8 with: ST7735R tft(Board::D7, Board::D8); PS: I want to use it with 1284p - is the board.hh the only place to enhance? BW: Did you test more of the ST7735 driver and the Canvas class? Would be nice to hear more about this and especially the graphics script engine I have put in there. There are some examples on this. There is also a simple off-screen canvas to help drawing to LCD devices such as the very cheap PCD8544 (Nokia 84x48). The driver is actually defined as an IOStream to allow direct printing with all the IOStream functions and operators (<<). I put a lot of work into making the Trace support really easy to use on different devices. You can for instance trace directly to the ST7735 by just changing the trace.begin() parameter. The support macros follow the Linux syslog format and will include the function and line in the output. This helps debugging without a debugger ;-) Cheers.
Rapa Nui
« Reply #5 on: February 23, 2013, 06:38:41 am » |
But if you wait a few hours or a day or so ;-) I will check more in detail whats special with the 1284p. Yes, I'll do  . The 1284p uses a separate core folder - ie. I am using the "mighty" stuff ..\hardware\arduino\avr\cores\mighty1284p\..) and pin defs in \hardware\arduino\avr\variants\mighty1284p\pins_arduino.h
Sweden
« Reply #6 on: February 23, 2013, 08:45:11 am » |
But if you wait a few hours or a day or so ;-) I will check more in detail whats special with the 1284p. Yes, I'll do  . The 1284p uses a separate core folder - ie. I am using the "mighty" stuff ..\hardware\arduino\avr\cores\mighty1284p\..) and pin defs in \hardware\arduino\avr\variants\mighty1284p\pins_arduino.h I have pushed an update with support for the ATmega1284P. https://github.com/mikaelpatel/Cosa/commit/568177b054478886f11a3bdcfed10f6b928a430dNeeded to add a new Board class but also update Interrupt and PWM pin handling. I don't have a board with this processor so the only test I have done is verifying build with the mighty1284p arduino core (as above). Actually I only used the boards.txt file. Please test. I really liked the spec of the ATmega1284P! Cheers.
« Last Edit: February 23, 2013, 08:50:13 am by kowalski »
Rapa Nui
« Reply #7 on: February 23, 2013, 09:17:23 am » |
It seems the uart needs a fix. 1284p has got two uarts. When running ie CosaBenchmarkThread example I do not get serial output in terminal..
Sweden
« Reply #8 on: February 23, 2013, 09:46:27 am » |
Missed that. Will have a look. But it seemed to compile alright ;-) Do you have a link to the board schematics? Which of the two UARTs are used for the serial output. I assumed UART0. https://github.com/mikaelpatel/Cosa/commit/97d796808389a58544815ebba441e28eafe4d2bdI have updated so the two UARTs are supported but I think there is something else that is the problem. Baudrate? Cheers.
« Last Edit: February 23, 2013, 10:31:10 am by kowalski »
Rapa Nui
« Reply #9 on: February 23, 2013, 10:08:26 am » |
What is the board spec for the UART? Do you have a link to the board schematics?
« Last Edit: February 23, 2013, 10:10:34 am by pito »
Rapa Nui
« Reply #10 on: February 23, 2013, 10:35:59 am » |
Fantastic! The fastest port ever (1284p mighty @16MHz/3V3).. CosaBenchmarkThread: started sizeof(Thread) = 9 sizeof(Counter) = 13 113:loop:info:31 us per dispatch (496 cycles) 113:loop:info:31 us per dispatch (496 cycles) 113:loop:info:31 us per dispatch (496 cycles)
CosaBenchmarkRTC: started free_memory() = 15932 Watchdog::ms_per_tick() = 16 Watchdog::get_ticks() = 0 58:setup:info:RTC::micros(): 4 63:setup:info:RTC::millis(): 4 68:setup:info:DELAY(1): 4
CosaBenchmarkFSM: started free_memory() = 15916 sizeof(Event::Handler) = 2 sizeof(Link) = 6 sizeof(FSM) = 12 sizeof(Echo) = 14 F_CPU = 16000000 I_CPU = 16 EVENTS_MAX = 100000 132:loop:info:27 us per event (432 cycles) 132:loop:info:27 us per event (432 cycles) 132:loop:info:27 us per event (432 cycles)
CosaBenchmarkPins: started free_memory() = 15889 sizeof(Event::Handler) = 2 sizeof(InputPin) = 4 sizeof(OutputPin) = 4 sizeof(AnalogPin) = 9 74:setup:info:Loop: 504 us per 1,000 nop loops
85:setup:info:Arduino: 6478 us per 1000 digitalRead(7) 95:setup:info:Cosa(10X): 629 us per 1000 inPin.is_set() 106:setup:info:Cosa(10X): 629 us per 1000 inPin >> var 116:setup:info:Cosa(11X): 567 us per 1000 InputPin::read(7)
128:setup:info:Arduino: 9812 us per 1000 digitalWrite(8, 1); digitalWrite(8, 0) 139:setup:info:Cosa(1X): 5032 us per 1000 outPin.write(1); outPin.write(0) 150:setup:info:Cosa(4X): 2328 us per 1000 outPin.set; outPin.clear() 161:setup:info:Cosa(4X): 2328 us per 1000 outPin << 1; outPin << 0 172:setup:info:Cosa(1X): 5535 us per 1000 OutputPin::write(8, 1); OutputPin::write(8, 0)
183:setup:info:Arduino: 9623 us per 1000 digitalWrite(8, !digitalRead(8)) 193:setup:info:Cosa(2X): 3711 us per 1000 outPin.write(!outPin.read()) 203:setup:info:Cosa(4X): 2139 us per 1000 outPin.is_set/clear/set() 215:setup:info:Cosa(4X): 2076 us per 1000 outPin >> var; outPin << !var 225:setup:info:Cosa(4X): 2076 us per 1000 outPin.set/is_clear() 235:setup:info:Cosa(8X): 1196 us per 1000 outPin.toggle() 245:setup:info:Cosa(3X): 3145 us per 1000 OutputPin::write(8, !OutputPin::read(8)) 258:setup:info:Cosa(2X): 3271 us per 1000 OutputPin::read/write(8,0/1) 268:setup:info:Cosa(12X): 755 us per 1000 OutputPin::toggle(8)
283:setup:info:Arduino: 14 us per bit data transfer() digitalWrite() 297:setup:info:Cosa(2X): 7 us per bit data transfer() pin.write() 311:setup:info:Cosa(3X): 4 us per bit data transfer() pin.write/toggle() 325:setup:info:Cosa(1X): 9 us per bit data transfer() OutputPin::write() 339:setup:info:Cosa(3X): 4 us per bit data transfer() OutputPin::write/toggle() 373:setup:info:Cosa(4X): 3 us per bit data transfer() pin.write/toggle() unrolled
383:setup:info:Arduino: 16 us per bit data transfer() shiftOut() 393:setup:info:Cosa(4X): 4 us per bit data transfer() dataPin.write()
401:setup:info:Arduino: 112 us per analogRead() 408:setup:info:Cosa(1X): 112 us per analogPin.sample() 417:setup:info:Cosa(1X): 112 us per analogPin >> var 424:setup:info:Cosa(1X): 112 us per AnalogPin::sample()
« Last Edit: February 23, 2013, 11:17:48 am by pito »
Sweden
« Reply #11 on: February 23, 2013, 10:47:28 am » |
Fantastic! CosaBenchmarkThread: started sizeof(Thread) = 9 sizeof(Counter) = 13 113:loop:info:31 us per dispatch (496 cycles)
Looking good! free_memory() = 15916 Wow! Thats something I only dream of ;-). There is a lot of design in Cosa to use PROGMEM when ever possible and cut down on SRAM usage. With 16K I could put in a real RTOS with processes ;-) Do you have the number on CosaBenchmarkPins? This shows how much faster Cosa is compared to Arduino/Wiring with regard to pin functions. Cheers - and thanks for your effort testing Cosa!
Rapa Nui
« Reply #12 on: February 23, 2013, 11:14:18 am » |
Do you have the number on CosaBenchmarkPins? See above.
Left Coast, CA (USA)
Measurement changes behavior
« Reply #13 on: February 23, 2013, 11:15:47 am » |
With 16K I could put in a real RTOS with processes ;-) A ATmega1284P has 16KB of SRAM and is pretty simple to get working in the arduino IDE. Lefty
« Reply #14 on: February 23, 2013, 11:48:59 am » |
There should be no problem with that much memory. ChibiOS/RT http://www.chibios.org/dokuwiki/doku.php is a nice little preemptive RTOS that easily runs on an Uno. It does a semaphore take plus a context switch in 12 usec. Giovanni Di Sirio, the author of ChibiOS wrote an experimental preemptive kernel called Nil RTOS that is really small. I have been playing with it on Uno and each thread takes only a few bytes plus stack space. It does a context switch a little faster than ChibiOS. The Arduino versions are here http://code.google.com/p/rtoslibs/downloads/list. You can really speed up pin I/O using a template class. I just posted a library that does writes in two cycles or 0.125 usec on an Uno. That library is at the above location.
« Last Edit: February 23, 2013, 12:06:19 pm by fat16lib »
