Topic: switching an inductor (Read 4737 times) previous topic - next topic
raschemmel
Quote
No, it will explode - did you read my previous post?
I think the damage will extend to everything but the inductor. I don't think it would be damaged.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
MarkT
You might cause insulation breakdown in the inductor too...
You know how old car ignitions worked?  Basically like this but with a much
smaller coil.
Paul__B
OK, looked at your reference.
Nowhere does it make any suggestion whatsoever for a need to vary, or benefit to varying,  the inductance.
There is no theoretical reason for doing so.
The purpose of the inductor is a low-pass filter to maintain a relatively constant current from the rectifiers which is going to be more efficient in the coils of the generator and presumably improve the excitation current, but it is not in a resonant circuit (in fact, resonance would be extremely undesirable) of any sort so there is no requirement for "tuning".
Therefore the maximum inductance will be essentially equally effective for any generator frequency.
raschemmel
#33
Feb 26, 2015, 03:48 am Last Edit: Feb 26, 2015, 03:52 am by raschemmel
Quote
C. Diode Bridge Rectifier and DC Link
Three phase diode bridge rectifier is used to convert
variable magnitude, variable frequency voltage at the
induction generator terminal into DC voltage [3].
Quote
Input transformer's turns ratio is 1:ηi The series reactor
(L) and shunt reactor (C) acts as an input filter. The current
ripples and voltage ripples are reduced by using the above
components [5].
Dc Link current is governed by the following equation
(1/ )( ) dc dc r i dc dc pi = L V −V − r i (10)
Where, RDC and LDC are the reactor resistance and
inductance respectively.
Quote
D. PWM Inverter
The output power of the rectifier is filtered by using the
LC filter
. By using PWM inverter DC power is converted
into AC power employing double edge sinusoidal pulse
width modulation technique [5]. The PWM signals are used
to switch on the IGBT's in the inverter. The IGBT's are
connected anti parallel with the diodes. If diode conducts,
energy is fed back to the source. A carrier wave is compared
with the reference signal corresponding to a phase to
generate gating signals. The instantaneous line - to - line
output voltage is Vab = VS (g1-g3).
"shunt reactor " ? (where is that ?)
Boardburner2
Sorry to disagree but.
Varying the inductance was a classical way of controlling the output voltage back in the day.
When I first experimented with this gear modern switchmode convertors were not commonly used.
Its not just frequency but voltage at work.
With variable speed from wind you get variable voltage as well.
No it does not but my previous experience suggests otherwise and I never found a means to explain it at the time.
But it fails to describe the implementation of the dc bridge and size of motor yet elsewhere says that it does not work well for small motors.
I have time on my hands and thought I would try to devise an experiment to verify.
raschemmel
The output power of a wind generator is a function of the work (wind power) put into it, not the variation
of an LC filter.  The output of the motor is AC which then rectified and the output stage is essential an inverter that functions like any other inverter, having a DC input voltage and IGBTs which turn on or off to
provide the positive and negative phases of the output AC voltage. I have to side with Paul that there is no basis for varying the inductance of a filter. I think you are just fiddling with the design without adequate background in power electronics design.
Boardburner2
#36
Feb 26, 2015, 04:55 am Last Edit: Feb 26, 2015, 03:35 pm by Boardburner2
You are quite correct.
Earlier experiments i did however did not agree with accepted theory.
Smaller motors do not seem to obey the same 'laws'.
No one seems to have addressed this adequately and I think the published papers have 'holes' in them as well
❝Input transformer's turns ratio is 1:ηi
I take that to mean an unspecified capacitor but not sure.
What input transformer ?
All I can see is a coil
Its not a huge problem just something I would like to satisfy my curiosity on.
I am trying to devise a not to expensive experimental setup to satisfy that.
The practical solution is to use a permanent magnet generator for small systems but in the uk its probably much better to go for solar rather than wind.
Yes but with with IMAG the normal capacitive filtering does not work and inductive seems to fail also under some circumstances (which I do not know).
mauried
Do you actually have the Inductor to do this?
Transformers cant be used as Inductors if DC is going thru them , as without an air gap in the core, which inductors used in lo pass filters have , the transformer will simply saturate.
Paul__B
I think it is a relative.
Boardburner2
No as per first post.
Been looking for an old variable one for years but they just do not seem to come up these days.
Late 60s I inherited some of an ex amateurs shack which had one.
But I discarded it as I could not pick it up....
raschemmel
Quote
That's a FLUX CAPACITOR
FLUX CAPACTIOR (necessary to achieve 1.21 Jigowatts of power)
Boardburner2
Well as per my sig I have fried a few boards in my time.
