Topic: Passing I/O functions to a class. (Read 3867 times) previous topic - next topic
OutOfLine
Proof?
https://github.com/reppr/pulses
Comment/uncomment  '#define USE_F_MACRO' in Menu.h
to switch between using Arduino F() macro or a noop replacement.
I told the menu to display free RAM for these tests, btw.
For testing PROGMEM support you would need the latest version with PROGMEM storage support.
Log message says "Switching PROGMEM for tests.".
(Yes I *do* know that this version reads progmem strings as char instead of unsigned char, breaking string display.
  I don't care, should not influence the test.)
The numbers you get will differ by a few bytes, as the versions are not absolutely identical.
The "Testing using Arduino F() macro only. " commit has some additional functionality even.
RAM usage increases by 6 bytes when using the menu the very first time. I don't even know why.
I gave startup values for RAM usage.
nickgammon
Quote
Binary sketch size: 7,206 bytes             Binary sketch size: 7,534 bytes
  RAM: 465                                              RAM: 1525
OK, so that is free RAM? The higher the better?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
OutOfLine
Quote
  RAM: 465                                              RAM: 1525
Yes, I hope so ;)
The code in  Menu::get_free_RAM()  is code I once copied (probably from the Arduino page) and have used for several years. I did not do real testing about the exact meaning of the result. Would be interested to learn more about that, btw.
Code: [Select]
int Menu::get_free_RAM() const {
  int free;
  extern int __bss_end;
  extern void *__brkval;
  if ((int) __brkval == 0)
    return ((int) &free) - ((int) &__bss_end);
    return ((int) &free) - ((int) __brkval);
