Offline
Newbie
« on: February 23, 2013, 04:02:20 am » |
Hi everybody ! I'm new here  I'm using Arduino for 2 years, but now i'm trying to do something more difficult. I'm having problems with my new Car Controller. I use : - LCD DfRobot Keypad - Keypad BV4605 I2C - Arduino Uno R2 (Powered by Vin)- Max Converter SPI For Temperature - A BreadBoard With Alimmentation 5 and 3.3 Each Side My problems, After 1 minute, Serial print "... Of memory EEPROM"I Know my Code is not Perfect ... and not finished !If you have Any tweak, Tell me  Ps: Sorry for mistake of language, i'm French. #include <LiquidCrystal.h> #include <MAX31855.h> #include <DFR_Key.h> #include <Wire.h> #include <bv4506.h> #include <I2c_bv.h> #include <EEPROMEx.h>
//Keypad 3X4 BV4506 keypad(0x31); int keypadDown; long clavierBkT; boolean clavierBk = false;
DFR_Key keypadLCD; LiquidCrystal lcd(8, 9, 4, 5, 6, 7); double voltage,voltageR,voltageC; int count, clavier = 0, clavierP;
//Action int waitingA = 0;
//message String mBuffer1,mBuffer2,mBuffer3,mBuffer4; int countB; boolean mBufferM;
//Thermocouple // ***** PIN DEFINITIONS ***** Thermocouple const unsigned char thermocoupleSO = 13; const unsigned char thermocoupleCS = 12; const unsigned char thermocoupleCLK = 11; // Declaration MAX31855 MAX31855(thermocoupleSO, thermocoupleCS, thermocoupleCLK);
//Gestion du loggage int logged = 0; String passTemp, passCar = String(EEPROM.readInt(10)); void setup() { //Serial for test Serial.begin(115200); Serial.println("Demarrage"); //Keypad Wire.begin(); //LCD lcd.begin(16, 2); lcd.clear(); lcd.setCursor(0,1); //pinMode(2, INPUT); // Hall sensor //digitalWrite(2, HIGH); //Demarrage lcd.print("Cumpu-Benda"); delay(1000); lcd.clear();
// Init Boucle count = 0;
void loop() { //Keypad
//Login if (logged == 0) { lcd.setCursor(0,0); lcd.print("Identification:"); if (touchePresser()) { lcd.setCursor(0,1); switch (passAppend(clavierP)) { case 1: //Bon lcd.print("Ok"); delay(1000); lcd.clear(); logged = 1; Serial.println("Logged In"); break; case 2: //Faux lcd.print("Error Password"); delay(1000); lcd.clear(); break; case 3: //Etoile for (int i=0; i < passTemp.length(); i++){ lcd.print("*"); } break; } }
} else { double Vcc; unsigned int ADCValue; Vcc = readVcc()/1000.0; ADCValue = analogRead(1); voltage = voltage + ( (ADCValue / 1023.0) * Vcc ); count++; keypad.clear(); clavier = keypadLCD.getKey(); if (clavier == SAMPLE_WAIT) clavier = 0; if (action(-2)) { //Faire action plutot que de gerer le reste } else if (touchePresser()) { //menu keypad Action Serial.println("action keypad"); action(clavierP); }//Fin menu keypad if (messageBuffer()) { // Gestion de l'affichage forcer } else { // Action au LCD detecter if (count >= 200) { if (clavier == 3) { lcd.clear(); voltageC = voltage/count; voltageR = (voltageC * 2.7428571) + 2.16; lcd.setCursor(0,0); lcd.print("Tension Vin"); lcd.setCursor(0,1); lcd.print(voltageR); lcd.setCursor(6,1); lcd.print(voltageC); } else if (clavier == 2) { lcd.clear(); voltageC = voltage/count; lcd.setCursor(0,0); voltageR = (voltageC * 2.7428571) + 2.16; float tensionpourcent = fmap(voltageR, 11.80, 13.50, 0.00, 100); lcd.print(tensionpourcent); lcd.setCursor(7,0); lcd.print("%"); lcd.setCursor(0,1); lcd.print(MAX31855.readThermocouple(CELSIUS)); } else if (clavier == 4) { lcd.clear(); lcd.setCursor(0,1); lcd.print(clavierP); lcd.setCursor(0,0); lcd.print(keypadDown); } voltage = 0; voltageR = 0; voltageC = 0; count = 0; } }//Fin detection clavier LCD }//Fin logged =1 } // fin loop
float fmap(float x, float in_min, float in_max, float out_min, float out_max) { return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min; }
long readVcc() { long result; // Read 1.1V reference against AVcc ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); delay(2); // Wait for Vref to settle ADCSRA |= _BV(ADSC); // Convert while (bit_is_set(ADCSRA,ADSC)); result = ADCL; result |= ADCH<<8; //result = 1125300L / result; // Back-calculate AVcc in mV 4.48 meurer / 4.07 arduino result = (((1.1*6.25)/(5.161))*1023*1000) / result; // Back-calculate AVcc in mV return result; } // //Gestion du loggin // //Password / Menu / Clavier //PassAppend int passAppend (int toucheC) { // On ajoute a la variable passTemp = passTemp + String(toucheC); // On verifie qu'il fait la longueur du pass if (passTemp.length() >= passCar.length()) { // Si oui On verifie qu'il est identique au pass if (passTemp == passCar) { // Si oui on renvoie true return 1; } // Sinon on efface et renvoie false et efface le screen else { passReset(); return 2; } //Sinon On ajoute une étoile au screen } else return 3; }
//PassReset String passReset() { passTemp =""; return "Pass Clear"; }
//PassSet String passSet(int pass) { if (EEPROM.updateInt(0, pass)) return "Pass Set"; else return "Error Set Pass"; }
// //Getion des messages sous forme de buffer // boolean messageBuffer() {
if ((mBuffer1 != "") && ( mBuffer1 != "" )) { if ((mBuffer3 != "") && ( mBuffer4 != "" )) { countB++; if(countB == 300) {mBufferM = true; lcd.clear();} if (countB > 600) {countB = 0; mBufferM = false; lcd.clear();} if (mBufferM) { lcd.setCursor(0,0); lcd.print(mBuffer3); lcd.setCursor(0,1); lcd.print(mBuffer4); } else{ lcd.setCursor(0,0); lcd.print(mBuffer1); lcd.setCursor(0,1); lcd.print(mBuffer2); } } else { lcd.setCursor(0,0); lcd.print(mBuffer1); lcd.setCursor(0,1); lcd.print(mBuffer2); countB = 0; } return true; } else{ return false; countB = 0; }
} boolean messageBufferErase() { mBuffer1 = ""; mBuffer2 = ""; mBuffer3 = ""; mBuffer4 = ""; } // //Gestion des actions // boolean action(int numero) { switch (numero) { case 1: //1 Allumage if (waitingA == 0) { //Verifie qu'il n'y a pas de demande de confirmation mBuffer1 = "Valider :"; mBuffer2 = "Pre-Allumage"; mBuffer3 = "* Pour Oui"; mBuffer4 = "# Pour Non"; waitingA = 1; } break; case 2: //2 Allumage Bobine break; case 3: //3 Demarreur break; case 9: //9 Set password break; case -2: //-1 Verifs action if (waitingA == 0) return false; switch (waitingA) { case 1: //1 Allumage /1 valider /2 Annuler if (touchePresser()) { if (clavierP == 10) {}//demarrer else if (clavierP == 11) // Quitter { Serial.println("annulation"); messageBufferErase(); waitingA = 0; } } break; } return true; break; } }
boolean touchePresser() { if (clavierBkT + 100 < millis()) { if (clavierBk == false) { clavierBkT = millis(); if (keypad.down() == 1) {clavierBk = true; clavierP = keypad.key(); Serial.println("Clavier P: "+String(clavierP)); return true;} } else { clavierBkT = millis(); if (keypad.down() == 0) {clavierBk = false;} } } return false; }
« Last Edit: February 23, 2013, 04:04:23 am by benda95280 »
Logged
UK
Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
« Reply #1 on: February 23, 2013, 07:20:32 am » |
Well, immediately I see an issue: ... String mBuffer1,mBuffer2,mBuffer3,mBuffer4; ... String passTemp, passCar = String(EEPROM.readInt(10)); ...
You're using Strings. Ditch them and use character arrays and you'll probably see all your problems disappear.
Logged
Offline
Newbie
« Reply #2 on: February 23, 2013, 09:02:25 am » |
I've try to change that: GuessTheNumber.ino: In function 'char passReset()': GuessTheNumber:235: error: invalid conversion from 'const char*' to 'char' GuessTheNumber.ino: In function 'char passSet(int)': GuessTheNumber:241: error: invalid conversion from 'const char*' to 'char' #include <LiquidCrystal.h> #include <MAX31855.h> #include <DFR_Key.h> #include <Wire.h> #include <bv4506.h> #include <I2c_bv.h> #include <EEPROMEx.h>
//message char mBuffer1,mBuffer2,mBuffer3,mBuffer4; int countB; boolean mBufferM;
//Gestion du loggage int logged = 0; char passTemp, passCar = EEPROM.readInt(10); void setup() { //Serial for test Serial.begin(115200); Serial.println("Demarrage"); //Keypad Wire.begin(); //LCD lcd.begin(16, 2); lcd.clear(); lcd.setCursor(0,1); //pinMode(2, INPUT); // Hall sensor //digitalWrite(2, HIGH); //Demarrage lcd.print("Cumpu-Benda"); delay(1000); lcd.clear();
//Login if (logged == 0) { lcd.setCursor(0,0); lcd.print("Identification:"); if (touchePresser()) { lcd.setCursor(0,1); switch (passAppend(clavierP)) { case 1: //Bon lcd.print("Ok"); delay(1000); lcd.clear(); logged = 1; Serial.println("Logged In"); break; case 2: //Faux lcd.print("Error Password"); delay(1000); lcd.clear(); break; case 3: //Etoile for (int i=0; i < sizeof(passTemp); i++){ lcd.print("*"); } break; } }
long readVcc() { long result; // Read 1.1V reference against AVcc ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); delay(2); // Wait for Vref to settle ADCSRA |= _BV(ADSC); // Convert while (bit_is_set(ADCSRA,ADSC)); result = ADCL; result |= ADCH<<8; //result = 1125300L / result; // Back-calculate AVcc in mV 4.48 meurer / 4.07 arduino result = (((1.1*6.25)/(5.161))*1023*1000) / result; // Back-calculate AVcc in mV return result; } // //Gestion du loggin // //Password / Menu / Clavier //PassAppend int passAppend (int toucheC) { // On ajoute a la variable passTemp = passTemp + char(toucheC); // On verifie qu'il fait la longueur du pass if (sizeof(passTemp) >= sizeof(passCar)) { // Si oui On verifie qu'il est identique au pass if (passTemp == passCar) { // Si oui on renvoie true return 1; } // Sinon on efface et renvoie false et efface le screen else { passReset(); return 2; } //Sinon On ajoute une étoile au screen } else return 3; }
//PassReset char passReset() { passTemp = ""; return "Pass Clear"; }
//PassSet char passSet(int pass) { if (EEPROM.updateInt(0, pass)) return "Pass Set"; else return "Error Set Pass"; }
boolean touchePresser() { if (clavierBkT + 100 < millis()) { if (clavierBk == false) { clavierBkT = millis(); if (keypad.down() == 1) {clavierBk = true; clavierP = keypad.key(); Serial.println("Clavier P: "+char(clavierP)); return true;} } else { clavierBkT = millis(); if (keypad.down() == 0) {clavierBk = false;} } } return false; }
Logged
UK
Offline
Edison Member
« Reply #3 on: February 23, 2013, 09:04:21 am » |
"char variable" stores one character.
"char *variable" points to a block of memory that can contain characters
"char variable[20]" reserves a block of 20 bytes in memory and points to it.
Now you tell me what's wrong.
Logged
UK
Offline
Edison Member
« Reply #4 on: February 23, 2013, 09:15:27 am » |
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #5 on: February 23, 2013, 09:32:12 am » |
"char *variable" points to a block of memory that can contain characters A slight correction. variable can be pointed to a block of memory. By itself, it simply defines a variable that is a pointer. That pointer then must be explicitly pointed to a block of memory. Many of the problems with pointers are caused by assuming that a pointer points to a block of memory when it does not, or when the block it points to is read-only or too small.
Logged
Offline
Newbie
« Reply #6 on: February 23, 2013, 06:11:10 pm » |
But, for a password, it need to be empty at start ?!
Logged
UK
Offline
Edison Member
« Reply #7 on: February 23, 2013, 06:43:48 pm » |
What is empty? Memory can never be empty. For it to be empty it would have to vanish. A block of memory, pointed to by a char * variable, will always contain something. Even if that is just all character 0, it's still full of it. If you'd read that page I posted you'd know that a char array "string" contains a series of characters terminated by the character 0 (that's not the ASCII character 0, but the actual numeric value 0, 8 bits all set to 0), so an "empty" string would be no characters terminated by the character 0. And for you to put something in there it doesn't have to be "empty" in the first place - you will just overwrite what is in there already, even if it's just garbage. char password[30];
getMyPassword(password); // fictitious function that gets a password from the user.
if (strcmp(password, "letmein") == 0) { Serial.println("You entered the right password."); } else { Serial.print("Sorry, "); Serial.print(password); Serial.println(" isn't the right password. Try again."); }
Logged
Offline
Newbie
« Reply #8 on: February 24, 2013, 01:49:20 pm » |
Thanks for you answer, I've try to use Char. When writing char passCar; passCar = EEPROM.readInt(10); Passcar return "9" And Serial print : "outside of EEPROM memory" With char* passCar; passCar = EEPROM.readInt(10); Return GuessTheNumber:53: error: invalid conversion from 'uint16_t' to 'char*'Sketch Size: 11042 on 32256
Logged
UK
Offline
Edison Member
« Reply #9 on: February 24, 2013, 01:54:00 pm » |
Spot the disparity:
char passCar;
Logged
Offline
Newbie
« Reply #10 on: February 24, 2013, 02:00:22 pm » |
Logged
UK
Offline
Edison Member
« Reply #11 on: February 24, 2013, 02:03:43 pm » |
A byte is an unsigned char. They are both 8 bits in size. I can't see it causing your problem though. Have you determined at which point in your program this message is being generated?
Logged
Offline
Newbie
« Reply #12 on: February 24, 2013, 03:35:50 pm » |
The message about Eeprom is shown when i press a key on the Keypad. Example : When key pressed it have to show : Serial.println("Clavier P: "+char(clavierP)); 1 times show : 2: avier P: 3: lavier P: 4: om memory 5: Out of Eeprom mem 6: 255 7: Clavier P: 8: Strange Characters ...
And SPI bus do something Crazy like return ~10 times the goog key and after return 255
Logged
Offline
Newbie
« Reply #13 on: February 24, 2013, 03:47:22 pm » |
With : EEPROM.writeByte(10, '12345'); (char) => carPass = EEPROM.readByte(10); Return 5
EEPROM.writeByte(10, 12345); (char) => carPass = EEPROM.readByte(10); Return 9
Logged
UK
Offline
Edison Member
« Reply #14 on: February 24, 2013, 04:55:16 pm » |
By doing that you are inadvertantly using the String class still. You'd be much better doing: Serial.print("Clavier P: ") Serial.println((char)clavierP);
Logged
