Loading...
Pages: [1]   Go Down
Author Topic: Tea5767 speaker/sound issues  (Read 350 times)
Offline Offline
Newbie
View Profile
This is my ninth project, and I am having issues even hearing this radio. I've finished all of the work for this system, but am having issues detecting any sound. The snippets of audio code that are placed in at various points aren't working. Everything does work on the serial monitor, but have yet to get a antenna to boost the range of the radio. Can someone help me properly insert the code for the speaker? Any assistance would be appreciated.
Scratch built project courtesy of Instructables.com and smonk1: "http://www.instructables.com/id/TEA5767-FM-Radio-Breakout-Board-for-Arduino/step4/Attach-to-Arduino/"
Here is the unhashed code courtesy of "http://www.electronicsblog.n":
Code:
/// Arduino FM receiver with TEA5767
#include <Wire.h>
#include <LiquidCrystal.h>
unsigned char search_mode=0;
int b=0;
int c=0;
#define Button_next 30
#define Button_prev 31
unsigned char frequencyH=0;
unsigned char frequencyL=0;
unsigned int frequencyB;
double frequency=0;
double freq_available=0;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); ///this is the configuration for my lcd screen
  Wire.begin();
/// buttons
  pinMode(Button_next, INPUT);
  digitalWrite(Button_next, HIGH); //pull up resistor
  pinMode(Button_prev, INPUT);
  digitalWrite(Button_prev, HIGH); //pull up resistor
    frequency=87.5; //starting frequency
    frequencyB=4*(frequency*1000000+225000)/32768; //calculating
    frequencyH=frequencyB>>8;
    frequencyL=frequencyB&0XFF;
  delay(200);
  Wire.beginTransmission(0x60); //writing TEA5767
    Wire.write(frequencyH);
    Wire.write(frequencyL);
    Wire.write(byte(0xB0));
    Wire.write(byte(0x10));
    Wire.write(byte(0x00));
    Wire.endTransmission();
  unsigned char buffer[5];
  lcd.setCursor(0, 0);
  Wire.requestFrom(0x60,5); //reading TEA5767
  if (Wire.available())
      for (int i=0; i<5; i++)
        buffer[i]= Wire.read();
        freq_available=(((buffer[0]&0x3F)<<8)+buffer[1])*32768/4-225000;
        Serial.print("FM ");
        Serial.print((freq_available/1000000));
        frequencyH=((buffer[0]&0x3F));
        frequencyL=buffer[1];
if (search_mode)
if(buffer[0]&0x80) search_mode=0;
  if (search_mode==1)
    Serial.print(" SCAN");
    else { Serial.print(" ");
  lcd.setCursor(0, 1);
Serial.print("Level: ");
Serial.print((buffer[3]>>4));
 Serial.print("/16 ");
if (buffer[2]&0x80)
  Serial.print("STEREO ");
else Serial.print("MONO ");
///// buttons read
//////////// button_next//////////
if (!digitalRead(Button_next)&&!b)
frequency=(freq_available/1000000)+0.05;
frequencyB=4*(frequency*1000000+225000)/32768+1;
Wire.write(byte(0x1F));
  delay(200);
b=100;
if (!digitalRead(Button_next)&&b==1)
///scannnn UP
search_mode=1;
Wire.write(frequencyH+0x40);
Wire.write(byte(0xD0));
  delay(200);
b=100;
if (!b==0) b--;
//////////// button_prev//////////
if (!digitalRead(Button_prev)&&!c)
frequency=(freq_available/1000000)-0.05;
frequencyH=frequencyB>>8; frequencyL=frequencyB&0XFF;
c=100;
  delay(200);
if (!digitalRead(Button_prev)&&c==1)
///scannnn DOWN
search_mode=1;
Wire.write(byte(0x50));
  delay(200);
c=100;
if (!c==0) c--;
Logged
Offline Offline
Edison Member
View Profile
This is the link, http://www.electronicsblog.net/arduino-fm-receiver-with-tea5767/
I don't understand your question, you would like some code for the speaker ?
You can't connect a speaker to the output of the module.
You should use an amplifier.
Logged
Pages: [1]   Go Up
Print
Jump to:
