Topic: Arduino 1.0.3 - Arduino Uno and ATTiny85 problems (video included) (Read 8638 times) previous topic - next topic
andrepcg
Feb 23, 2013, 04:53 pm Last Edit: Feb 23, 2013, 05:51 pm by andrepcg Reason: 1
Hi there! I'm having some troubles with my attiny85 and arduino uno. I'm using this for the attiny85 core http://code.google.com/p/arduino-tiny/
I've already uploaded the Arduino ISP sketch to the arduino Uno with no problems. After doing that the Board is defined as Attiny85 internal 8 MHz clock, programmer is Arduino as ISP.
The blink sketch is loaded and the led port is defined as 1. On the attiny the led is connected to port 0. (I'm doing this because the led was blinking when uploading the sketch and I needed to know if it was the sketch running or some boot stuff -> it was boot stuff).
Now I tested the sketch upload with 2 methods:
1) Just connecting arduino uno and pressing Upload sketch button
2) Connecting arduino uno, holding reset and just when "Binary sketch..." shows in the console I let the reset go.
The two methods return different errors (at least in the video but i'm trying to reproduce it right now with no success).
Code: [Select]
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
http://www.youtube.com/watch?v=jC9bTXvil04
I've tried a lot of things, I've read a lot of tutorials but I can't solve this problem.. Help?
EDIT: verbose output, http://pastebin.com/uNbjAZDe
Erni
As far as I could see, you miss a connection from Arduino pin 10 to Attiny reset
andrepcg
#2
Feb 23, 2013, 05:33 pm Last Edit: Feb 23, 2013, 05:51 pm by andrepcg Reason: 1
true. retried it right now and the error is the same:
Code: [Select]
        this check.
I've enabled verbose output, http://pastebin.com/uNbjAZDe
Erni
Quote
Try File->Upload using programmer
http://www.ernstc.dk/arduino/attiny85.html
andrepcg
Quote
same error..
Coding Badly
andrepcg
#6
Feb 23, 2013, 08:34 pm Last Edit: Feb 23, 2013, 08:42 pm by andrepcg Reason: 1
I've checked the wiring a lot of times and I don't see anything wrong..
EDIT: if you look at the capacitor you can see the stripe on the left side meaning the capacitor is reversed but it's only an illusion from the light and the negative side of the capacitor is connected to the ground
Coding Badly
andrepcg
#8
Feb 23, 2013, 08:52 pm Last Edit: Feb 23, 2013, 09:01 pm by andrepcg Reason: 1
Do all the wires conduct electricity?
I'm getting these values while the arduino is connected to the usb port (so everything is standby, i'm not uploading the sketch):
  • attiny is getting 4.97V (pin 3 in attiny)
  • pin 13 is outputting 0.07V (connected to pin 2)
  • pin 12 is outputting 0.0V (connected to pin 1)
  • pin 11 is outputting 0.0V (connected to pin 0)
  • pin 10 is peaking 4.35V (reset pin)
  • the capacitor is charged
this being an attiny85v, has anything to do with it? i guess not but idk..
Shpaget
I had some trouble with the capacitor not connecting properly when plugged directly in the headers of the board. Moving it to the breadboard solved the problem.
andrepcg
yep, already did that with no success. the measurements I took in the last post were with the capacitor on the breadboard.
looking at the avrdude output, what can you say about this? (http://pastebin.com/uNbjAZDe)
Coding Badly
Correct.
Quote
Incorrect.  Stop doing that.
Quote
You only posted one error message...
Code: [Select]
        this check.
That error goes with #1 or #2?
andrepcg
if you watch the video I have the error there.
but that error is happening with situation #1, I stopped doing the 2nd
Coding Badly
There are two possibilities... 1. Wiring; 2. Clocking
If you have never successfully changed the fuses (done by "Burn Bootloader") then it cannot be #2.
Coding Badly
