Pages: [1]   Go Down
Author Topic: looking for a DC-DC 12v boost converter  (Read 839 times)
Offline Offline
Sr. Member
View Profile
im looking for a DC DC boost converter for a car's battery ~10-15v to my laptops charger output (19v, 2.15A when charging). it doesn't make sense to use an inverter to: 12v DC -> 120V AC -> 19v.
im thinking:
Vin: 0-20v
Vout: 10-20V or so.
Aout: <=10A
i was looking at: http://www.linear.com/product/LTC3786 or http://www.ti.com/product/tps55340 or http://www.ti.com/product/tps61175 but all the ones i have seen use transformers. anyway around this, or to get it slimmed downed?
Logged
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
[url]http://ar
Australia
Offline Offline
Sr. Member
View Profile
By transformers , do you mean inductors?
If so, its not possible to make a boost converter without an inductor or transformer.
Logged
Offline Offline
Sr. Member
View Profile
ok, thanks. any tips in general?
Logged
[url]http://ar
Australia
Offline Offline
Sr. Member
View Profile
These types of converters are quite common.
Heres an example.
http://www.bixnet.com/12vdcto19vdc.html
They are tricky to build unless you can get the proper ferrites for the inductors,
so I wouldnt recommend building your own.
Logged
Offline Offline
Sr. Member
View Profile
good info. id probably be better off doing something more universal like: http://www.radiolocman.com/shem/schematics.html?di=61516
then i can use anything 120v ac
Logged
[url]http://ar
UK
Offline Offline
Faraday Member
Where is your SSCCE?!?!
View Profile
WWW
Buy a universal laptop car power supply off the shelf.  They are cheap, they work well, and they come with a guarantee.  i.e., they're unlikely to blow up your laptop.
Logged
Why not visit my eBay shop? http://stores.ebay.co.uk/Majenko-Technologies
Replacement for the Arduino IDE: UECIDE - Proper serial terminal, graphing facilities, plugins, overhauled internals.
Java isn't bad in itself, but it has enabled morons to write programs.
Pages: [1]   Go Up
Jump to:
