Topic: Serial issues with a leonardo (Read 3637 times) previous topic - next topic
permnoob
I have a leonardo connected to my laptop.  Idon't play with serial too much, nottwo way atleast.  my sketch didn't work (serialevent never got called) so I tried the serial event example sketch, and that doesn't work w/ my leonardo either.  If I just have a Serial.Print, it displays fine on the laptop, but as I said, serial event never seems to be called, e ven in the example.
is this a leonardo issue?  or is it me?
permnoob
ok it seems to be a leonardo issue.  I knew I would regret trying new hardware
PaulS
Quote
or is it me?
I'd go with it being just you. Or, more likely, your undisclosed code.
permnoob
I didn't post the code since I said I was using example code, I figured there was no need.
Code: [Select]
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
  // initialize serial:
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
  // print the string when a newline arrives:
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
  SerialEvent occurs whenever a new data comes in the
hardware serial RX.  This routine is run between each
time loop() runs, so using delay inside loop can delay
response.  Multiple bytes of data may be available.
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
PaulS
What is sending the serial data? I see no proof that serialEvent() is not called.
permnoob
I have it connectedto my laptop via USB cable.  If I add somethign like
Code: [Select]
delay(2000);
Serial.println("Setup compelte");
to the end of setup, I see that msg on the laptop screen no issue, so I know serial com works.
permnoob
adding a similar chunk of code inside of serialevent never prints to the seral monitor.
PaulS
I'll repeat my question once more. What is sending the serial data? Yes, I know it is the PC, but a PC is collection of hardware. There is some application on the PC that sends data, not "the PC".
permnoob
I am sending it using the serial monitor from the arduino IDE
PaulS
I've confirmed that the serialEvent() method is NOT called on the Leonardo. Not that is is really a big deal, as all that means is that at the end of loop, the amount of data in the serial buffer is determined, and if that is not zero, the function is called.
Adding
Code: [Select]
if(Serial.available() > 0)
  serialEvent();
to the end of loop() accomplishes the same thing.
permnoob
I have never used serial event before, always did it sas you described.  Untill I was fighting this issue I always thought SerialEvent did some magick behind the scenes (say some kind of "highlevel" inturrupt or something else I don't know about) so that it was actually called outside of normal loop() looping.  Is there some inherent benifit to using it, or does it just simplify coding for new folks?  I don't plan on using it any more, just adds confusion and strange flow to my cod.e
PaulS
Quote
No.
Quote
No.
Personally, I think it was a useless addition to the Arduino tool set. A solution looking for a problem, rather than a problem needing a solution.
Quote
Agreed, especially since you must use global variables to have any data sharing with loop().
