Topic: IRremote help (Read 5139 times) previous topic - next topic
ColeH
Hello,
  I have been trying to use an IR remote i have with my arduino but i have run into a problem.  I am trying to use the IRremote library to figure out what my remote is sending to the arduino.  After putting the IRremote file into my libraries folder, i include the library but then an error comes up when i try to verify.  It says
C:\Program Files (x86)\arduino-1.0.3\libraries\IRremote\IRremote.cpp:271: error: 'volatile struct irparams_t' has no member named 'rawlen'
and basically that over and over but with different file names.  Did i mess up somehow?
nickgammon
Quick5pnt0
Did you restart the IDE?
PaulS
User downloaded libraries do NOT go in the core library folder.
ColeH
Here is my code
/ example 32.1 - IR receiver code repeater
// http://tronixstuff.com/tutorials > chapter 32
// based on code by Ken Shirriff - http://arcfn.com
#include <IRremote.h> // use the library
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
  Serial.begin(9600); // for serial monitor output
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) // have we received an IR signal?
    Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal
    irrecv.resume(); // receive the next value
  }  // Your loop can do other things while waiting for an IR command
I did restart my IDE but it still does not work.
If user downloaded libraries don't go into the core library folder, then where does it go?
PaulS
In the libraries folder in the folder where sketches are stored.
nickgammon
http://arduino.cc/en/Guide/Libraries
ColeH
I moved the IRremote library file into Documents\Arduino\libraries and then tried again, but i still get the same error.
PaulS
The IRremote library? Which one?
ColeH
I mean the file that I downloaded.
nickgammon
<sigh>
Which file? And don't reply "the one on my computer". What is the link to it?
Did you restart the IDE after moving it?
ColeH
I downloaded it from here http://tronixstuff.wordpress.com/2011/03/30/tutorial-arduino-and-infra-red-control/  but almost every other tutorial i found on IRremote control with arduino had a download for the same file.
PaulS
Same code I have. Compiles and links (and works) on Arduino 1.0.3.
ColeH
All i have to do is download the file, unzip it, and put it into documents/arduino/libraries, then open up the IDE right?
nickgammon
The whole folder, yes.
Is this how you have it set up?
