« on: February 24, 2013, 01:46:42 am » |
Hello, I have been trying to use an IR remote i have with my arduino but i have run into a problem. I am trying to use the IRremote library to figure out what my remote is sending to the arduino. After putting the IRremote file into my libraries folder, i include the library but then an error comes up when i try to verify. It says
C:\Program Files (x86)\arduino-1.0.3\libraries\IRremote\IRremote.cpp:271: error: 'volatile struct irparams_t' has no member named 'rawlen'
and basically that over and over but with different file names. Did i mess up somehow?
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #1 on: February 24, 2013, 04:00:50 am » |
How to use this forumCan you post your code please?
NE PA
« Reply #2 on: February 24, 2013, 12:23:07 pm » |
Did you restart the IDE?
Seattle, WA USA
Online
Seattle, WA USA
« Reply #3 on: February 24, 2013, 12:44:24 pm » |
User downloaded libraries do NOT go in the core library folder.
« Reply #4 on: February 24, 2013, 01:00:27 pm » |
Here is my code / example 32.1 - IR receiver code repeater // http://tronixstuff.com/tutorials > chapter 32 // based on code by Ken Shirriff - http://arcfn.com #include <IRremote.h> // use the library int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11 IRrecv irrecv(receiver); // create instance of 'irrecv' decode_results results; void setup() { Serial.begin(9600); // for serial monitor output irrecv.enableIRIn(); // Start the receiver } void loop() { if (irrecv.decode(&results)) // have we received an IR signal? { Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal irrecv.resume(); // receive the next value } // Your loop can do other things while waiting for an IR command } I did restart my IDE but it still does not work. If user downloaded libraries don't go into the core library folder, then where does it go?
Seattle, WA USA
Online
Seattle, WA USA
« Reply #5 on: February 24, 2013, 01:09:17 pm » |
If user downloaded libraries don't go into the core library folder, then where does it go? In the libraries folder in the folder where sketches are stored.
Shannon Member
Lua rocks!
« Reply #6 on: February 24, 2013, 03:15:12 pm » |
http://arduino.cc/en/Guide/Libraries
« Reply #7 on: February 24, 2013, 05:11:26 pm » |
I moved the IRremote library file into Documents\Arduino\libraries and then tried again, but i still get the same error.
Seattle, WA USA
Online
Seattle, WA USA
« Reply #8 on: February 24, 2013, 05:44:27 pm » |
I am trying to use the IRremote library The IRremote library? Which one?
« Reply #9 on: February 24, 2013, 06:25:23 pm » |
I mean the file that I downloaded.
Shannon Member
Lua rocks!
« Reply #10 on: February 24, 2013, 06:30:47 pm » |
<sigh>
Which file? And don't reply "the one on my computer". What is the link to it?
Did you restart the IDE after moving it?
Seattle, WA USA
Online
Seattle, WA USA
« Reply #12 on: February 24, 2013, 07:34:06 pm » |
Same code I have. Compiles and links (and works) on Arduino 1.0.3.
« Reply #13 on: February 24, 2013, 07:41:15 pm » |
All i have to do is download the file, unzip it, and put it into documents/arduino/libraries, then open up the IDE right?
Shannon Member
Lua rocks!
« Reply #14 on: February 24, 2013, 07:52:23 pm » |
The whole folder, yes. Is this how you have it set up?
