Topic: Photo resistor (Read 1 time) previous topic - next topic
penguin19
Feb 26, 2013, 01:54 am Last Edit: Mar 17, 2013, 01:58 am by penguin19 Reason: 1
Code: [Select]
if (((lightLevel > 127.5) || (lightLevel < 191.25)))
 for(index = 0; index <= 0; index++)
 analogWrite(ledPins[index], HIGH);
if (((lightLevel > 191.25) || (lightLevel < 255)))
 for(index = 0; index <= 3; index++)
 analogWrite(ledPins[index], LOW);
johnwasser
Code: [Select]
void off()
That function doesn't actually do anything.  From context I think you intended to write:
Code: [Select]
void off()
  for (int index=0; index < 3; index++)
    digitalWrite(ledPins[index], LOW);
Other parts of the code may be wrong in similar ways.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
penguin19
I changed the off function like this:
Code: [Select]
void off()
int index;
  for (int index = 0; index < 4; index ++)
  digitalWrite(ledPins[index], HIGH);
I tried turning the pins LOW, but they remained on. I then tested them on HIGH to see what would happen and they blink on and then remain off. Any idea why this happens? Could my wiring on the board be wrong?
I got the dim function to work by doing this:
Code: [Select]
void dim()
   lightLevel=analogRead(sensorPin);
//manualTune();
autoTune();
analogWrite(ledPins[index], lightLevel);
Still can't get the gauge function to work though...
Grumpy_Mike
you don't need the
Code: [Select]
int index;
Because you already declare the variable in
Code: [Select]
Quote
No. If that is what you see something is putting them high again.
This sort of test is wrong:-
Code: [Select]
You are using the || which is the logical OR, so if the light level is less than 255 then it is true irrespective of the first part. I think you mean && the and operator here.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
