Loading...
Pages: [1]   Go Down
Author Topic: [Beginer] How can I use my LCD to display the Serial.print() and Serial input  (Read 251 times)
Offline Offline
Full Member
View Profile
Good morning.
I just get a LCD with 16 col and 4 ligns
I would like to use it to display the Welcome text and all Serial input and all Serial.print().
I am woriking with Arduino Uno.
I imported the library
#include <LiquidCrystal.h>
First issue:
and at the setup() I enter this
Code:
  lcd.begin(16, 4);
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
  // Print a message to the LCD.
  lcd.print("****************"); // Display 16x* at the first lign
  lcd.print("*** Wellcome ***"); // Display those 16 caracter at the lign 2
  lcd.print("*** to iBip ****"); // Display those 16 catacters at the lign 3
  lcd.print("***************"); // Display those 16 starts at the last lign
  delay(5000);
  lcd.clear(); // Clear the screen
As there is 16 col, I suppose the nect caracter will go to the second lign, but it does not goe to the 3 lign.
Then I tried to use
Code:
  lcd.setCursor(0, 1);
lcd.setCursor(0, 2);
But it work only for the 2nd lign. The third lign is displayed form the 7col......
Second problem
I want to diaplay the Serial input. I have that function which display in Terminal
Code:
String getMessage() {
  String s="";
  while(1) {
    if(cell.available()>0) {
      s = s+(char)cell.read();
      if (s.length()>1 && s[s.length()-2]=='\r' && s[s.length()-1]=='\n') { // if last 2 chars are \r\n
        if (s==" \r\n" || s=="\r\n") { // skip these, move on
          s="";
        else { // we have a message!
          #ifdef DEBUG
          Serial.println(s.substring(0,s.length()-2));
          #endif
          lcd.print(s.substring(0,s.length()-2));
          return s.substring(0,s.length()-2);
It works but I want to have each new message in a new lign.
Third problem
When my display is full. When all lign are showing a message. I would to have the
- The Second lign displayed at the lign 1
- The third lign display at lign 2
- The last lign displaed at lign 3
- The new message at lign 4.
How can I do it??
I check autoscroll, but auto scroll display the carater after the last and not a a new lign.
In fact, I would like to have exactely what does the terminal, but in a LCD.
Could you help me for my first LCD task??
Do you know some tutorials
Many thank
Logged
Offline Offline
Full Member
View Profile
Is there not a function like this
Code:
lcd.println(s.substring(0,s.length()-2));
Which place the cursor to a new lign after the end of the message and move up the displayed text if it take 4 lign?
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Part of your problem stems from the characteristics of the display and part from a deficiency in the LiquidCrystal library.
The display was not designed to replace a CRT or LCD display such as that on a computer.  It was designed to display short messages such as 'add toner' or 'fire in zone 3' and there was no real need to implement the <CR> or <LF> control codes.
Also, due to the memory implementation required by the vintage of the controller, you will find that the display will proceed from line 1 to line 3, then to line 2, and finally to line 4.  To find out more about the reasons for this you can follow the LCD Addressing link at http://web.alfredstate.edu/weimandn.
The reason for the 7 column offset on two of the lines is due to the fact that the LiquidCrystal library does not use the correct starting addresses for those lines on a 16x4 display.
Some of these problems were addressed when the LiquidCrystal440 library was developed a few years ago.  To get a copy start here:--> http://code.google.com/p/liquidcrystal440/ and follow the Downloads link to get to the latest version.
There is also a 'new' LiquidCrystal replacement library available that probably deals with at least some of these issues as well.  You can find information about that library here --> https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home <--.
Don
Logged
Pages: [1]   Go Up
Print
Jump to:
