Topic: L3DG20 - MiniMU-9 v2 (Read 2146 times) previous topic - next topic
fcvolpe
Good afternoon ....
I'm using minimu-9 v2 (LSM303DLHC and L3DG20) arduino in use, but the L3DG20 is sending values ??even when arrested, is this normal? It was not to show 0 when stopped?
Boa tarde....
Estou usando MiniMU-9 v2 (LSM303DLHC e L3DG20) no arduino uso, porém o L3DG20 fica mandando valores mesmo estando parado, isso é normal? Não era para  mostrar 0 quando parado?
robtillaart
Do you have a link to a datasheet?
Você tem um link para uma folha de dados? [Português?]
Rob Tillaart
fcvolpe
Datasheet
http://www.st.com/web/en/resource/technical/document/datasheet/DM00036465.pdf
robtillaart
quick look at the table of contents of the datasheet triggered this question:  Is the sensor in stream mode?
Rob Tillaart
