Topic: u8glib 1.11 function SleepOn don't work. (Read 4507 times) previous topic - next topic
Carlosgu
Hi, sorry by my English, I'm from Spain. I'm doing an sketch with a LCD ST7565 128x64,  I'm trying to use the functions "SleepON" and "SleepOff".
In the reference of U8glib this functions are avalaible since version 1.11. I'm using this constructor:
U8GLIB_DOGM128 u8g(13, 11, 10, 9, 8);
When I compiled my sketch, it appears an error: 'class U8GLIB_DOGM128' has no member named 'SleepOn'
I had search this member in all files in the library u8glib, but i dont found it.
Can you help me? Thanks.
olikraus
Release 1.11 is not yet out. But I have just put another prerelease on the download page.
Let me know if the sleep function works. I added it some hours ago.
Oliver
Carlosgu
Carlosgu
Hello Olikraus, I downloaded the version 1.11 (    u8glib_arduino_v1.11.zip ) at http://code.google.com/p/u8glib/downloads/list.
I read the news for 1.11: New release v1.11 is available for download:
Support for T6963
Support for Arduino Due
Sleep Mode
4x mode for ST7920
New C++ interface for ST7920
but i not find how i have to do for use the function sleepon and sleepoff.
I'm looking for text "sleepon" in all archives of library and I not find it.
Can you help me. Thanks.
olikraus
Hi
Thanks for the hint. Procedure names are:
    void U8GLIB::sleepOn(void)
    void U8GLIB::sleepOff(void)
I will add this to the reference manual.
Thanks,
Oliver
Carlosgu
Thanks, Oliver
I put the code in my sketch and when i compile it say me:
ProAACon_V115.ino: In function 'void SCRApagaPantalla()':
ProAACon_V115:702: error: 'class U8GLIB_DOGM128' has no member named 'sleepOn'
ProAACon_V115.ino: In function 'void SCREnciendePantalla()':
ProAACon_V115:709: error: 'class U8GLIB_DOGM128' has no member named 'sleepOff'
My functions are:
// APAGAMOS LA PANTALLA
void SCRApagaPantalla(){
  scru8g.sleepOn();
// ENCENDEMOS LA PANTALLA
void SCREnciendePantalla(){
  scru8g.sleepOff();
All others funtions work fine, why those not?
Thanks again
olikraus
ok, I have to investigate this more closely. I have currently only limited access to the u8glib project, but I hope to work on this topic next week.
Oliver
Carlosgu
Hi, Oliver:
I found the function at file u8g_ll_api.c and the syntax are:
void u8g_SleepOn(u8g_t *u8g)
  u8g_call_dev_fn(u8g, u8g->dev, U8G_DEV_MSG_SLEEP_ON, NULL);
void u8g_SleepOff(u8g_t *u8g)
  u8g_call_dev_fn(u8g, u8g->dev, U8G_DEV_MSG_SLEEP_OFF, NULL);
In te reference we have SleepOn and SleepOff not u8g_SleepOn and u8g_SleepOff. Maybe this is the matter?
I'll try later at home and i'll say you something.
olikraus
These two procedures are part of the C interface. However the same procedure should be also available in the C++ interface.
Oliver
Carlosgu
Hi, I tried at home and don't work, I don't know what is the matter. I'll continue looking for, but
If you found the bug please send me.
Thanks again.
olikraus
Hi
I have added the following commands into the loop() procedure of the GraphicsTest example:
  if ( (draw_state % 8) == 2 )
   u8g.sleepOn();
  if ( (draw_state % 8) == 3 )
   u8g.sleepOff();
Everything works as expected. I did not found any bug.
Why do you think that it is not working?
Do you receive any warnings or compiler errors?
Can you upload your code?
Oliver
Carlosgu
Hello oliver,
I found my problem, not because reason though I copied the new library, compiled with the old
I deleted the directory \library\u8glib and I copied u8glib again. compiled ok. I not have arduino card now, I test at my home later.
I tell you if the function works
Thanks for all. :)
olikraus
Glad to hear that your problem has been solved.
Oliver
