Topic: No Mac serial port choices. Only Bluetooth. Sad I can't use my Arduino Uno. (Read 62603 times) previous topic - next topic
shakyspoon
No relevant serial ports are listed in Tools > Serial Port > .
Only listed ports are /dev/tty.Bluetooth-PDA-Sync, /dev/cu.Bluetooth-PDA-Sync, /dev/tty.Bluetooth-Modem, /dev/cu.Bluetooth-Modem.
Tried all of them. Always the same orange in arduino console. "processing.app.SerialException: Serial port '/dev/tty.Bluetooth-Modem' already in use. Try quiting any programs that may be using it."
or if no bluetooth port is selected: "processing.app.SerialNotFoundException: Serial port 'COM1' not found. Did you select the right one from the Tools > Serial Port menu?"
Using Snow Leopard 10.6.8 on MacBook Pro, all software up to date via software update.
The Uno worked on my PPC G5 for the past year. The "solution" to "just use the G5" is no longer an option.
Never had a "Network detected" dialog when plugging in Arduino Uno on Snow Leopard 10.6.8 on MacBook Pro.
Changed out 4 different USB cords, all tested in working order. All USB ports directly on the computer were tried.
When connected the Uno green "ON" LED is on and "L" LED is flashing most likely due to "Blinking Light" (File > Examples > Basic > Blink) example currently running and was uploaded from the PPC G5.
Tried IDE's arduino-1.0.1, arduino-1.0.2, arduino-1.0.3, arduino-1.5.2b.
Tossed out /Users/user1/Library/Arduino/preferences.txt and /Users/user1/Library/Preferences/cc.arduino.Arduino.plist
Tried restarting the IDE with the board connected to the computer and also connecting before IDE start.
All firewalls were off. Went thru the Activity Monitor and force quit anything that might hold USB ports, example Image capture. They do start right back up.
Tried this http://www.cmiyc.com/blog/2012/10/08/arduino-fixing-serial-port-in-use/
ls -l /var/lock
sudo mkdir /var/lock
sudo chmod 777 /var/lock
Opened "Get Info", tried "Open using Rosetta", liberated the user permissions.
Uno R3 version .0001 purchased from Sparkfun.com 12-2011. Stock UNO, no modifications, nothing connected but the USB cord.
Pointless but I installed the FTDI drivers.
The Uno is selected in Tools > Board
Uninstalled my usrobotics 56K USB Modem model 5637 from network preferences.
I have turned off bluetooth in System Preferences. Tried all the above. I have turned on bluetooth in System Preferences. Tried all the above.
From USB menu on "System Profiler"
Communication Device:
  Product ID:   0x0043
  Vendor ID:   0x2341
  Version:    0.01
  Serial Number:   64935343533351801222
  Speed:   Up to 12 Mb/sec
  Manufacturer:   Arduino (www.arduino.cc)
  Location ID:   0x3d100000 / 2
  Current Available (mA):   500
  Current Required (mA):   Unknown (Device has not been configured)
I've scoured the troubleshooting forums and http://www.arduino.cc/en/Guide/Troubleshooting#upload, and googled and googled and googled. I really appreciate the input but no one has a solution. Like so many other Mac users on 10.6 to 10.7 with the loss of serial port choices, I'm disappointed that I can't use my Arduino. Perhaps an option would be to use a bluetooth/wifi interface but I feel for now I've lost the faith.
Serial Monitor Output:
   at processing.app.Serial.<init>(Serial.java:171)
   at processing.app.Serial.<init>(Serial.java:92)
   at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:207)
   at processing.app.Editor.handleSerial(Editor.java:2481)
   at processing.app.Editor$17.actionPerformed(Editor.java:665)
   at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2028)
   at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2351)
   at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
   at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
   at javax.swing.AbstractButton.doClick(AbstractButton.java:389)
   at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:95)
   at java.awt.MenuItem.processActionEvent(MenuItem.java:650)
   at java.awt.MenuItem.processEvent(MenuItem.java:609)
   at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:343)
   at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:331)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:713)
   at java.awt.EventQueue.access$400(EventQueue.java:82)
   at java.awt.EventQueue$2.run(EventQueue.java:669)
   at java.awt.EventQueue$2.run(EventQueue.java:667)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:98)
   at java.awt.EventQueue$3.run(EventQueue.java:683)
   at java.awt.EventQueue$3.run(EventQueue.java:681)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:680)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
nickgammon
Quote
http://www.gammon.com.au/forum/?id=11329
I've got OS/X 10.7.5 and my Arduinos appear correctly. In this screenshot I have a couple plugged in, plus a couple of FTDI cables:
This is how it appears in the System Profile:
I don't know what to suggest, though. Reboot? Check for OS updates?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
cmiyc
The Bluetooth port is part of your Mac and has nothing to do with the Arduino.  The default for the IDE is to pick something.  However, you'll never communicate with your Arduino this way.
ls -l /var/lock
While I'm glad you found that, the problem is completely unrelated.  Something is preventing your serial port to be properly enumerated.  The "already in use" is because the IDE is trying to use a port unrelated to the Arduino.
You can't program the chip over WiFi and Bluetooth is problematic since it doesn't usually do auto reset.
The problem is your Mac isn't assigning a serial port to the Arduino.
Are you connecting the Arduino though a USB Hub?  (Keyboards count as a Hub).
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
spatula
As already noted this is an OS problem. The port should appear (only when the Arduino is physically connected) as a pair of files /dev/tty.usbmodemXYZ and /dev/cu.usbmodemXYZ. The IDE gets its list of available ports from the OS.
There are utilities that may help your diagnosis, perhaps the standard Utility->Console will show some meaningful error message when you connect the Arduino. USB Prober is a dedicated tool available from the Mac developer site, and you may find downloadable copies around. I'm saying this because *apparently* some people solved their "device not recognized" problems just by running a low-level usb analyzer (???). I would also get rid of the FTDI drivers, just in case.
I run OSX 10.6.8 on a MBPro and have the same Vendor/Product/Version IDs, never had similar problems so far.
shakyspoon
Thanks for the input! You guys got me thinking, I have my laptop setup with 2 partitions, I use the work partition all the time and I use the maintenance partition for running disk utilities and such on the work partition. The maintenance partition only has the default and software updated 10.6.8 with some additional maintenance utilities installed. So I booted to the maintenance partition, installed IDE Arduino 1.0.3, plugged in the Uno board and viola, the new Network device Detected dialog popped up. I uploaded some tests and the Uno works fine & dandy. But all my stuff is on my work partition so this setup would suck. I rebooted back to the work partition, as per your suggestion checked the console messages after plugging in the board:
2/26/13 8:01:57 AM   com.apple.kextd[10]   Can't load /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/AppleUSBCDC.kext - no code for running kernel's architecture.
2/26/13 8:01:57 AM   com.apple.kextd[10]   Failed to load /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/AppleUSBCDC.kext - (libkern/kext) requested architecture/executable not found.
2/26/13 8:01:57 AM   com.apple.kextd[10]   Load com.apple.driver.AppleUSBCDC failed; removing personalities.
Interesting differences between my work partition and my maintenance partition of file '/System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/AppleUSBCDC.kext'
My work partition
Kind: Kernel Extension (PowerPC)
Size: 356 KB on disk
Created: Saturday, August 1, 2009 12:52 AM
Modified: Saturday, August 1, 2009 12:52 AM
Version: 3.1.5, USB CDC driver
My maintenance partition of the same System extension file but from a clean install of 10.6.8:
Kind: Kernel Extension (Intel)
Size: 123 KB on disk
Version: 4.0.5, USB CDC driver
Some strange differences. I copied '/System/Library/Extensions/IOUSBFamily.kext' from the maintenance partition to the desktop of my work partition.
1st I duped then replaced the direct problem "/System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/AppleUSBCDC.kext" with the same file from the maintenance partition. No go, nada, Nothing. No "new network interface Detected" dialog.
Then figured I'll replace the whole dang extension:
08:31:51 PM Tue Feb 26, 2013:/System/Library/Extensions user1 }
  • <===o sudo mv IOUSBFamily.kext/ IOUSBFamily.kext.ORIGINAL/
    08:32:36 PM Tue Feb 26, 2013:/System/Library/Extensions user1 }
  • <===o sudo cp -r '/Users/user1/Desktop/IOUSBFamily.kext from user2 - 10.6.8/IOUSBFamily.kext' .
    The board was still plugged in and BOOM! there was the "new network interface Detected" dialog. Hit Network Preferences, then Apply, booted up the IDE, Tools > Serial Port and I am good to go! Thanks!!!
    Just hope I didn't break something else.
    USB Drivers that I recall installing. I'm sure there were others.
    USRobotics zoom modem
    Logitech mouse drivers
cmiyc
Nice job troubleshooting the issue.  Glad you got it to work.
dchialvo
I had the same problem of no Mac port to choose for the MEGA 2560. (MAC OSX, 10.8.5 )
SOLUTION:
1) Fired the Arduino 1.0.5 , Connected the Arduino to a USB port
1) I went to tools/BOARD and choose (don't ask me the rationale) another BOARD model  which has the choice of
serial ports
2) went to tools/SerialPorts and selected /dev/tty.usbmodem621
3) went back to tools/BOARD and selected the right one (i.e., MEGA 2560).
Everything is working…
Don't ask me why….
Sebizarro
I have the same problem, the MacBook Pro does not recognise any port for Arduino Uno R3.
the arduino is for controlling a CNC machine, and the Atmega chip is "burned" with hex(grlb) file.
tried connecting in windows (VMware) and no connection also. installed the ftdi drivers and still nothing works, don't know how to instal the USBprobe.
really not an expert on this matter, just want make this work.
anyone can help me with a simple solution  :)
jovi
... I would also get rid of the FTDI drivers, just in case.
Can someone please tell me where I can find the FTDI drivers on Mac OS Mountain Lion so I can get rid of them?
I am also looking for the D2XX drivers and a SiLabsUSBDriver, which was recommended in another forum on this topic, so I can get rid of those and start over.
I gather from this forum that I never needed those drivers so I'd like to get rid of them. I'm 3 days in and still can't get IDE to show a port for UNO. The port did appear once, but then disappeared. I'm trying to go back to the beginning and recreate what I did to get it to appear.
OS: Mountain Lion
Model: iMac early 2008
Arduino: UNO (just the UNO board, nothing else attached)
IDE: 1.0.5
Thanks!
jovi
UPDATE: I found and removed all drivers using Easy Find.
Please disregard.
alpeace89
I have this exact problem. Does anyone have a solution for it? I tried as suggested above selecting another board and changing the ports but it didn't work for me. I have also installed the drivers.
Thanks,
Alex
B_Free
I just had almost the exact same experience as shakyspoon (original post), want to share how I solved it.
My computer crashed while uploading to a Diecimila.  When I rebooted the serial ports in the Arduino IDE were all bluetooth.  I tried using the Processing sketch by Tom Igoe (http://processing.org/reference/libraries/serial/Serial_list_.html) to list all the available ports but it only found the bluetooth ones as well.  Also, when I plugged the board in I did not get the "Network detected" dialogue box anymore.
I did find some Console error messages referring to the  IOUSBFamily.kext
To fix it I tried...
* switching to a different board in the Arduino IDE (just like dchialvo's post above), that didn't work.
* verifying and fixing permissions on my hard disk, that didn't work.
* resetting the SMC, that didn't work.
* resetting PRAM, that didn't work.
* reinstalling the entire Operating System, that didn't work.
Finally, I just tried plugging in a different Arduino board, my Arduino Uno.  Suddenly the USB serial ports were back in the Arduino IDE.  Then I unplugged the Uno and plugged the Diecimila back in and the USB serial ports remained!
I have no idea if the other stuff I did helped, but at least it's working again.
I'm using Mac OS 10.6.8 on an old MacBook, with Arduino IDE 1.0.5
alpeace89
When I had the exact same problem it turned out my UNO had no boot loader. Took it back to Maplin and it worked 1st go with a new one!
purplezack
Hi everybody, I'm having the same problem, but I've not a second partition to check.
the weird thing is that until this night I've always worked with this system (Mac OSX 10.9.5) without problem, but now I can't see serial ports from my usb input.
I use without problems usb drive but arduino, panstick and a board I builded from myself, not anymore!
They are presents in hardware list as usb hardware, just the /dev/tty.usbmodem* address is not created, so that Arduino and other serial reader didn't notice them.
I installed new FTDI driver this morning, trying to solve that problem, and then I removed them, but nothing to do.
5xFive
I'm having the same problem on Mac 10.10 with an Uno and IDE 1.6.4.  No tty anything, just cu.
