Topic: got error (Read 2458 times) previous topic - next topic
jhen
Feb 23, 2013, 01:51 am Last Edit: Feb 23, 2013, 01:54 am by Coding Badly Reason: 1
this is my code
Code: [Select]
#include <SoftwareSerial.h>
 GSM Send Sketch for Arduino
 Initializes GSM Module and sends an SMS to recipient
 The circuit:
 *Arduino pin 0 (RX) - GSM Module (TX)
 *Arduino pin 1 (TX) - GSM Module (RX)
SoftwareSerial RFID(10,11);
char Rx_data[50];
unsigned char Rx_index = 0;
int i = 0;
char msg[160];
int sig;
char number;
 Serial.begin(38400);
 Serial1.begin(9600);
 RFID.begin(9600);
 initGSM();
 send_msg(number, msg);
 if(Serial1.available()){
  char c=Serial1.read();
 if(c==65){
   number=Serial1.read();}
   else{}
void send_msg(char *number, char *msg)
 char at_cmgs_cmd[30] = {'\0'};
 char msg1[160] = {'\0'};
 char ctl_z = 0x1A;
 sprintf(msg1, "%s%c", msg, ctl_z);
 sprintf(at_cmgs_cmd, "AT+CMGS=\"%s\"\r\n",number);
 sendGSM(at_cmgs_cmd);
 delay(100);
 delay(100);
 delay(100);
 sendGSM(msg1);
 delay(100);
void sendGSM(char *string){
 Serial.write(string);
 delay(90);
void clearString(char *strArray) {
 int j;
 for (j = 100; j > 0; j--)
   strArray[j] = 0x00;
void send_cmd(char *at_cmd, char clr){
 char *stat = '\0';
 while(!stat){
   sendGSM(at_cmd);
   delay(90);
   readSerialString(Rx_data);
   stat = strstr(Rx_data, "OK");
 if (clr){
   clearString(Rx_data);
   delay(200);
   stat = '\0';
void initGSM(){
 send_cmd("AT\r\n",1);
//  send_cmd("ATE0\r\n",1); // Turn off automatic echo of the GSM Module
 send_cmd("AT+CMGF=1\r\n",1); // Set message format to text mode
 //Sucess
 Serial.println("Success");
void readSerialString (char *strArray) {
 if(!Serial.available()) {
   return;
 while(Serial.available()) {
   strArray[i] = Serial.read();
   i++;
here's my error
Code: [Select]
final.ino: In function 'void setup()':
final:30: error: invalid conversion from 'char' to 'char*'
final:30: error: initializing argument 1 of 'void send_msg(char*, char*)'
Delta_G
I'm not sure what you intend to do there neither of those variables has anything in them at that point.
But either way, number is declared as a char.  The function expects a pointer to a char.  An & in front of number will clear the error but probably won't work like you expect since the function is using it as a string.  It would need a trailing NULL to work there.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
PaulS
Quote
No, it won't. number needs to be a string (an array).
And, as Delta_G alluded to, both number and msg need to have values assigned. Sending an empty message to an undefined number is a waste of effort (and you will be charged).
nickgammon
Code: [Select]
  if(c==65){
    else{}
What is the "else" for? What is 65?
You know you have one character available, but are reading two. Why?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
jhen
here is the original code that i want to modify
i want to change the number to a variable depending to the receive data from the pc as well as the message("hello")  this code it is working ,what i need to do?
Code: [Select]
char Rx_data[50];
int i = 0;
char msg[160];
int sig;
  initGSM();
  send_msg("09295791692", "Hello");
  //none
  char ctl_z = 0x1A;
  delay(100);
  delay(100);
  delay(100);
  sendGSM(msg1);
  delay(100);
  delay(90);
  int j;
    strArray[j] = 0x00;
  char *stat = '\0';
  while(!stat){
    sendGSM(at_cmd);
    delay(90);
  if (clr){
    delay(200);
    stat = '\0';
void initGSM(){
  //Sucess
    return;
    i++;
nickgammon
Quote
Code: [Select]
  char *stat = '\0';
  while(!stat){
This is incredibly obscure. I suggest a rewrite.
jhen
PaulS
Quote
IS IT possible?
Certainly.
What is IT, though?
jhen
is it possible to change the number to a variable depending to the receive data...
PaulS
Quote
This is like pulling teeth. Change what number to what variable? Almost anything is possible if you know what you are trying to do.
nickgammon
IS IT possible?
http://en.wikipedia.org/wiki/Knights_who_say_Ni
Quote
The Knights happen to have a weakness in that a number of words, when spoken to them, has the same effect on them as their saying "Ni" has on others. The only one of these words that is revealed in the film is the word "it", which is picked up on when Arthur, upon being asked to cut down the mightiest tree in the forest with a herring, declares that "it can't be done." Ultimately, King Arthur and Sir Robin (who shows up with his own knights) both say "it" several times in conversation (unaware that "it" was the word that was causing the Knights' pain). However earlier in the very same scene the head Knight himself uses the word ("It is a good shrubbery.") suggesting that it only causes the knights pain when said by someone else.
