Topic: I2C Slave command (Read 2838 times) previous topic - next topic
Bandofcs
Feb 25, 2013, 05:01 am Last Edit: Feb 25, 2013, 05:17 am by Bandofcs Reason: 1
Hi all,
I am trying to use the master device to command the slave to vary the blinky speed. However, I did not observe the blinky LED lighting up at all. Can someone help me look at my code to see what is wrong? Many thanks.
master device
 if (Serial.available() > 0) {
   x = Serial.read();
 Wire.beginTransmission(4); // transmit to device #4
 Wire.write("x is ");        // sends five bytes
 Wire.write(x);              // sends one byte
 Wire.endTransmission();    // stop transmitting
slave device
[tr][td]
void receiveEvent(int howMany)
 while(1 < Wire.available()) // loop through all but the last
   char c = Wire.read(); // receive byte as a character
   Serial.print(c);         // print the character
 int x = Wire.read();    // receive byte as an integer
 Serial.println(x);         // print the integer
  switch(x){
case 49:
a=500;
digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
 delay(a);               // wait for a second
 digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
 delay(a);
break;
case 50:
a=1000;
 delay(a);
break;
nickgammon
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Read this: http://www.gammon.com.au/i2c
nickgammon
Don't do serial prints inside an interrupt service routine, such as receiveEvent.
Bandofcs
Hi Nick, thanks for your input.
I have tried commenting off all serial codelines including that in setup and it still doesnt work. Are there other methods for debugging?
nickgammon
Post the whole amended receiver sketch please. I'd like to see the whole context. And what is this about?
That means the receiving end has to handle getting "x is ". Is it? It doesn't look like it to me.
Bandofcs
Hi Nick,
you are right. it doesnt need to. I merely edited from the wire example code given.
#include <Wire.h>
int led = 13;
int a=0;
 Wire.begin(4);                // join i2c bus with address #4
 Wire.onReceive(receiveEvent); // register event
// Serial.begin(9600);           // start serial for output
 pinMode(led, OUTPUT);
 delay(100);
  // Serial.print(c);         // print the character
// Serial.println(x);         // print the integer
  switch(x){
case 49:
a=500;
 delay(a);
break;
case 50:
a=1000;
 delay(a);
break;
nickgammon
Also don't do delays inside an ISR.
So what is this "x" you are sending?
nickgammon
http://www.gammon.com.au/interrupts
Scroll down to: "Hints for writing ISRs"
Bandofcs
i am sending '1' and '2' which corresponds to 49 and 50
nickgammon
Instead of:
case 49:
How about:
case '1':
Easier to read don't you think?
PaulS
  delay(100);
Why? If you can't find anything useful for loop() to, sitting on its hands for long periods of time, while doing nothing, is stupid. Get rid of the delay()!
