Topic: Why use int instead of byte for pin numbers? (Read 26067 times) previous topic - next topic
krupski
There's always running...  Gets you warm in cold weather, and gets you further distance in a shorter time.
It also gives you heart attacks and knackered knees.
Most of the traces in my left knee are burned open from playing hockey. Running isn't an option for me anymore!  :)
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
Khalid
I can not listen bad about Arduino... I am very thankful to the guys who gave us Free IDE and lot of libraries... And all those are very very simple to use... I love you guys :)
Simply...You can't afford me..
Author Of:
http://my-woodcarving.blogspot.com/
http://www.free3dscans.blogspot.com/
http://my-diysolarwind.blogspot.com/
Oops..some one gave me Karma...:)
transfinite
The real answer to the original question:
1. The programmer's time is much more expensive than the computer or compiler's time.
2. 95% of the time you are not going to need the extra few bytes saved.
3. The C++ optimizer is so good that it will rarely make any difference in code size anyway.
Two practices that will save some resources were already mentioned by majenko and Krupski in the first page of this thread:
const int instead of int for constants will some a couple bytes,
and Serial.print(F("string const")); instead of Serial.print("string const");
The latter will use more flash, but save RAM.  Conservation of RAM is usually a bigger concern than conversation of flash, in my experience.  If your code starts acting flaky you are probably running out of RAM, not flash.
-transfinite
Coding Badly
The latter will use more flash...
By a constant eight bytes for the entire sketch.  Hardly worth mentioning.   ;)
krupski
Ah but don't you know? Everyone's sketch compiles to 32767 bytes and not a single one more will fit! (the reason for crippling sprintf and sscanf for floating point).
/saracsm off.
Osgeld
you mean the wiring guys?
http://wiring.org.co/
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
retrolefty
Sure, along with the AVRDUDE guys, the gcc guys, the processing guys, and the java guys (I'm probably leaving others out?). The arduino platform design stands on the shoulders of many open source projects, it wasn't designed in a vacuum or a ground up effort, more like assembled from many other's open source contributions.
I think arduino's main unique contribution was their decision to open source their hardware design also which really spurred on a strong 3rd party 'compatible' and shield market that few other hardware/software micro-controller enjoy.
Lefty
GoForSmoke
Why do we use:
Code: [Select]
int led = 13;
instead of
Code: [Select]
byte led = 13;
If you would never need to define more than 256 pins, why use the extra space for int? Is there a reason?
Thanks.
That's what I do. 2k ram really isn't much, and then you try an ATtiny....
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
GoForSmoke
An "int" is an unsigned 16 bit variable (uses two bytes of memory).
Type int has always been signed in every version of C or C++ I ever used, including Arduino.
http://arduino.cc/en/Reference/Int
callmebob
#39
Mar 05, 2018, 04:39 pm Last Edit: Mar 05, 2018, 04:46 pm by callmebob
A "byte" type is the same as "uint8_t" (uses one byte of memory).  An "int" is an unsigned 16 bit variable (uses two bytes of memory).
Thanks krupski, for this informative answer. After going back to it now, I see this info is in the reference data, but I didn't absorb it like I did in your statement.
UKHeliBob
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
callmebob
#41
Mar 05, 2018, 04:57 pm Last Edit: Mar 05, 2018, 05:07 pm by callmebob
Oops, reviving a dead thread... sorry was so thrilled with the answer, I didn't read any dates.
After UKHeliBob's informative reply I noticed the dates. Thanks to the wonderful feature of this board, I had to wait 5 minutes before editing or deleting it.
Just a thought... it might be 5 years to you all, but it was only 15 minutes old to me :)
UKHeliBob
Quote
You are halfway to having the 5 minutes between posts restriction lifted (100 posts needed I believe)
Cosme_Fulanito
Arduino is not alone on this. There is an ongoing trend among computer programmers, and that is that you don't think that much about anything. One of those things you don't think about is data types. AT ALL.
Remember that "incident" (oh the horror!) on Youtube where the play count for Gangman Style rolled over?
They were using signed integers to store that. It would have taken a semi competent programmer of any seniority, let alone architect, to realize that it takes the same space and processing power to just use an unsigned integer, but that's not "standard", that's not "modern", modern is to use whatever holds numbers.
The base integer type of the language/platform gets used for anything numeric that doesn't need decimal places. Period.
UKHeliBob
Quote
There are programming languages that don't actually have data types.  Whilst this provides great freedom it does teach you to be very careful.  Debugging can be fun.
