Author Topic: logFile.close  (Read 408 times)
Hi
i have a question about using a file on you SD cart
normally you open a file SD.open.....  than write some data in it , and when you done close the file logFile.close()
But in my program it is opened at 00:00h and closed at 23:55h,
If i reset or powerdown between that time, the arduino will  NOT  give a logFile.close() .
Could the file then be corrupted or get corrupted, or ??? of will the pointer be lost , where file is ended (last written character)
i have done this a couple of times , not closing file and after start up the arduino opened it same file again for writing data , no problem, no currupt file..  is there some other program closing the file , or is thr SD cart protected against this
if a file could get corrupted , if there a check for this
geetings
Seattle, WA USA
Seattle, WA USA
Why? It should be opened when you need to write to it, and closed when you are done writing.
That's not good.
Yes.
You've been lucky. I don't advise continuing a bad practice, though.
Sure. Define corrupted. Detect where the files is corrupted, and write an EOF in that location. The file will no longer be corrupted.
That's not good.
Yes.
i write every 5 minutes data to it, so thats the reason i do not close it every time
Seattle, WA USA
Seattle, WA USA
That's not a reason. That's an excuse.
its the easiers way..  to leave it open
So your advice  open file write data and close it .. next 5 min open it again etc..  OK ., so window for crashing file is very small(only during writing)
But will the program or file know where the put the next line, is the pointer where the last character is written alway known, when i open the file again?
it see on the arduino.cc page
http://arduino.cc/en/Reference/SDCardNotes
Opening/Closing files
When you use file.write(), it doesn't write to the card until you flush() or close(). Whenever you open a file, be sure to close it to save your data.
So a flush will save it directly , what will do en close instruction , save an EOF???
« Last Edit: February 25, 2013, 03:51:40 pm by logger » Logged
Seattle, WA USA
Seattle, WA USA
Sure, but it's not the right way.
Yes, it is.
Depends on how you open the file. If you open in append mode, then, yes, the write pointer is positioned at the end of the file.
Each time you call the write() (or print() or println()) method, data is written to a buffer. The flush() method actually causes a write to the file, copying the buffer contents into the file. The close() method calls flush(). Closing the file does write an EOF into the file, while flush() does not.
Yes, it is.
OK thx for information
so only difference is the EOF , in my case . This could course a corrupt file , because it is not properly closed
file corrupt dectetion
can i detect it by  . if file SD.exist  then , try SD.open
a File object referring to the opened file; if the file couldn't be opened, this object will evaluate to false in a boolean context, i.e. you can test the return value with "if (f)".
