Topic: Arduino DUE and Home Easy (Read 3547 times) previous topic - next topic
eumanecs
Unable with Arduino DUE reciever code above to find outyour transmitter address for Home Easy devices. Have some one faced the same isue with recive code.
http://playground.arduino.cc/Code/HomeEasy
int rxPin = 12;
{       pinMode(rxPin, INPUT);
        int i = 0;
        unsigned long t = 0;
        byte prevBit = 0;
        byte bit = 0;
        unsigned long sender = 0;
        bool group = false;
        bool on = false;
        unsigned int recipient = 0;
        // latch 1
        while((t < 9480 || t > 10350))
        {       t = pulseIn(rxPin, LOW, 1000000);
        // latch 2
        while(t < 2550 || t > 2700)
        // data
        while(i < 64)
                if(t > 200 && t < 365)
                {       bit = 0;
                else if(t > 1000 && t < 1360)
                {       bit = 1;
                {       i = 0;
                if(i % 2 == 1)
                        if((prevBit ^ bit) == 0)
                        {       // must be either 01 or 10, cannot be 00 or 11
                                i = 0;
                        if(i < 53)
                        {       // first 26 data bits
                                sender <<= 1;
                                sender |= prevBit;
                        else if(i == 53)
                        {       // 26th data bit
                                group = prevBit;
                        else if(i == 55)
                        {       // 27th data bit
                                on = prevBit;
                        {       // last 4 data bits
                                recipient <<= 1;
                                recipient |= prevBit;
                prevBit = bit;
                ++i;
        // interpret message
        if(i > 0)
        {       printResult(sender, group, on, recipient);
void printResult(unsigned long sender, bool group, bool on, unsigned int recipient)
        Serial.print("sender ");
        Serial.println(sender);
        if(group)
        {       Serial.println("group command");
        {       Serial.println("no group");
        if(on)
        {       Serial.println("on");
        {       Serial.println("off");
        Serial.print("recipient ");
        Serial.println(recipient);
eumanecs
I think - does it mean that i should increase timings 5.25 times greater, because DUE CPU core clock speed is 5.25 times greater, 84Mhz instead of 16 Mhz as for UNO. Or should I change 1000000, core clock speed value.
cmaglie
The parameters for pulseIn(..) are expressed in uS (microseconds) your sketch should work across different boards.
May you try your on an Arduino Uno (or any other board), to discover if the issue is specific for the Arduino Due?
C.
eumanecs
I've tried this skech with the Arduino UNO and Leonardo serial monitor prints the recipiant and Sender ID.
But with the Arduino DUE this same code does not print out any data on seril monitor. So the problem is related directly to the DUE board
